> All Motor
Old 03-08-2007, 02:51 PM   #1
EG hunter
EG hunter's Avatar
Default LS Vtec need help!!!
I have golden eagle ls vtec kits and trying to tap the hole on the head, I need to know that is that any special tool to tap the tread on that hole? Could any one show me how to plug it? some picture will be appreciated.
Right car for the right person......
EG hunter is offline Report Post   Reply With Quote
Old 03-08-2007, 05:07 PM   #2
CRXsmoke
CRXsmoke's Avatar
Default Re: LS Vtec need help!!! (13s del sol)
to plug the internal oil line on the vtec head you need a 1/8 npt plug (comes with golden eagle kit) and youll need a drill bit and a tap and dye kit. The drill bit widens the hole, then you will use the tap and dye to make your new threads in that hole.
be careful not to drill too far into your head b/c there is a water line behind that hole. and you dont want oil and water mixing when you start up the motor. I recommend using a drill press
_/ - http://www.hondamarketplace.com/show...light=crxsmoke
<u> PM me if interested in anything!</u>
_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
CRXsmoke is offline Report Post   Reply With Quote
Old 03-08-2007, 05:32 PM   #3
del_slow420
del_slow420's Avatar
Send a message via AIM to del_slow420
Default Re: LS Vtec need help!!! (CRXsmoke)
uh dont drill it just use the tap and tap it u can get it started and if u dont have a tap and die set u can just put a small socket on it and just go pretty much all they way in with the tap.. they just put the plug in and i used lock tight on mine but u dont have to just make sure its tight and sits a little in the head u dont want it to be flush or just under cause it will mess up your head gasket
1995 del sol vtec not stock b20vtec, numbers coming soon..gone
1995 del sol vtec boosted lsvtec comin soon to the streets near you
vouches: 2000Ek, 95dxb18c1, hondaboy4life, JDMisGOOD, jimmhatch, pittbullracer, pr3d, sicegcivic, srt42004n, swoyEKr, SyDuck,
aim wildmonkeys420
del_slow420 is offline Report Post   Reply With Quote
Old 03-08-2007, 08:27 PM   #4
EG hunter
EG hunter's Avatar
Thanks you for your help, but my problems is do you need a special tools to turn the 1/8npt tap? Is that any special way to do it? Because i tried to tap the tread on the hole but it didn't come out right, i mean no treads showing up.....do i need to send it to machine shop?
Old 03-09-2007, 07:29 AM   #5
zCivic
zCivic's Avatar
The correct tap comes with the golden eagle kit if new. I always used a 1/4'' socket wrench and socket on the tap itself. Just tap it deep enough so the tap bottoms out. The plug needs to be below the head surface or you will need to have the head milled.
02 Subaru WRX
91 CRX DX 84.5mm ls-vtec (back on Jack Stands over a year now)
91 CRX SI (Pending Sale)
zCivic is offline Report Post   Reply With Quote
Old 03-15-2007, 01:21 PM   #6
not_an_fnwerkz_Fan
not_an_fnwerkz_Fan's Avatar
Send a message via ICQ to not_an_fnwerkz_Fan Send a message via AIM to not_an_fnwerkz_Fan
Default Re: LS Vtec need help!!! (zCivic)
if u have trouble dont go 2 FNWERKZ he Sucks
not_an_fnwerkz_Fan is offline Report Post   Reply With Quote
Old 03-16-2007, 08:22 AM   #7
EG hunter
EG hunter's Avatar
Default Re: LS Vtec need help!!! (not_an_fnwerkz_Fan)
i appreciate you information, thanks
Old 04-06-2007, 10:02 PM   #8
Siknezzx661
Siknezzx661's Avatar
Sorry to take this thread away. but to this guy, why don't you run your motor not your mouth...
Team Siknezz 661
LSV - All Motor street Car - UNTUNED : 12.30@110mph (LACR)
FNWERKZ BUILT http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif
John @M&H http://images.honda-tech.com/set1/smile/emthup.gif
Chris @ Whitfield Racing http://images.honda-tech.com/set1/smile/emthup.gif
Representin' TEAM SIKNEZZ 805/408/661
Siknezzx661 is offline Report Post   Reply With Quote
Old 04-07-2007, 12:02 AM   #9
siknezz4
siknezz4's Avatar
Congrats team siknezz661, keep it up dawg!
all motor 12 sec 4dr fnwerkz built, stock block 1.8 gsr daily driver...
siknezz4 is offline Report Post   Reply With Quote
Bookmarks
drill, head, tap, vtec
