> Honda CRX / EF Civic
Old 03-09-2007, 06:15 AM   #26
Booz
Booz's Avatar
Default Re: (ComeOnKip)
Nice write up. This is something I've been wanting to do on my 89 crx using the discs off my 90. Very helpful indeed.
Booz is offline Report Post   Reply With Quote
Old 03-09-2007, 06:22 AM   #27
solbrothers
Soul Sisters
solbrothers's Avatar
Send a message via AIM to solbrothers
Default Re: REAR DISK BRAKE CONVERSION w/pics (crx_si-r)
dayum. subscribed. i think i'm gonna do this in a few weeks on my ef sedan
-Matt
Originally Posted by Arsenal View Post
Solbrother's has a lot of great points and has some great advice. Would listen to his advice.
solbrothers is offline Report Post   Reply With Quote
Old 03-09-2007, 09:21 PM   #28
bluelsvtecda9
bluelsvtecda9's Avatar
wats brake lines do u use the da or ef
bluelsvtecda9 is offline Report Post   Reply With Quote
Old 03-09-2007, 09:54 PM   #29
Crx Jimmy
Crx Jimmy's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (bluelsvtecda9)
either one will work, 90-91 crx si or 90-93 integra will both work fine
Crx Jimmy is offline Report Post   Reply With Quote
Old 03-10-2007, 08:35 AM   #30
Angry
Angry's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Crx Jimmy)
Are 88-89 and 90-91 compensator arms the same?
88HF...d15b7/d16y8 mini-me
88Si...Still working on that one...
89 CRX Si...194k...Retired
Angry is offline Report Post   Reply With Quote
Old 03-10-2007, 09:30 AM   #31
EatSleepJDM
EatSleepJDM's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Angry)
im putting 90 integra rear brakes on my 88 crx does everything bolt right up, trailing arm, and every other arm off of the trailing arm?
86X95 14.0:1 Ls/Vtec Exospeed, Six Sigma Racing, Tom Cote(Tbone)-for coating my pistons
EatSleepJDM is offline Report Post   Reply With Quote
Old 03-10-2007, 09:35 AM   #32
crx_si-r
crx_si-r's Avatar
Send a message via AIM to crx_si-r
Default Re: REAR DISK BRAKE CONVERSION w/pics (EatSleepJDM)
everything is a direct bolt on
crx_si-r is offline Report Post   Reply With Quote
Old 03-10-2007, 10:11 AM   #33
jackinthetrunk
jackinthetrunk's Avatar
Default Re: (ED9man)
Originally Posted by ED9man
I didn't have to touch the tank on my CRX, maybe the hatch is different.
EF SEDAN SQUAD #81
Originally Posted by Starscream View Post
Motorcycles are like drugs, they can give you a wonderful time, but also **** up your life. Are you ready for it?
jackinthetrunk is offline Report Post   Reply With Quote
Old 03-10-2007, 10:45 AM   #34
harmonator84
harmonator84's Avatar
Default Re: (jackinthetrunk)
Nice write up. I think this should go in the FAQ!
88 Crx Dx- Sold
89 Crx Hf- Rip (parts car)
90 Crx Si- Current
91 Crx Si- Current
Myspace
harmonator84 is offline Report Post   Reply With Quote
Old 03-10-2007, 11:21 AM   #35
Bejita
Bejita's Avatar
Send a message via AIM to Bejita
Your next project should be to change your tail lights.
Originally Posted by kdubek9
thinking maybe one of the vtech pistons are stuck and or missing.
http://images.honda-tech.com/set1/smile/emhammer.gif
Bejita is offline Report Post   Reply With Quote
Old 03-10-2007, 11:42 AM   #36
crx_si-r
crx_si-r's Avatar
Default Re: (Bejita)
um wat taillights if u read the post u would see that this was done 2 my friends car and that i tried to get him to change em.
Old 03-11-2007, 09:08 PM   #37
CW-ITR
CW-ITR's Avatar
So, did you swapped out the E-brake cables also or you re-used the E-brake cables?
Here is the H-T vouches:
http://www.hondamarketplace.co...76568
Here is the local vouch(Norcal):
http://hondamarketplace.com/zerothread?id=1876565
CW-ITR is offline Report Post   Reply With Quote
Old 03-11-2007, 10:07 PM   #38
superhatchbackbros
superhatchbackbros's Avatar
Send a message via AIM to superhatchbackbros
i just did a rear disk setup on my 89 dx hb using 91 crx si rear disks & swaybar, DA integra E-brake cables bc the crx ones are to short for a HB, Da integra 40/40 prop valve, brand new Crx Si master cylinder w/lifetime warranty from autozone, new oem rear rotors w/ ceramic pads, front brembo cross drilled /slotted rotors w/ ceramic pads, and Stainless steel Braided brake lines . and i can stop on a dime.. iv never been more happier
superhatchbackbros is offline Report Post   Reply With Quote
Old 03-11-2007, 10:52 PM   #39
Targa250R
be professional
Targa250R's Avatar
Why did you drop the fuel tank? That is totally unnecessary. You just created a lot more work for yourself.
Originally Posted by Super79Dave
Oh and you missed changing the proportioning valve. 4040
The 4040 is not the correct proportioning valve for a Civic with 7CLP13S rear calipers and the stock small unmarked front calipers for 9.5" discs. The correct proportioning valve for that setup is from a '92-95 Civic EH3 Si non-ABS.
The 4040 is used for 7CLP13S rears with 17CL14VN fronts.
Do not, I repeat, DO NOT use any arms from the Integra other than the trailing arm, or else you will have major wheel alignment problems. The trailing arm is the ONLY arm you can use from the Integra.
Originally Posted by CRX_CRAZY07
94 integra ls rear brakes work on a 91 crx done this same way?
Yes.
You can't reuse your cables. You have to use DA Integra cables (on a Civic) or '90-91 CRX Si cables (on a CRX). The fittings are different for drums vs. calipers.
1991 Civic | 1998 CB750 | 2001 Integra | 2005 Giant Trance 2 | 2009 Redline Conquest Pro
Targa250R is offline Report Post   Reply With Quote
Old 03-12-2007, 04:40 PM   #40
RMXmitch
RMXmitch's Avatar
Default Re: (CRX_CRAZY07)
Yo I got my rear disks off a 94 teg.. I am gonna be putting them on within the next few weeks.. From my search I found everything is gonna work, but I am gonna buy some 90-93 brake hoses. I will let you know how it works out when I am done.
RMXmitch is offline Report Post   Reply With Quote
Old 03-12-2007, 05:16 PM   #41
Tyson
Tyson's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Targa250R)
this is important enough that i need to ask for you to justify this.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 03-12-2007, 08:15 PM   #42
Targa250R
be professional
Targa250R's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Tyson)
I don't know if I even want to go there Why bother even changing the prop valve from stock at all if you're just going to put another wrong one on?
Old 03-12-2007, 11:43 PM   #43
Tyson
Tyson's Avatar
no really. please explain your logic.
im not questioning you. i will probably agree with you. i just want to know why you make such a statement.
Old 03-12-2007, 11:54 PM   #44
Targa250R
be professional
Targa250R's Avatar
Ask yourself this: Why would a 4040 be the correct proportioning valve for the D273/9.5" unmarked front calipers with 7CLP13S rears? A car with such a configuration was not given a 4040 valve. The only car that ever came stock with that configuration from Honda was the non-ABS EH3. 4040s were found on cars with 17CL14VN fronts and 7CLP13S rears.
You and I both know that trying to decipher the proportioning valves are a crapshoot anyway. I've just defaulted to recommending a valve from a car with the closest stock brake configuration to the intended hybrid setup (with some exceptions being made for '96-00 Civics).
Old 03-12-2007, 11:55 PM   #45
Tyson
Tyson's Avatar
so what valve does the eg civic have?
what MC?
Old 03-12-2007, 11:56 PM   #46
Targa250R
be professional
Targa250R's Avatar
Don't know, but I'd be interested to find out, so I could see if any other cars shared it. I haven't had an EH3 in the junkyard for over 2 years.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what MC?</TD></TR></TABLE>
13/16".
Old 03-13-2007, 12:07 AM   #47
Tyson
Tyson's Avatar
time to ask the EG forum i suppose...
care to do the honors?
Old 03-13-2007, 12:08 AM   #48
Targa250R
be professional
Targa250R's Avatar
I hate the EG forum. They only answer questions that deal with JDM road flares and carbon fiber center caps for Rota wheels. Good luck getting a technical answer
Old 03-13-2007, 04:40 AM   #49
GarageAlchemist
Guest
Posts: n/a
this is true, but we must forge ahead..
Old 03-13-2007, 07:43 AM   #50
garageEF
garageEF's Avatar
Send a message via AIM to garageEF
nice write up
very clear and good pics.
Originally Posted by RC_Benjamin
when does that hottie turn 16? i need a ride
garageEF is offline Report Post   Reply With Quote
Bookmarks
97, arm, brake, cb750, conversion, disk, door, drum, hatch, honda, integra, rear, removing, swap, trailing, wobble
