Motor rebuild kit(dohc zc)
I am looking for a zc (dohc) rebuild kit. Does anyone know were i can find one. I just bought a zc dohc with 250,000 miles on it. It burns oil cause the rins a alomst gone.
Re: Motor rebuild kit(dohc zc)
just make your own rebuild kit. here's what you need:
91 civic si:d16a6
oil pan gasket
piston rings
rod bearings
main bearings
oil pump pickup o-ring
rear main seal
front crank seal
water pump
thermostat
timing belt tensioner
lower rad hose
89 integra:d16a1
head gasket
valve cover gasket
spark plug tube seals
intake gasket
exhaust gasket
plug wires
distributor cap and rotor
cam seals
88 prelude:
timing belt
84 accord:
upper rad hose
you probably wont need all these parts, but while you have it apart, why not? good luck
91 civic si:d16a6
oil pan gasket
piston rings
rod bearings
main bearings
rear main seal
front crank seal
water pump
thermostat
lower rad hose
89 integra:d16a1
head gasket
valve cover gasket
intake gasket
exhaust gasket
plug wires
cam seals
88 prelude:
timing belt
84 accord:
upper rad hose
this should have everything you need to know. its quite thorough
http://www.d-series.org/forums/showthread.php?t=91053
Ken99287
03-21-2011 03:05 AM
pyro_freak8
50
01-03-2004 07:43 PM
