> All Motor
Old 03-08-2007, 05:41 AM   #1
hatchy69
hatchy69's Avatar
Send a message via AIM to hatchy69
Default Quick ls/vtec question
i have a b18b swap in my eh2, i was planing to get more power and do lsvtec but im not 100% sure about it still im still thinking about it anyways heres my question, all i need to build a lsvtec is the golden eagle lsvtec kit that comes with the head gasket,arp studs and bolts, the line for the oil etc, vtec head with distributer, b16 or gsr oil pan,water pump and timming belt rite? sum1 correct me if im wrong. my other question is what ecu do i use? thanks
EH Squad Member #85
THC
hatchy69 is offline Report Post   Reply With Quote
Old 03-08-2007, 05:51 AM   #2
D-Rob
D-Rob's Avatar
Send a message via AIM to D-Rob
Default Re: Quick ls/vtec question (hatchy69)
You can do everything you mentioned above, but if you limit it to that, you're asking for trouble.
The single most important piece to upgrade when building an LSVTEC is the rod bolts.
The ARP rod bolts eliminate the stretching habit the stock units have, and are the cheapest insurance for your engine out of all the other parts you'll be putting in.
They cost $35-$40, and they save LSVTEC's.
I recommend doing a search on your topic before making another thread to ask a question such as this.
Good luck.
- Derek
InnovativeMotorWorks
w w w . i n n o v a t i v e - m o t o r w o r k s . c o m
Cleaning Out Sale! --> http://www.hondamarketplace.com/show....php?t=2679505
D-Rob is offline Report Post   Reply With Quote
Old 03-08-2007, 09:05 AM   #3
99hondacura
99hondacura's Avatar
Location: down the street,bythe river in the van, co, united states
Send a message via AIM to 99hondacura
u use any vtec ecu
1997 #0260 theft recovery(project)
2004 JBP sti (daily driver)
1996 jdm rhd itR (project)
99hondacura is offline Report Post   Reply With Quote
Old 03-08-2007, 10:09 AM   #4
hatchy69
hatchy69's Avatar
Default Re: (99hondacura)
is it hard to install the rod bolts?
EH Squad Member #85
THC
Old 03-08-2007, 12:34 PM   #5
doood
doood's Avatar
Send a message via AIM to doood
Default Re: (hatchy69)
a machine shop should install them
Originally Posted by Bobismoi
Yes, the JDM 2.0L B18C5 is VERY rare. When I found it I had the complete front clip shipped over from Japan... just to make sure I would have all the little bits and pieces
orly?
POS civic krew #001
doood is offline Report Post   Reply With Quote
Old 03-08-2007, 04:04 PM   #6
mar778c
mar778c's Avatar
Also, be careful of how high you rev. Stock pr4 pistons do not have valve reliefs for a vtec head. If you are not careful, you could have some piston valve contact.
Good people:
Synapse Motorsports,JDogg,b18c1_powered _si,CHEETAH, 86si,NA_is_best, Astig, McNews Automotive, geardog, 4g hatch, Innovative Motorworks
mar778c is offline Report Post   Reply With Quote
Old 03-08-2007, 05:00 PM   #7
Suck my DX
Suck my DX's Avatar
Default Re: Quick ls/vtec question (mar778c)
why do you need to run a b16 or gsr oil pan? ive never heard of that
good parts for sale in SO CAL
http://www.hondamarketplace.com/show...6#post36857056
Suck my DX is offline Report Post   Reply With Quote
Old 03-08-2007, 05:03 PM   #8
doood
doood's Avatar
you only need a gsr oil pan if using the gsr girdle. otherwise the b16 and ls oil pans are the same.
orly?
POS civic krew #001
Old 03-08-2007, 05:05 PM   #9
Suck my DX
Suck my DX's Avatar
Default Re: Quick ls/vtec question (doood)
and what would be the advantage of using the gsr girdle
Old 03-08-2007, 05:08 PM   #10
doood
doood's Avatar
Default Re: Quick ls/vtec question (Suck my DX)
more stability at higher rpm's
orly?
POS civic krew #001
Old 03-08-2007, 05:09 PM   #11
Suck my DX
Suck my DX's Avatar
and why is that?
Old 03-08-2007, 05:46 PM   #12
doood
doood's Avatar
and why is that?
exactly what it sounds like
orly?
POS civic krew #001
Old 03-08-2007, 07:44 PM   #13
mar778c
mar778c's Avatar
and why is that?
The gridle increase rigidity at the 2, 3, and 4 main caps. This lowers the blocks vibration response amplitude at high rpms. Thus making the block more stable.
Good people:
Old 03-09-2007, 12:35 PM   #14
Suck my DX
Suck my DX's Avatar
thanks for the info...so how do you use a gsr girdle on an ls block without changing the mains? is it an extra piece or do you need gsr main caps and a line bore?
disregard if its a dumb question...im just curious
Bookmarks
