> Honda CRX / EF Civic
Old 05-17-2007, 11:49 AM   #1
wickedEFguy
wickedEFguy's Avatar
Send a message via AIM to wickedEFguy
Default For those that need the ES hyperflex and trailing arm instructions please look
I got bored at work and but together all the PDF sites that use the energy suspension hyperflex kit, They're way of using part numbers with PDF files gets a little confusing so I got all of them together to stop any confusment for others. I also added the trailing arms so if you don't have any of these instructions then here's the direct links to them. Hope this helps
16.3103 - Front End Control Arm Bushing set
16.3104 (85) and (119) – Rear end control arm bushing set
16.10101 – Steering Rack Bushing Set (Power steering only)
16.8102 – Front Shock upper and Lower bushing set
16.1102 – Manual Transmission Shifter Stabilizer Bushing Set
16.8103 – Rear upper and lower bushing set
16.8104 – Front End Links
16.7102 - Front strut Rod Bushing Ser
16.5111 - (19MM) )Front Sway Bar Fram Bushings 16.5110 (18MM)
9.13103 – Tie Rod Boots
16.13101 – Front Ball Joint Boot set
16.102 – Sway bar
16.7106 – Rear Trailing Arms
16.18102 - CRX 1988-91 Hyperflew System Complete Master bushing Set
(17139, 17140, 17153, 17155, 17161, 17162, 17163, 17248, 17276, 17389)
16.3103 - http://energysuspension.com/pdf_instruc/17139.PDF
16.3104 - http://energysuspension.com/pdf_instruc/17140.PDF
16.10101 - http://energysuspension.com/pdf_instruc/17153.PDF
16.18102 - http://energysuspension.com/pdf_instruc/17155.PDF
16.1102 - http://energysuspension.com/pdf_instruc/17161.PDF
16.8102 - http://energysuspension.com/pdf_instruc/17162.PDF
16.8103 - http://energysuspension.com/pdf_instruc/17163.PDF
16.38104 - http://energysuspension.com/pdf_instruc/17248.PDF
16.18102 - http://energysuspension.com/pdf_instruc/17276.PDF
16.3111 - http://energysuspension.com/pdf_instruc/17389.PDF
16.102 - http://energysuspension.com/pdf_instruc/17039.PDF
16.7106 - http://energysuspension.com/pdf_instruc/17339.PDF
90 Red CRX Si with a turbo B16 Jackstand garage conversion. http://images.honda-tech.com/set1/smile/emthup.gif
If you prick us, do we not bleed? if you tickle us, do we not laugh? if you poison us, do we not die? and if you wrong us, shall we not revenge?".
-William Shakespeare
wickedEFguy is offline Report Post   Reply With Quote
Old 05-17-2007, 12:06 PM   #2
dopey88
dopey88's Avatar
WOW thank you i vote for a STICKY!!!
dopey88 is offline Report Post   Reply With Quote
Old 05-17-2007, 12:22 PM   #3
Tyson
Tyson's Avatar
Default Re: For those that need the ES hyperflex and trailing arm instructions please look (wickedEFguy)
as much as i recommend not using energy suspension bushings, the information is good and well organized.
its now in the FAQ.
btw, front swaybar bushings are 18mm on DX and Si. civic 4dr sedans are 19mm. HF is 17.2mm, which doesnt correspond to the "16mm" nominal size. i have no idea why they offer it as 16mm.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 07-09-2007, 10:02 AM   #4
hust1er
hust1er's Avatar
Default Re: For those that need the ES hyperflex and trailing arm instructions please look (Tyson)
y dont you recommend using es bushings?
hust1er is offline Report Post   Reply With Quote
Old 07-09-2007, 10:22 AM   #5
crazykamper
crazykamper's Avatar
Send a message via AIM to crazykamper
^ also curious, trailing arm ones i understand, but why not the rest?
WTB : Full-Coilovers for ek! ; Preffer F&F Type 2, or type 1,but pm me what you got! (ground controls or buddyclub or whatever it maybe...)
crazykamper is offline Report Post   Reply With Quote
Old 05-02-2008, 04:10 PM   #6
yuletak
yuletak's Avatar
Default Why not ES?
Bump on the request for explanation of why not ES.
yuletak is offline Report Post   Reply With Quote
Old 05-02-2008, 04:19 PM   #7
Deetz
2002 Acura RSX
Deetz's Avatar
I can give some insight....
I have a set on my crx. Most of the kit is pretty good, but...the bushing for the front lower control arms, make the ride stiff as hell and very harsh on bumps on the street.
Also, you have to be very liberal when applying the grease to them, poly bushing love to squeek. And sometime will require you to pull out a noisy one and re-apply grease time to time. Aside from that, the car will feel super solid, and handle great.
1989 CRX SI
2000 EM1- Vogue Silver
2002 RSX -K24 project on the way
Deetz is offline Report Post   Reply With Quote
Old 05-04-2008, 04:49 PM   #8
yuletak
yuletak's Avatar
Default Re: (Deetz)
Thanks for the info.
Old 05-04-2008, 09:07 PM   #9
ED9man
ED9man's Avatar
Send a message via AIM to ED9man
Default Re: (crazykamper)
Because you have to replace them every year unless you want to pull them out, clean, and relube them every few thousand miles. They are cheap enough if you are willing to put out the labor.
ED9man is offline Report Post   Reply With Quote
Old 05-05-2008, 06:21 AM   #10
ComeOnKip
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
Send a message via AIM to ComeOnKip
The reason poly sucks is because it responds like sticky rubber.... thus not allowing unihibited travel of the suspension arms. Notice how hard an LCA to move is once your replace the bushings w/ poly? cause all its doing is binding and grabbing.
For the street, If i ever replace bushings again i'm going hard rubber or just oem rubber. For a race car go spherical. Poly has no use for alot of suspension applications.
We all knew what consequences could be with the crew we had at the controls, there's no harbor age for the USA-holes. I doubt there's a benign God to save our souls, cuz no one else is gonna save the USA-holes
ComeOnKip is offline Report Post   Reply With Quote
Old 05-05-2008, 10:57 AM   #11
Zdyned
Zdyned's Avatar
Default Re: (ComeOnKip)
i replaced the front and rear LCA's only and it did squeak occasionaly like when going super slow and flexing over a speed bump, but if you drive a lowerd CRX then your ride is prolly already super stiff.
The sway arms though from what i understand are bad to replace with poly because they make the car way to stiff and do not allow enough travel.
so my point is selectively the ES kit isn't bad, but i think the entire kit makes the car way to stiff for daily use.
thanks for the info though it would have been nice to have this before i did my bushing... well maybe not because then i would have put them all in and the car would have been to stiff
Zdyned is offline Report Post   Reply With Quote
Old 05-13-2008, 01:47 AM   #12
yuletak
yuletak's Avatar
Thanks for all the great responses. I was set on purchasing the master set from Amazon for $142. Now I'll probably opt not to.
Old 07-10-2008, 10:17 AM   #13
vtec_head
vtec_head's Avatar
Default Re: (yuletak)
Does anyone recommend another aftermarket bushing kit?
My 88 rex desperately needs bushings all around!
About how much does this kit run for? Is it more or less expensive than O.E.?
thanks!
'07' Accord V6 sedan and '88' Anthracite VW grey CRX zc and '07' Honda Rincon 680cc 4x4 atv and a '07' Tundra 5.7 ltr. TRD dbl cab(sorry it's not a Honda)
"the more you know.....the faster you will go"
vtec_head is offline Report Post   Reply With Quote
Old 07-10-2008, 11:09 AM   #14
mike-y
mike-y's Avatar
Send a message via AIM to mike-y
Default Re: (vtec_head)
also, poly bushings wear out much faster than oem rubber.. in just a couple of years they can become cracked and deteriorated and then you've got extra play in your suspension. Unless its a full on race car, just stick with new OEM bushings, or mugen hard rubber bushings if you want to pay the price for those.
And fwiw, the newer RTA replacement bushing that you can get from honda is a harder rubber (like the mugen piece) than the original ones that came with the car.
mike-y is offline Report Post   Reply With Quote
Old 06-02-2009, 11:02 AM   #15
Charlie Moua
Charlie Moua's Avatar
I know over the years honda will go with different manufactures.
How do you know that the bushing are harder(rubber) than the originals since it's not possible to compare a new "original" bushing with a new one?
Charlie
<FONT SIZE="1"><FONT COLOR="green">VOUCH Thread</FONT></FONT>
Dyno Apexi B16a 10psi
Dyno Apexi B18b 10psi
Dyno Apexi B18b 14psi
<FONT COLOR="gold">Mugen 無限 Power</FONT>
235whp & 175tq @ 7psi
280whp & 205tq @ 10psi
300whp & 230tq @ 14psi
Charlie Moua is offline Report Post   Reply With Quote
Old 06-02-2009, 02:50 PM   #16
TunerN00b
TunerN00b's Avatar
Charlie
The part number changed when they swapped.
The new design has more rubber, and is visually different.
Durometer tests have confirmed that the material itself is also stiffer.
I haven't seen a direct comparison to the Mugen pieces. I also don't have the links to back what I wrote, I'm going off of memory here and might be including information I read on another forum. Hopefully I didn't mis-remember anything.
And you could compare the new design to the older design on a new bushing. At one point in time, you could get either of them from the dealer. They should have all been replaced with the new part by now though.
TunerN00b is offline Report Post   Reply With Quote
Old 06-02-2009, 08:04 PM   #17
Charlie Moua
I'll have to price it out OEM and ES bushings. I think in some applications it would be okay to go with ES but some I'll opt for OEM. Can somone help double check my list for OEM P#?
Energy Suspension Hyperflex Kit 88-91 civic/crx
16.3103 - Front End Control Arm Bushing set H# 51393-SH3-003 - $17.80
16.3104 (85) and (119) – Rear end control arm bushing H# 52365-SH3-000 (2) - $14.22
16.8102 – Front Shock lower bushing H# 51810-SH3-004 - $13.77
16.8103 – Rear lower bushing H# 52622-SH3-010 - $14.41
16.8104 – Front sway-bar end link bushing # 52316-692-010 (8) $1.66
16.7102 - Front strut rod Bushing
16.5110 - Front Sway Bar (18mm) Frame Bushings H# 51316-SH3-000 (2) $4.14
16.102 – Rear sway-bar end links bushing H# 52314-SH3-000 (2) - $5.88
16.7106 – Rear Trailing Arms (USE OEM, Mugen or Megan)
OEM EF ('88-00 Civic, '88-91 CRX, '97-01 CR-V, '93-97 del Sol, '94-01 Integra) #52385-S21-003 - $34.95 (or 52385-SR3-000 - $54.69)
OEM DA - 52385-SK7-N02
Old 11-10-2009, 02:07 PM   #18
elf469
2008 Acura CL
elf469's Avatar
Send a message via AIM to elf469
Mugen bushings part #'s from www.kingmotorsports.com
Front End Mugen Hard Bushings
Front Lower Arm Set - 2 Piece Set [51393-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Front Radius Rod Set - 4 Piece Set [51395-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Front Shock Absorber Fork Set - 2 Piece Set [51810-XE5-S0N0]
Civic (1988-1991)
Civic (1992-1995)
CRX (1988-1991)
Del Sol (1993-1997)
Integra (1994-2001)
Front Spring Mount [51686-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Front Upper Arm Set - 4 Piece Set [51455-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Mugen Shifter & Steering Hard Bushings
Shift Linkage Bushing Set - 2 Piece Set [54300-XG5-S0N0]
Civic (1988-1991)
Civic (1992-1995)
Civic (1996-2000)
CRX (1988-1991)
Del Sol (1993-1997)
Integra (1990-1993)
Integra (1994-2001)
Steering Box Cushion Set [53434-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Rear End Mugen Hard Bushings
Rear Compensator Arm Set - 4 Piece Set [52343-XE5-S0N0]
Civic (1988-1991)
Civic (1992-1995)
Civic (1996-2000)
CRX (1988-1991)
Del Sol (1993-1997)
Integra (1990-1993)
Integra (1994-2001)
Rear Lower Arm Set - 4 Piece Set [52365-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Integra (1994-2001) 1998-01 Type R
Rear Spring Mount Set [52686-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Rear Trailing Arm Set - 2 Piece Set [52385-XE9-S0N0]
Civic (1988-1991)
Civic (1992-1995)
Civic (1996-2000)
CRX (1988-1991)
Del Sol (1993-1997)
Integra (1994-2001
Rear Upper Arm Inner Set - 2 Piece Set [52393-XE5-S0N0]
Civic (1988-1991)
CRX (1988-1991)
Integra (1990-1993)
Rear Upper Arm Outer Set - 2 Piece Set [52395-XE5-S0N0]
Civic (1988-1991)
Civic (1992-1995)
Civic (1996-2000)
CRX (1988-1991)
Del Sol (1993-1997)
Integra (1990-1993)
Integra (1994-2001)
elf469 is offline Report Post   Reply With Quote
Old 11-10-2009, 03:38 PM   #19
ComeOnKip
ComeOnKip's Avatar
I have since installed the Suja 1 motoring hard rubber kit on my car (all except RTA because I have DA rear trailing arms which got new stock bushings). Awesome, as far as driving the car they feel just as firm as the polys, no squeaking at all.
If someone needs my RTA bushings for an EF I'll sell them Pm me.
Old 11-10-2009, 04:59 PM   #20
CRX Toad
Moderator
CRX Toad's Avatar
Well put together. I also agree with Tyson and the others on ES. There is much better materials out there for the application.
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
CRX Toad is offline Report Post   Reply With Quote
Old 11-10-2009, 05:04 PM   #21
ef-hatchcrap
ef-hatchcrap's Avatar
Send a message via AIM to ef-hatchcrap
I have the entire es bushing kit on my crx and I have no issues or squeaking from the bushings at all I love it. I drive the car 30 miles one way to work
ef-hatchcrap is offline Report Post   Reply With Quote
Bookmarks
17339, 2003, accord, arm, bushing, bushings, cotrol, energy, honda, hyperflex, labor, lower, replace, rod, strut, suspension, work
