#1 | |||||
.EF Squad Member #6 |
#2 |
15 views and nothing so far...
Bump!
#3 |
Daily bump...
#4 |
I don't like you.
2001 Honda S2000 |
from what i have been told, the mcphearson's suspension setup was a way that honda could cut cost, since its a 'cheaper' design. also, the suspension does not have much shock travel. the RSX also has alot more understeer than the older model hondas, but you can slightly fix this with a larger rear swaybar. if you ever look at the realtime racing rsx's they have a completely redesigned suspension for better handling. see http://www.realtimerl.com/content/acura-rsx for their setup.
FS: 2001 Honda S2000 |
#5 | |
Give people time, not a lot of folks know a lot about the suspension on the DC5. I know I have personally posted, more times that I wish to count, the things wrong with the DC5 setup and ways to correct them. I wanted to see where this thread went before I chimed in. I'm not bragging, but I probably have the most experience with the DC5 setup on this forum right now. I've see the HART solution to the problems and I've talked extensively with the folks at Koni. I've also owned 3 cars based on this platform and worked with every one of them. I was hoping to fill in the holes where others have posted rather than do the entire writeup myself. |
#6 | |
I don't like you.
2001 Honda S2000 |
#7 | |
#8 | |
I don't like you.
2001 Honda S2000 |
#9 |
I appreciate the replies guys. Sorry about bumping, but we all know how fast threads drop on HT
We're just that popular.Anyways, I'll just keep checking back for more info when I can. Again any info posted is appreciated. Maybe if this thread goes well and a lot of info gets added, maybe it could be stickied? We will have to wait and see. Cheers all.
#10 |
This my last attempt at getting some info on the subject. If I don't get any replies, I will just assume that the DC5 handles like crap.
#11 | |
Too low = poor roll center, no suspension travel, ill tie-rod angles and shock binding in the rear. Motion ratio = ~ 1:1 front, .5:1 rear. Hence, you need double the rate out back to keep a neutral car. About 4x in the rear if you want very good rotation. Also, DC5 doesn't have much caster. You can get a lot of camber in the front, which somewhat makes up for it. Positives of the DC5 are a solid chassis and the ability to fit a large wheel/tire package on it. Plus, the K-series motor. You can tune the suspension somewhat and fix some of the problems, but overall it will never be as good as the old DC2 setup. |
#12 |
I dont know alot about suspension. Why is the mcpherson worse than the double wishbone?
Vouches: Stryker - Good parts, Better delivery. http://images.honda-tech.com/set1/smile/emsmilep.gif http://images.honda-tech.com/set1/smile/emthup.gif BozoSI - Good Guy, awesome parts! http://images.honda-tech.com/set1/smile/emthup.gif Tokuisport - Quick delivery, Cool guy. http://images.honda-tech.com/set1/smile/emthup.gif Alucard - Cheap and Good parts. Very honest! http://images.honda-tech.com/set1/smile/emthup.gif GSR Racer Chick - Life saver! Good cheap parts! http://images.honda-tech.com/set1/smile/emthup.gif |
#13 | |
a lot less adjustable.... and once you start shortening the distance between the lower control arm and the top of the strut more that like an inch and a half it gets a sweet terminal body roll effect.... there is more im sure. |
#14 |
Pacific North Fresh
2003 Honda CivicJoin Date: Oct 2008
Thanks for answering his question, just about 2.5 years too late
#15 | |
grammer nawzi
Hostis honori invidia H-T Grammar Police #002 Will suck pp for nice whip Crew Member #1 |
#16 |
im pretty sure ive seen ppl cut the shock tower and make them higher to slam their cars. cant the same principle be applied for a slammed car to handle good aswell?
Buy My Shit! Full D17 manual swap $900, D17 motor $350 http://www.hondamarketplace.com/show....php?t=2668519 |
#17 |
Pacific North Fresh
No, there's a lot more to it than shock travel. Please now, lets not fill this thread with incorrect information like others (not directed at anyone). There are plenty of threads open that can answer any question on DC5/EP3 suspension.
#18 |
lol, I rock.
| Bookmarks |
| Tags |
| binding, coilover, dc5, forum, function, low, setup, suspenion |
