> Acura NSX
Old 05-06-2008, 07:56 PM   #51
goferkiller007
goferkiller007's Avatar
Default Re: Photos of each system (Ponyboy)
nice setup
goferkiller007 is offline Report Post   Reply With Quote
Old 06-29-2008, 09:38 PM   #52
Top Ramen
Top Ramen's Avatar
Default Re: Photos of each system (goferkiller007)
Some nice air cleaners on a V8 TWM ITB set-up:
"Until I see a lawsuit, I just don't see how I have a customer service problem" - Javier Gutierrez (JG Engine Dynamics) .
Top Ramen is offline Report Post   Reply With Quote
Old 08-26-2008, 08:43 PM   #53
tealchief
tealchief's Avatar
Send a message via AIM to tealchief
lawl all these pics look so sexy.. but from what ive read the SoS sounds like the best deal to me.
1994 h22a eg hatch- fkn project
1999 civic ek b16-pwnt by mercedes m-class
2006 accord i-4-LAME
tealchief is offline Report Post   Reply With Quote
Old 09-03-2008, 08:43 AM   #54
Ponyboy
Modeval
1991 Acura NSX
Ponyboy's Avatar
Send a message via AIM to Ponyboy
Default Re: (tealchief)
Regarding single TB vs. ITB, from the Jenvey website:
Why not just use a big single throttle body?
The choice of thottle body size for the typical road car is a compromise between two opposing needs; to allow sufficient air flow for the engine to achieve its full power potential and to keep the butterfly small enough to allow a progressive throttle action at low openings.
The engine designer has a number of tricks available to help match these opposing needs: the no. 1 solution is to use a linkage which favourably varies the ratio between pedal movement and throttle action. For example, our SFG (big single) throttle body rotates the butterfly 1.4 degrees for the first 10 degrees of quadrant rotation (5.5mm of cable travel) and 20 degrees for the last 10 degrees of quadrant rotation. Other solutions include shaping the bore of the throttle body such that the gap on one side of the butterfly remains small for the first part of butterfly rotation, using two butterflies opening sequentially and electronic throttle control.
The above techniques allow the designer to use a sufficiently large throttle body bore that rarely limits engine performance to a measurable degree. It follows that enlarging the original throttle body will only make a useful gain when other aspects of the engine have been changed to substantially increase the power output. The most likely change due to a larger throttle body, if any, on an otherwise standard engine is a car that goes slower round corners due to lack of fine throttle control for the driver. At best, there may be a slight improvement in response (see below).
It helps to understand the relationship between size and output to consider that a 2L Formula 3 engine produces 200+BHP through a 26mm (531 sq mm) restrictor, whilst, say, a 75mm throttle body is eight times larger at 4,418 sq mm! Similarly, in an experiment to curb the power of 270 BHP touring car engines, we reduced the size of the single throttle body to less than 44mm (1520 sq mm) before there was any noticeable reduction: a 75mm body has three times the flow.
The single throttle body has a number of benefits for the mass-producer: it requires no balancing or fine-tuning since all cylinders are drawing from a common volume. It is also cheaper to make than multiple bodies and, for everyday motoring, has the advantage that throttle response is gentle and delayed since sudden opening of the throttle must first fill the entire induction system before the engine gets the full benefit. This effect is well suited to the needs of the inexpert driver since, whatever the throttle position, torque builds slowly and nothing happens suddenly.
Multiple throttle bodies are used in all naturally-aspirated true race engines, most motorbikes and some top-end cars (e.g. BMW M series): i.e. where the driver prefers to be in full control. They have a number of advantages: The most obvious to the driver is virtually instantaneous throttle response whilst the individual inlet tracts allow true length tuning of the inlet system – a large influence on torque and power output. In a well-designed throttle body system the positioning of the injectors and butterflies aid fuel mixing: very important in higher RPM (i.e. above 5,000) engines.
In summary;
Single throttle bodies;
Are simple to set up.
Are cheap to make.
Make engine response gentle – will not frighten the average driver.
Are easily silenced.
Multiple throttle bodies;
Make engine response lively.
Increase power and torque by improving mixture quality – particularly at higher RPM.
Increase power and/or torque by resonance tuning – when correctly lengthed.
Give no-compromise performance.
3.6L NSX ScienceofSpeed Stroker - 335rwhp/270rwtq and a thousand more revs to go.
Ponyboy is offline Report Post   Reply With Quote
Old 09-18-2008, 12:31 PM   #55
Ponyboy
Modeval
1991 Acura NSX
Ponyboy's Avatar
Default Re: (Ponyboy)
Dug up these old photos from my archive - Comptech USA fab'd ITBs:
Fixed!
Modified by Ponyboy at 8:17 PM 9/18/2008
Old 09-18-2008, 02:42 PM   #56
DisturbedK24
DisturbedK24's Avatar
pics dont work!!! lets see those bad boys ponyboy
i poop bigger than you dream
DisturbedK24 is offline Report Post   Reply With Quote
Old 11-01-2008, 01:00 PM   #57
Ponyboy
Modeval
1991 Acura NSX
Ponyboy's Avatar
Default Re: (DisturbedK24)
Looks like there's a new entrant in the NSX ITB field, Tracy Sports. The Winter issue of Honda Tuning has a pictorial of 3.5L ITB'd NSX which looks to be the company's show/race car.
Looking for web pics now...
Old 11-01-2008, 06:53 PM   #58
Top Ramen
Top Ramen's Avatar
With Japanese 'tuners' you have to be careful; just because they show a product on their car and sell it doesn't mean they make it. A LOT of them re-package another companies parts and call it their own.
Old 06-30-2009, 09:28 PM   #59
dr.gonzo
Default Re: Official ITB Performance Discussion
I am currently building an all motor set up in my miata. Nothing beats the instant throttle response + the sound
dr.gonzo is offline Report Post   Reply With Quote
Bookmarks
air, airbox, box, c30a, cwest, filter, honda, hp, itb, itbs, jenvey, nsx, plenum, sports, system, tracy
