> Paint and Body
Old 04-27-2007, 12:05 PM   #51
harmonator84
harmonator84's Avatar
Default Re: (harmonator)
Originally Posted by -NA-aLL-thE-wAy-
their?
<Ownz PG3
Man your all over those!
88 Crx Dx- Sold
89 Crx Hf- Rip (parts car)
90 Crx Si- Current
91 Crx Si- Current
Myspace
harmonator84 is offline Report Post   Reply With Quote
Old 04-27-2007, 06:11 PM   #52
91ed9
91ed9's Avatar
Send a message via AIM to 91ed9
hey harm, i knwo you check this thread more than anythign else
how long should i wait till i compound/polish
i knwo wax i have to wait atleast a month
91crx si- junked 91crx dx-Sold!
2006 Audi A4 Tein coilovers,Custom FMIC Apr stage 2 software, 2.5" testpipe, 3" custom single exhaust, South Bend stage 2 clutch, 16lb lightwieght flywheel
91ed9 is offline Report Post   Reply With Quote
Old 04-27-2007, 06:34 PM   #53
harmonator84
Default Re: (91ed9)
It all depends on the paint. Different paint takes different times. Some you can do right away..some you have to wait till it hardens alittle..
I know you used rustoleam and its not going to tell you how long...hmm, let me think about that..I will get back to you.
88 Crx Dx- Sold
90 Crx Si- Current
91 Crx Si- Current
Myspace
Old 04-27-2007, 06:51 PM   #54
91ed9
91ed9's Avatar
i knwo people have done it like right after they wetsanded but i want this paint job to be the best it can be you knwo!
thanks once again
HARMONATOR FOR PAINT AND BODY MOD!!!
Old 04-28-2007, 07:11 PM   #55
eda6
eda6's Avatar
Default Re: (SjCiViCHB)
thanks for taking time to post this write up.
i think you should touch on "how to remove moisture from your pneumatic setup" and "how to properly do an atomization test".
tip-for the people using 1/4" hose and 1/4" fittings, replace the hose and fittings with 3/8". hvlp stands for high volume low pressure. by increasing the size of the fittings you'll get more air volume and the paint will atomize better.
another tip-always set air pressure at the gun with the trigger pulled. meaning install a gage right before the gun, adjust air pressure at the wall mounted reg, and finally remove gage from the gun. This helps compensate for the pressure drop through your hose.
question-what should be used to apply rubbing compound and glaze before buffing?
Modified by eda6 at 11:29 PM 4/28/2007
eda6 is offline Report Post   Reply With Quote
Old 04-29-2007, 04:32 PM   #56
95slomocivi
95slomocivi's Avatar
Send a message via AIM to 95slomocivi
What about the trim around the windows and the roof ? how do you change that ?
Mines dried up and curling up around my front windows causing water to leak in.
good write up.
Originally Posted by d357r0y
I'm not a real sissy, I just play one in every day life.
95slomocivi is offline Report Post   Reply With Quote
Old 04-30-2007, 11:48 AM   #57
hondaZvic
1999 Honda Civic
My Garage
hondaZvic's Avatar
Send a message via AIM to hondaZvic
Default Re: Everything you need to know about Autobody repair. (abnaasefmb)
Excellent write up harmonator!!!!
i took 2 years at a technical school also.. that was like a review in a nut-shell sorta... (a big nut-shell, but review none the less)
MY COUPE | MY HATCH
hondaZvic is offline Report Post   Reply With Quote
Old 04-30-2007, 12:21 PM   #58
harmonator84
Default Re: Everything you need to know about Autobody repair. (hondaZvic)
good write up.
The weatherstriping will do that over time. It just pops out....some are harder to get out then others but they just pop out.
Thanks man. Yea I used some of my notes that I took back from class. Where did you go to school at?
88 Crx Dx- Sold
90 Crx Si- Current
91 Crx Si- Current
Myspace
Old 04-30-2007, 06:13 PM   #59
hondaboy4life
hondaboy4life's Avatar
Send a message via AIM to hondaboy4life
Default Re: Everything you need to know about Autobody repair. (harmonator)
harmonator, you should, if you have time, add all the usefull posts peopel make or any additional ones you do to the first page to keep it organized.
hondaboy4life is offline Report Post   Reply With Quote
Old 04-30-2007, 07:41 PM   #60
SoCal EJ1
SoCal EJ1's Avatar
Default Re: (95slomocivi)
good write up.
Depends which model. For the EG/EJ models, the sides of the front just pop out. The top can be cut out but can't be replaced properly without pulling the window. Same goes for the back and rear quarters, althought I know of a few people who have managed to tuck the rear quarters into place with a lot of time and patience on hatchs. Hope that helps.
SoCal EJ1 is offline Report Post   Reply With Quote
Old 05-01-2007, 06:52 AM   #61
WhatThaFrig
Default Re: (SoCal EJ1)
Great write up.
While the wicked stand confounded
Call me with the Saints surrounded.
"Give a man a gun and he is a hero. Give him two and he is a God!"
WhatThaFrig is offline Report Post   Reply With Quote
Old 05-01-2007, 01:01 PM   #62
hondaZvic
1999 Honda Civic
My Garage
hondaZvic's Avatar
South Plains JR. college in Tx. ever heard of it?
MY COUPE | MY HATCH
Old 05-01-2007, 02:48 PM   #63
95slomocivi
thanks for the info. I'm gonna try to replace mine , now I have a better idea on how to start.
Old 05-01-2007, 09:34 PM   #64
harmonator84
Originally Posted by WhatThaFrig
Great write up.
Thanks
Nope
88 Crx Dx- Sold
90 Crx Si- Current
91 Crx Si- Current
Myspace
Old 05-01-2007, 10:48 PM   #65
sic944t
sic944t's Avatar
this is a great job as all have said learned alot and at a crucial time ... my question is should you allways spray a self etching primer over raw metal and then if you have a nasty surface where a high build primer is needed then should you just spray that over the self etching
you still have them connectors ?
the gods of vtec need them to thrive
sic944t is offline Report Post   Reply With Quote
Old 05-01-2007, 10:53 PM   #66
sic944t
sic944t's Avatar
Default Re: (sic944t)
wait your name is matt is it matt harmon if so did you ever live in auburn indiana or a surrounding area and if yes hahah we went to school together
Old 05-01-2007, 11:03 PM   #67
hondaZvic
1999 Honda Civic
My Garage
hondaZvic's Avatar
Nope
didnt think soo.. lol.. where'd u attend?
MY COUPE | MY HATCH
Old 05-02-2007, 05:18 AM   #68
harmonator84
Default Re: (hondaZvic)
Big Sandy Community and Technical College....
Nothing big at all. Just the teacher knew his stuff
88 Crx Dx- Sold
90 Crx Si- Current
91 Crx Si- Current
Myspace
Old 05-02-2007, 05:51 PM   #69
VAAJ
VAAJ's Avatar
Send a message via ICQ to VAAJ Send a message via AIM to VAAJ
didn't finish reading the entire post, but I enjoy reading it so far.
WAR HARMONATOR!
VAAJ is offline Report Post   Reply With Quote
Old 05-02-2007, 06:23 PM   #70
91ed9
91ed9's Avatar
Default Re: (VAAJ)
APPLYING BASECOAT/CLEARCOAT
More and more Vehicles have basecoat/ clearcoat finishes, it is very important to become fmailiar with them. You must first spray the color basecoat over the repair area.
fix it ! jsut looking out
haha re reading everythign again
Old 05-03-2007, 06:01 PM   #71
sic944t
sic944t's Avatar
Default Re: (91ed9)
HARMONATOR
wait is your name is matt is it matt harmon if so did you ever live in auburn indiana or a surrounding area and if yes hahah we went to school together
Old 05-04-2007, 07:18 AM   #72
harmonator84
Originally Posted by sic944t
HARMONATOR
actually my name is matt...but i have never been to auburn indiana sorry...strange
88 Crx Dx- Sold
90 Crx Si- Current
91 Crx Si- Current
Myspace
Old 05-04-2007, 08:49 AM   #73
sic944t
sic944t's Avatar
it would be a strange coincidence
anyways i dont know if you answered this but i have bare metal, filler, and old paint all showing so should i use self etching primer then go over that with a high build primer and do my sanding trying not sand through the self etching primer so as too keep the raw metal in prime ?
Old 05-04-2007, 11:49 PM   #74
Slo_D16
Slo_D16's Avatar
What about seam sealers and the different kinds and when to use them? Anybody have any info on this?
Slo_D16 is offline Report Post   Reply With Quote
Old 05-05-2007, 01:44 PM   #75
dem0nk1d
dem0nk1d's Avatar
Send a message via AIM to dem0nk1d
Good idea, is maybe showing pictures on how to use seam sealer on maybe a door skin. And how to replace it
95 EG Civic (R.i.P T-Boned)
89 EF Sedan (Current Project)
"keep a full interior and still be fast!!!! leave the stripped interiors to the real racecars!!!!" -sikefcrx89
"don't be a ricer! keep your bumper support kids, it might save your life." -dem0nk1d
dem0nk1d is offline Report Post   Reply With Quote
Bookmarks
auto, body, bodyman, checklist, college, honda, island, long, paint, printable, repair, repairer, shop, shrinkage, work
