#126 | ||||||
<FONT SIZE="1"><FONT COLOR="green">VOUCH Thread</FONT></FONT> Dyno Apexi B16a 10psi Dyno Apexi B18b 10psi Dyno Apexi B18b 14psi <FONT COLOR="gold">Mugen 無限 Power</FONT> 235whp & 175tq @ 7psi 280whp & 205tq @ 10psi 300whp & 230tq @ 14psi |
#127 |
how hard was this on jack stands?
i <3 my honda |
#128 |
#129 |
well as you can see from the pics i only used 2 jackstands. would have been done in a couple hours but my buddy had grabbed the wrong ebrake cables (del sol ones)
#130 |
going back to the BB n MC thing.. i already have the DA fronts n started on the rear but the heads of the bolts in the lca on the disks broke n i kinda lost interest. since im running the DA fronts should i use the 4040 prop and get the DA BB n MC? and from what i understand, when u change the brake booster u have to take out the dash.. correct?
#131 |
#132 |
can the brake conversion be done using everything off a delso si?
4 doors- " thats how i roll" |
#133 |
Moderator
#134 |
can i use 95 civic si trailing arms with abs for my ef? or will the abs be a problem?
#135 |
i have the da rear disk conversion on my ef2 with a 13/16 master cylinder and brake booster but is using a 3030 valve...should i use the 4040 valve or just stay with the 3030...the rear disk conversion was already on the car when i bought it...!!!
BiG ChOr!Zo™
#136 |
wow thats a great write good job bro
#137 |
i have all the stock (DX) parts still on my crx, but when i drive my buddies sedan his braking power is a lot better. he has the swapped MC and 4040 prop valve. so i will soon be doing that too. i highly recommend it since i have been driving his car since my crx was stolen.
#138 |
#139 |
#140 |
1991 Honda CRX |
Hey, just read the whole write up. Just had a few questions. I'm getting a donor car tomorrow (a DA) that i'm gonna be getting the rear disc off to do this swap. Just curious though in this picture:
![]() It looks like you removes the lower control arm too. When I put it back, do I use the EF one, or the DA one? Also at one point in the thread, you said that your buddy grabbed the wrong E-Brake cables. Which ones do you need? Will the ones off a DA work? If not I need to know asap. Thanks. |
#141 |
1991 Honda CRX |
also, you said to change the prop valve.. will the one from the DA work? If yes, would it be better then the on on my DX crx?
#142 |
my buddy had grabbed del sol cables those do not work they are way too short for the hb. and yes the prop valve from a DA will work perfect. if you have a hb the DA cables will bolt up perfectly with out a problem, if you have a crx you will need the cables from a 91 crx si. otherwise your cables will drag on the ground.
#143 |
1991 Honda CRX |
Damn. I got a CRX.
what about the LCA? which one do I use? |
#144 |
you can use the one from your car, but i used all the parts that came form the donor car minus the top bar that connects to the frame.
#145 |
Would it be possible for you to make a master list of parts needed to complete this conversion? I'm about to do this on my car since I've been wanting the upgrade and my wheel bearings are going bad.
#146 |
so if u did the rear brake conversion on a ef..would u still use the same lcas? or if was to buy aftermarket lower control arms which ones would u buy...the ef?
You <3 My Honda 1990 SI BUILD <------------------------- |
#147 |
#148 | |
BiG ChOr!Zo™
#149 |
i have a 90 si and i want to know for sure wat i need to do the dc swap?
i have a wrecked 99 integra ls at my disposal but it has ABS. |
| Bookmarks |
| Tags |
| 97, arm, brake, cb750, conversion, disk, door, drum, hatch, honda, integra, rear, removing, swap, trailing, wobble |
