#1 | |||||
Modeval
1991 Acura NSX |
3.6L NSX ScienceofSpeed Stroker - 335rwhp/270rwtq and a thousand more revs to go. |
#2 |
The SoS ITBs are really Hayword, which gives them a huge advantage in my opinion. Lance does a good job designing and building manifolds and linkages and he uses Jenvey throttle bodies, which are the best available. Thesy use 48mm (at the plate) Jenveys and are tapered overall. It is by far the cheapest system ($4.5K) and is probably the most complete - including a vaccuum accumulator and cold start mechanism. I think it also has the longest overall runner length, which is nice on a motor not known for torque.
I have heard Revolution has a new design, which is good news, because their old set-up was crap. I think they scavenged parts off of a Porsche system instead of starting from scratch and it showed. Hopefully the new system is better, but it is hard to get technical information from them. They are 787,500 Yen plus whatever it costs to get them here. The Todas are okay, but those guys are way too in love with their parts. There is absolutely no way they are worth the asking price. They come in 45mm or 47mm. Modified by Top Ramen at 9:50 AM 5/21/2007
"Until I see a lawsuit, I just don't see how I have a customer service problem" - Javier Gutierrez (JG Engine Dynamics) . |
#3 |
Science of Speed
note the overall length and the nice injector placement ![]() Toda ![]() New Revolution Looks like it would be tough to build a box for these without interfering with the linkage. ![]() Old Revolution
#4 |
Modeval
1991 Acura NSX |
I've heard the same about the SOS/Haywood ITBs - about the Jenvey throttle bodies and the cold start mechanism. The cold start and idle issues seem to be where the systems get hung up.
Here's closer up pic of the TODA itbs: ![]() Man, I'm in love with that CF airbox/plenum. And another pic of the Revo itbs w/ a decidely unstock transmission and mounts: ![]() And some "to be determined:" ![]() ![]() Old Revo's?
#5 | |
I would run big tubes down to the side scoops (both of them) and use cone filters to feed cold air from both sides into the ITBs. You sould need to loose the fan on the passenger side, but it is pretty pointless anyway. You could easily build a small box that enclosed the cone filters and sealed up against the side scoops. Like this: ![]() Now that is just sweetness. . . .
#6 |
hmm pretty nice carbon manifold. Do you know the company that produces that?
Tuning is EVERYTHING! 235whp 173Lbs of torque 2.3 VTEC H22a Dc2 NA! 280whp 201lbs of torque 2.6 VTEC H22a NA! [b]-ECU UPGRADES-JDM ENGINES-JDM PARTS-HONDATA- CNC PORTED HEADS-CUSTOM HEADERS AND MORE! H22A SWAP SPECIALISTS! http://www.PROSPEEDPOWER.com |
#7 | |
96RS History EK4 HB NA1 MC21 |
#8 |
what a cluster FOX...news.
anyone have numbers of what each ITB setups can produce?
#9 | |
#10 | |
i will try. Search initiated.
#11 |
Modeval
1991 Acura NSX |
Nice pics of that CF airbox/plenum, Davey. I wonder what the formula is for determining the ideal plenum volume though?
Although hatch induction would be much easier, I'm not a big fan of the JGTC scoop either. Maybe the Advance slotted hatch would work though. ![]() Looks like Advance has their own ITB system as well: ![]()
#12 |
that slotted glass is nice but i think the scoop would yield more air inside.
#13 |
Modeval
1991 Acura NSX |
Very likely but, man, are those an eyesore. I think if one is thinking about going in that direction, they may as well go for the whole "shark fin" and get even more pressurized air in the plenum.
I wonder if a NACA(s) duct would work...
#14 |
I don't think there is an "ideal" plenum size on set-ups like this. You just need to get it big enough to provide even (and plentiful) air to each throttle assembly. The overall ITB/runner/stack length is what gets tuned for resonance.
#15 |
Modeval
1991 Acura NSX |
I'm thinking that by adding a "tuned" plenum, one could tune another 2 (total of 6) resonance frequencies.
From what I've read, a short wide intake runner favors higher RPM torque peak b/c they have a higher resonant frequency and the larger diameter is less air flow restrictive. A longer narrow intake runner favors lower RPM torque peak b/c of a lower resonant frequency and narrower diameter increases velocity. And examples of the varying philosophies are above in the pics as well. Good stuff. Now I know why F1 engines use a variable intake.
#16 |
itb for the win.
#17 | ||
#18 |
You could always go open mesh over your engine bay. Seriously its not that bad, you learn how to use the side mirrors real quick. Plus the engine cools down like you wouldn't believe.
I too am thinking about ITB's on my Exige. The hard part is that we use e-throttle, which might be OK depending on how an e-throttle motor works. But even harder is that we use MAF, so finding a way to measure the air is alot harder. You guys are at least lucky enough to have MAP systems.
2006 Lotus Exige 280HP and only 1970 pounds. |
#19 | ||
Modeval
1991 Acura NSX |
And I've been looking on the SAE website for books on intake theory and design but...nothing. Quote:
Found a new close-up pic of the Revolution ITBs ganked from the Top End website:
#20 | |
Modeval
1991 Acura NSX |
#21 | |
#22 |
Modeval
1991 Acura NSX |
Found a good pic of the plenum internals:
![]() Think that's 5.4 liters?
#23 | |
#24 | |
You could also look into discrete intake manifolds for the banks. 3 cylinders get a single manifold with its own throttle body (like a 60mm or so). Link the 2 throttle body actuators together and read the TPS off one of them. Connect the MAP sensor to both of them. The IACV may be a little interesting though. Kind of like how the bigger V engines are with dual throttle bodies.
#25 |
Modeval
1991 Acura NSX |
That's certainly possible. Though, for me, I think I'd like to keep whatever I go with as stock looking as possible - at least on the outside.
Found a good filter idea: And the site: http://www.verycoolparts.com/Stack.htm This may be the easiest way to go along with the Advance hatch.
| Bookmarks |
| Tags |
| air, airbox, box, c30a, cwest, filter, honda, hp, itb, itbs, jenvey, nsx, plenum, sports, system, tracy |
