#51 | |||||
http://images.honda-tech.com/set1/smile/emthdown.gif ... |
#52 | |
I checked my ring gap so now I just have to put them on the pistons. I'm tired though.
♥LSVTEC build♥ "At last we will reveal ourselves to the Jedi. At last we will have revenge..." |
#53 |
for the buildup...Good work, the progress is looking good. GOod luck with the rest.
DC Squad Member # 0405 NahLeDGE [b]"Pain is weakness leaving the body"[b] ALL-STAR CREW http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif[b]**FS: AUDIO EQUIPMENT/PANEL/ HEAD UNITS/ INTAKES/ ETC/**[b]http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif http://www.hondamarketplace.co...68098 |
#54 |
1993 Honda CivicJoin Date: Oct 2006
nice build, might starting very similar project soon w/ 93 ls
#55 |
very nice, subscribing. What compression is this set up going to net you at? with the p30 pistons and b16 head?
Modified by SiB16A at 10:58 AM 4/7/2007 |
#56 | |
I believe I'll be somewhere around 12:1. I could be wrong.
#57 |
Beacuse im doing the same set up except, i am using a gsr head, but i was told that i would bet net at 11:8 and others say 12:4. I would rather have 11:8, so i need to find out quick..
#58 |
awesome build
#59 |
I was looking at this compression calculator.
http://www.zealautowerks.com/ Don't know how accurate it is though. Thanks for taking the time to check out the build and for all the kind words fellas.
#60 |
I was installing my pistons and ended up bending one of the bottom oil rings pretty bad. What should I do? I dont want to compromise my build, but I dont want to have to buy a whole new set of rings just for 1 ring. Any advice please?
Thanks -Craig
#61 |
wow awesome build i'm in for more. good to see a DA resurrected
1996 Honda Civic SI Teknotik.com JDMrides.ca My Build Thread: http://honda-tech.com/zerothread/2133437 |
#62 |
damn man looks like a good build up!
BOOM BAZOOKA JOE Turbo GPW s2000 csmotorsports.net "we build porsche's" |
#63 | ||
Thanks, holmes! Quote:
Well guys, I bent up an oil ring while I was installing the pistons soooooooo...I have to call Hastings tomorrow to see if I can buy one separately. Very very discouraging.
#64 |
Anyways, Full Race sent the dowel pins that were M.I.A. They also threw in a couple more stickers...not that I have anywhere to stick them.
![]() I installed the rings on the pistons. Ironing boards rule. ![]() All the pistons with rings ![]() I've got 2 pistons installed and the other 2 will have to wait until my 2 replacement oil rings come in. Thats right, the piston ring body count has now risen to 2. Good thing I foresaw this and bought 4 extras. Hahah.
#65 |
I now have 3 of my pistons in after getting my replacement oil rings in. Out of the corner of my eye, I saw that something was going on with the 2nd compression ring. I looked closer and that bitch was split (circumference-wise). So I called Hastings directly even though I got the rings from K-Teller and one of the engineers hopped on the phone. Dawn was agreed that this was a defect. She was VERY nice and got me all hooked up. So I should have the last piston installed next week. Damn. So much drama for some pistons.
#66 |
bumpp
D series parts http://www.hondamarketplace.co...05351 |
#67 |
curious what your mechanical background is, were did you learn from?
and it looks excellent so far
#68 | |
I have NO mechanical background whatsoever. Most of what I've learned has been from Honda Tech, friends, Haynes manual, Helms manual, and other sources on the internet. Such being the case, my dad thinks I'm crazy for trying to build an engine. But I figured that I'm a fairly intelligent person, I have a daily driver, I have plenty of time and space, and I've got the balls to try anything at least once.Thanks for checking out my build.
#69 |
great thread.
nothing better than hondas and star wars |
#70 |
Just got back from Florida (for work) and saw that my new compression ring came in. I was wanting to put it all together this weekend but I'm not allowed on my house since my girlfriend is throwing a damn baby shower at our place. Girls FTMFL.
#71 |
looking good on the build hope to see the finished resaults
#72 |
nice build bro this DA looks clean...how much has this build ran you sof ar...im thinkin of goin lsvtec with my si
#73 | |
#74 |
Finally got the pistons installed. It's been a long journey... 2 bent oil rings and 1 defective compression ring, but theyre finally in. ![]() ![]() Also started cleaning the carbon out of the combustion chambers ![]() ![]() Eww. ![]() I'll post pics after I hit it a few more times and get it all wiped down. Can anybody confirm the placement of the breather box? I pulled it off of my old block and I've marked the picture for where I believe it goes. I ask because I know that the 96+ LS blocks didnt have the box and I got confused as to which block I have. ![]() ![]() From what I can tell, the hose goes from the breather to the nozzle near the deck and the bottom fitting of the box fits perfectly in that vacant hole. Any advice is appreciated. Thanks- Craig
#75 |
Looking good man.
00 Sliver LS |
| Bookmarks |
| Tags |
| 667, bolts, build, da, hastings, installing, ls, lsvtec, make, p30, piston, pistons, rings, rod, swap, vtec |
