* * OBD1 B-series engine into OBD2a/OBD2b civic/integra * *
Old 09-08-2008, 05:58 PM
  #101
caraudiofaq's Avatar
Default Re: (Katman)
Hi katman : I have an 99 ex hatchbk i want to but an 99 B18b ls motor in , i have the ex harness what type of ecu can I use? thnx......
Old 09-08-2008, 06:47 PM
  #102
Katman's Avatar
Default Re: (caraudiofaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caraudiofaq &raquo;</TD></TR><TR><TD CLASS="quote">Hi katman : I have an 99 ex hatchbk i want to but an 99 B18b ls motor in , i have the ex harness what type of ecu can I use? thnx......</TD></TR></TABLE>
well you can use the 99 LS ecu, but you'll need to get an OBD2b to OBD2a jumper harness adapter (which i sell ) in order to plug n' play to the ecu. Either that or convert to OBD1 and run an OBD1 LS ecu.
You won't want to use the 00-01 integra LS ecu because of the immobilizer situation. Although I do have a way to bypass the immobilizer and you won't have a constant CEL light. Actually this would probably be the cheapest route. Hit me up if you're interested...
Old 09-09-2008, 03:58 PM
  #103
thnx..........
Old 09-09-2008, 04:06 PM
  #104
how much is the harness?
Old 09-11-2008, 04:03 PM
  #105
Katman's Avatar
PM.d
Old 09-20-2008, 08:46 AM
  #106
BLACKLIST138's Avatar
kats prolly has a harness cause i flake pump faked him on one a month ago..
Old 09-20-2008, 09:35 PM
  #107
97_coupe's Avatar
Hey Katman, I am in the middle of swapping a JDM OBD1 B16 SiR II in my 97 DX, I thought that all D series injectors were 240cc but now I am not sure. I didnt want to convert my OBD2 injector plugs to OBD1 so is it ok to use my DX injectors or should I just convert them? If so, what route should I take to convert them, thanks.
Old 10-01-2008, 09:06 AM
  #108
JDMblkguy's Avatar
Default Re: * * OBD1 B-series engine into OBD2a/OBD2b civic/integra * * (Katman)
idk if this has already been asked. but i need to know. im putting an obdo B18a1 in my 90 civic Si hatch. and i was wanting to know if i had to change my spindles? some say yeah some say no. if anyone could help better than CH let me know
parts i have
B18A1 obdo
obdo pr4
still looking for tranny
Old 10-03-2008, 01:57 PM
  #109
kaoticstyles's Avatar
Default Re: * * OBD1 B-series engine into OBD2a/OBD2b civic/integra * * (JDMblkguy)
so using any auto harness will not let the car start?
Old 10-04-2008, 10:55 AM
  #110
Rcriteser's Avatar
I have a 2000 honda civic DX. I pulled the d16 and replaced it with a 98 b18c5 out of a type r integra. im using the engine harness from a 99 civic si. my si harness only has 8 wires my dizzy has 9. im using a 99 si ecu. car starts in limp mode. but if you rev it up a lil turn the key to off and back on then you can trick it and it will rev all the way to 9000 rpm. but then the car wont idle it shuts down if you dont keep the idle above 1500 rpm. i tried to swap a 99 si dizzy on the motor and it wouldnt even attempt to start. Now i have a P06 ecu chipped with the Hondata S300. Unfortunately you cant trick this ecu with the key trick. so i can rev to 3800 and thats it. Does anyone know how to fix this.Will trying a 99 si dizzy on this ecu work? I have a new one on the way just waiting on it to get here. I need it to run right so i can get it on the dyno and get it tuned. Im only running 5psi of boost right now cause im afraid to go any higher. Im still using the 99 si ecu so i can trick it and get it to rev.Any help would be greatly appreciated. Thank you.
Modified by Rcriteser at 2:03 PM 10/4/2008
Old 10-10-2008, 06:55 AM
  #111
nels450's Avatar
hey katman, new to this whole scene, got a 96 civic ex that had the d16y8 in it. i just bought a b16a2 out of a 99 si. now from what i read in order to use that 99 ecu i have to get the jumper harness, a to b, right? which by the wya you sell right? or can i use a obd1 ecu? sorry for the noob questions, btw grat thread
Modified by nels450 at 8:02 AM 10/10/2008
Old 10-10-2008, 07:39 AM
  #112
Katman's Avatar
Default Re: (nels450)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nels450 &raquo;</TD></TR><TR><TD CLASS="quote">hey katman, new to this whole scene, got a 96 civic ex that had the d16y8 in it. i just bought a b16a2 out of a 99 si. now from what i read in order to use that 99 ecu i have to get the jumper harness, a to b, right? which by the wya you sell right? or can i use a obd1 ecu? sorry for the noob questions, btw grat thread
Welcome...
That is correct, you would need an OBD2a-&gt;OBD2b jumper harness to run the 99 Si ecu or if you wanted to convert to OBD1 you'd need an OBD2a-&gt;OBD1 jumper harness & OBD1 ecu such as a reprogrammed P28.
OBD1 allows for reprogramming whereas the Si ecu does not.
Old 10-10-2008, 08:03 AM
  #113
nels450's Avatar
so do u have htose jumper harness.i have a p28 ecu out of my old civic and i also know where i could get a p72 if i were to go obd1. would the p72 be the better option?
Old 10-10-2008, 09:18 AM
  #114
Katman's Avatar
Default Re: (97_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Hey Katman, I am in the middle of swapping a JDM OBD1 B16 SiR II in my 97 DX, I thought that all D series injectors were 240cc but now I am not sure. I didnt want to convert my OBD2 injector plugs to OBD1 so is it ok to use my DX injectors or should I just convert them? If so, what route should I take to convert them, thanks.</TD></TR></TABLE>
Most of the D & B-series injectors are 240cc. Your OBD2 DX injectors are 240cc if memory serves me right, so you can use those with your B16 swap. Btw, you can make OBD1 injectors fit into an OBD2 plug by pulling out the blue insert as seen here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMblkguy &raquo;</TD></TR><TR><TD CLASS="quote">idk if this has already been asked. but i need to know. im putting an obdo B18a1 in my 90 civic Si hatch. and i was wanting to know if i had to change my spindles? some say yeah some say no. if anyone could help better than CH let me know
I believe if you have an Si of HF model, you're ok, but the lower models (DX/STD) need to have the spindles swapped out for that of an Si or HF model spindle.
EF guys could chime in if they want
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoticstyles &raquo;</TD></TR><TR><TD CLASS="quote">so using any auto harness will not let the car start?</TD></TR></TABLE>
Yes - IF using an Auto harness in a 5speed chassis.
Reusing an Auto harness in an auto chassis converted to 5-speed has been reported to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rcriteser &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 honda civic DX. I pulled the d16 and replaced it with a 98 b18c5 out of a type r integra. im using the engine harness from a 99 civic si. my si harness only has 8 wires my dizzy has 9. im using a 99 si ecu. car starts in limp mode. but if you rev it up a lil turn the key to off and back on then you can trick it and it will rev all the way to 9000 rpm. but then the car wont idle it shuts down if you dont keep the idle above 1500 rpm. i tried to swap a 99 si dizzy on the motor and it wouldnt even attempt to start. Now i have a P06 ecu chipped with the Hondata S300. Unfortunately you cant trick this ecu with the key trick. so i can rev to 3800 and thats it. Does anyone know how to fix this.Will trying a 99 si dizzy on this ecu work? Any help would be greatly appreciated.
hmm...if you truly have an Si engine harness and Si ecu, you shouldn't be having these issues. The car should start up fine, if everything is installed correctly when using the Si distributor (ground wires are grounded, plugs are fully clipped in, etc). I'm going to guess that your engine harness isn't Si spec or somthing along those lines.
Can you put your Si ecu back in along with the Si distributor, get the CEL to come back on and and find out what CEL codes you're getting are?
here's a how-to on checking the CEL light codes:
http://technet.ff-squad.com/how-to/celcheck/
Old 10-26-2008, 01:17 AM
  #115
jdmteg11sec's Avatar
ok guys need some quick help, iam looking into putting my 94 integra b18b non vtec engine into my buddies 96 non vtec civic hatch, i havent seena nything pertaining to a non vtec swaps what will i need to do wiring wise also i have every thing from integtra to use all mounts axle, shift linkage anything else mounting wise yo guys know i need, i really want to know about the wiring for both being non vtec, is there even any wiring involve? or is it pnp like if i was dropping in the b18b into a 92-95, let me know guys, thanks
Old 10-30-2008, 05:55 AM
  #116
LA_HONDAS's Avatar
for the EF guys
b-series axles will fit the si,ex,dx std hubs but not the hf hubs
Old 10-30-2008, 09:14 PM
  #117
Sl0wEK's Avatar
Default Re: (LA_HONDAS)
I have a 99 civic ex and just put in a LS swap (reused my engine harness). The dizzy plug is different. I read this post and it turned out that I have to convert it back to the older style "big plug." Is there a write up of how to do this?
Old 10-30-2008, 09:40 PM
  #118
LA_HONDAS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
i wish i knew that 2 months ago
Old 10-31-2008, 04:14 PM
  #119
Katman's Avatar
Default Re: (jdmteg11sec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmteg11sec &raquo;</TD></TR><TR><TD CLASS="quote">ok guys need some quick help, iam looking into putting my 94 integra b18b non vtec engine into my buddies 96 non vtec civic hatch, i havent seena nything pertaining to a non vtec swaps what will i need to do wiring wise also i have every thing from integtra to use all mounts axle, shift linkage anything else mounting wise yo guys know i need, i really want to know about the wiring for both being non vtec, is there even any wiring involve? or is it pnp like if i was dropping in the b18b into a 92-95, let me know guys, thanks </TD></TR></TABLE>
it would be the same overal installation procedures as a VTEC engine swap minus the VTEC and knock sensor wiring.
Old 11-16-2008, 01:17 PM
  #120
Dualcampro's Avatar
hi katman
i have a problem. my wiring harness is an OBD2b harness out of an 99-00 Honda civic. Everything is plugging up execpt for the dizzy. the harness is an 8 pin while the dizzy is an 10 pin. Do you have any idea how to rewire it so i can use my 8 pin harness to the 10 pin dizzy
Thanks
Ian
Old 11-20-2008, 11:14 PM
  #121
Katman's Avatar
Originally Posted by Dualcampro
hi katman
Thanks
Ian
Ok, OBD2b civics use a smaller OBD1 style dizzy plug. You need to switch over to the bigger OBD2a D-series / OBD2 B-series style dizzy plug.
when you swap over to the bigger OBD2a dizzy plug, just color match the wires to their respective pin locations.
You can also use this diagram as reference:
Old 11-21-2008, 07:21 AM
  #122
LA_HONDAS's Avatar
Originally Posted by Katman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Column &raquo;</TD></TR><TR><TD CLASS="quote">Hello, Im brand new here(first post). Kat... wow man, just wow!! Quick question for you. Or any other gurus...
I have a 00 Civic Hatch. My son blew the engine(n00b). I have a 96-97 EX motor/ecu.
Will the wiring for this work at all?
If so, I know I have to do the 3-wire to 2-wire IACV and the VTEC wiring. Would there be anything else?
If not, what would you suggest? Appreciate your help.</TD></TR></TABLE>
welcome..
You'll have to reuse your 00 engine harness on the 96-97 (OBD2a) EX D16Y8 engine. If the 96-97 Y8 engine comes with an engine harness, you will have to swap the dizzy plug over to your 00 harness. 99-00 civics use a smaller dizzy plug.
To use the OBD2a EX ecu, you'll need to purchase an OBD2b-OBD2a ecu jumper harness adapter (which i sell ).
hth
not true
i have a 2000 ex and it have the big dizzy plug on it
Old 11-24-2008, 12:11 AM
  #123
Katman's Avatar
Originally Posted by LA_HONDAS
not true
does it now?
and this is a totally stock 00 EX that hasn't been tampered with? no motor swaps, etc?
Old 11-24-2008, 10:58 AM
  #124
LA_HONDAS's Avatar
no it was not tampered with
it have the stock motor in it
Old 11-24-2008, 12:09 PM
  #125
Katman's Avatar
you SURE it's a 2000 ??
Quick Reply: * * OBD1 B-series engine into OBD2a/OBD2b civic/integra * *
