#1 | |||||
#2 |
setting the motor in for mount placement.
#3 |
#4 |
#5 |
Sweet!! got my new clutch and the new dizzy.
![]() did more work on the mounts did all the weld and got some seal stuff. ![]() ![]() ill post more later its getting late. i know there big pics but i dont know how to resize but you can see more detail. |
#6 |
WOW!! Thats different.. How did you do the wiring and fuel set up?
"Money talks bullshit walks" '89 STD Hatchback b16- sold '89 SI Hatchback Sohc ZC/ b16- sold '88 LX auto "goldfinger" - Donated http://images.honda-tech.com/set1/smile/emsmile.gif '89 DX Hatchback B18b BAR-ed- Current love http://images.honda-tech.com/set1/smile/embeer.gif |
#7 |
ok, so two posts?
Anyway, are you using a flux core welder? Aside from that, looks like a fun project.
I have no signature. |
#8 |
yes its flux core and never had a prob with it the gas was out on my brothers welder and i have a time limit the welds are fine they are as strong as enything mig will do just gatta work a lill more lol.
the wiring ( 90 civic hatch all was ran then pined to the stock dash for the 80 cvcc very easy stuff fuel pump is off the 89 integra same Psi as the 92-95 civic axles are cut - resplined at a shop in portland OR, dont have them back yet this weekend doing the last of the wiring. ![]() ![]() the VSS for the swap is in the stock cvcc cluster. ![]() ![]() ![]()
#9 |
![]() ![]() ![]() ![]() ![]() im still looking for some Honda rotas that are 14" gatta go with 14s thats as big it will let me go on the car it had 12" stock
#10 |
15" will fit. I have 15" Mugen copy-cats on my '83 S.
Car looks good! |
#11 |
Looks good. Do you have any pics of the rest of the car?
#12 |
badass
PSN: yurpindude FS: First gen RSX Type S wheels w/tires. Local NJ Tristate area. http://www.hondamarketplace.co...72139 |
#13 |
This is all i have for the out side of civic ill do more pics of every thing befor paint and after. its going in for paint as soon as i finish the wiring for the dash should be sunday will be done with wiring its ganna be white stock color i wanna make it look stock but with a better c-v-cc motor the trac-bars are i gatta weld up still and put in the stiffer springs.
![]() ![]() here is the under-car pic i can still lower the car 1/12 to fit the wheels and looks.
#14 |
looks good but i would think about gusseting those mounts. Glad to finally see someone building one of these.
--Vinyl Graphics-- -Die cuts - Banners - Magnetics - Vehicle lettering - Business lettering - Silk Screening http://www.yagerdsigns.com Mention HT and get 10% off |
#15 | |
wow that is gona be one fun little ride!
O this is an ovary. put this in your signature if you know some stupid bitch that needs her's punched-- straight shot, right to the babymaker Quote:
#16 |
2005 silverstone S2000 |
#17 |
im sure the mounts are ganna hold up to alot with out gussets lol i hit them to try and adjust with a 2 1/2 lbs hammer and they will not move at all there stout as hell lol i reinforced the sheet metal around the mounts and did a notch in the frame on the trans mount. i also have the solid polyurethane mounts. but thank you for the help.
#18 |
How are you using the 89 Integra fuel pump?
My '83 S uses an inline fuel pump; I'm sure your '80 uses the same style. Is the '89 Integra pump an inline? If not, how are you going to mount it into the gas tank? |
#19 |
Alright then, you got it.
#20 |
the 86-89 acura integra has the fuel pump out of the tank driver side under car and has the psi like the 90+ integra it will work the best for the Vtec this is what i use on the 84 civic w/ d16 SI swap worked great!
#21 |
Cool man, you got it all figured out.
If I can ever finish these projects I'm working on, I'll throw a B series into my '83. |
#22 |
Nice man im in for some more progress and some vids!!!
#23 |
Nice project, I love old school honda's. I have a question, where is the alternator at I didn't see it in the pictures? It clears the frame?
<U>Destroy everything,obliterate what makes us weak</U> Give them nothing, but take everything. |
#24 |
nice project, it will be a lot of fun when finished.
#25 |
sorry i forgot to post that the alt. is in the front i didn't want to bash the crap out of the frame so i made a bracket and extended the wires.
| Bookmarks |
| Tags |
| 1980, 1992, accord, b16a, b18, civic, cvcc, gas, honda, motor, mount, placement, smell, swap, vtec |
