> Honda CRX / EF Civic
Old 03-08-2007, 12:41 AM   #1
crx_si-r
crx_si-r's Avatar
Send a message via AIM to crx_si-r
Default REAR DISK BRAKE CONVERSION w/pics
hey eveyone just this past weeken my buddy's rear brake shoes went out on his 91 hatchback so he was basically metal to metal on the shoes with the drums. i had been puttin off doin his rear disk conversion, mainly cuz i hate dealin with the stupid gas tank, LOL. but i finally gave in and decided to take some pics while in the proccess of doin it. takin pics made the swap take longer than i had hoped but oh well its for a good cause i hope u enjoy......
NO NEED TO DROP THE GAS TANK I DID ANOTHER BRAKE CONVERSION ON MY HATCH last week and i did not need to drop the tank.
well here we go.
here is wat his rear brakes looked like b4 i started workin on it....
[img]http://i6.photobucket.com/albums/y203/crx_SiR/rear%20brake%20conversion/01****edupbrakes.jpg[/img]
1. start out by removing the rear seats so u can access the fuel pump connector.
2. next remove the shifter/e-brake console, u should then see this....
i went ahead at this point and un hinged the e-brake cables from the handle so i wouldnt have to get back inside the car untill near the end.
3. remove the tires and raise the car on jacks.
4. drain the left over fuel, i would suggest use it up as much as possible before starting this. this is where the drain plug is located near the rear left corner of the fuel tank.....
5. after enough or all fuel has been drained u will then remove the fuel line cover...
6. next after removing the cover u will then have to disconnect a total of 5 fuel lines. 3 near the rear of the tank and 2 near the front by the filler neck....
6. after u have diconnected the fuel lines proceed to remove the gas tank enough so u can see the bolts that hold the brake cable to the chassis
7. after the tank has been moved go ahead and remove the following bolts i like to leave these 2 boltsf or last because they can hold up ur rear brakes while ur workin on the rest of the bolts....
8. now before u undo that last 2 bolts dont forget to remove the clip and unscrew the brake hose....
9. now after u remove the brake hose go ahead and remove the last 2 bolts....
10. now u have successfully removed ur rear brakes. now the only thing left is to do the whole proccess backwards. here is wat the final product should look like....
one thing i would also like to suggest is that u get some new hose clamps because i personally dont like the stock ones. but then again thats just me. after installin ur new brakes all u have to do is just bleed the system. wat du u guys think of my write up? i wasnt sure if it was already covered but i thought it would be informative to post.
yea i i kno i told my buddy to get rid of those lights. total time was about 4.5hrs until it was completely done bleeding included and takin pics along the way, cuz i got hungry. lol
Modified by crx_si-r at 10:30 PM 3/24/2007
crx_si-r is offline Report Post   Reply With Quote
Old 03-08-2007, 12:47 AM   #2
mat18
mat18's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (crx_si-r)
that was a great write up.
engine hoist for sale http://www.hondamarketplace.co...60699
mat18 is offline Report Post   Reply With Quote
Old 03-08-2007, 01:02 AM   #3
88 civic ef
88 civic ef's Avatar
Send a message via AIM to 88 civic ef
hey i was wondering. i have a 88 civic and if i do get rear disc brakes do i have to get new rear shocks???
-daily driven red 88 ed6
Stock Ls with bolt ons - E.T. : 14.612
http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
88 civic ef is offline Report Post   Reply With Quote
Old 03-08-2007, 01:59 AM   #4
Cheeech
Cheeech's Avatar
Send a message via AIM to Cheeech
Default Re: REAR DISK BRAKE CONVERSION w/pics (mat18)
Cheeech is offline Report Post   Reply With Quote
Old 03-08-2007, 07:37 AM   #5
crx_si-r
crx_si-r's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (88 civic ef)
no everything bolts right up. unless ur rear shocks are blown then i dont see y u would need to replace them. u should be fine.
Old 03-08-2007, 07:41 AM   #6
ED9man
ED9man's Avatar
Send a message via AIM to ED9man
I didn't have to touch the tank on my CRX, maybe the hatch is different.
ED9man is offline Report Post   Reply With Quote
Old 03-08-2007, 07:45 AM   #7
CRX Toad
Moderator
CRX Toad's Avatar
Great write up!
However there is no need to drop the tank at all. I have done several brake conversions on CRX's and hatch's it is not something that needs to be done. All bolts, and cables can be removed easily without dropping the tank.
Hondworks
Need a write up on how to fix your CRX cracked climate control, PM me
CRX Toad is offline Report Post   Reply With Quote
Old 03-08-2007, 07:48 AM   #8
65stang90crx
65stang90crx's Avatar
Send a message via AIM to 65stang90crx
Default Re: REAR DISK BRAKE CONVERSION w/pics (CRX Toad)
<--------Didnt drop tank for rear disc brake conversion.
1990 CRX DX D15b2, Greddy exhaust, skunk2 coilovers, koni yellows, rear disc conversion, flik racing rims 15" w/rt615 Azenis. Getting an LS!... Well getting closer http://images.honda-tech.com/set1/smile/emthup.gif
1965 Mustang 289, 302 heads and pistons with mild cam, Heddman headers, flowmaster dual exhaust, power front disc brake conversion
65stang90crx is offline Report Post   Reply With Quote
Old 03-08-2007, 08:01 AM   #9
FernEF
FernEF's Avatar
Send a message via AIM to FernEF
Default Re: REAR DISK BRAKE CONVERSION w/pics (65stang90crx)
rear disc or probley the easiest to do...does take time tho
Yup, I'm FernEF http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
THE OFFCIAL BUMPER DISTRBUTOR
BYB Back Yard Bumpers
98-01 dc integra front and rear bumpers FS
s2k front bumpers,EG,DA,EK.CB7,evoulotion,srt4 PM ME 4 DETAILS!
FernEF is offline Report Post   Reply With Quote
Old 03-08-2007, 08:07 AM   #10
Super79Dave
Super79Dave's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (FernEF)
Yep me too didn't have to drop the tank at all. No interference at all.
Just unbolt the drum trailing arm and bolt up the disc trailing arm.
Oh and you missed changing the proportioning valve. 4040
Super79Dave is offline Report Post   Reply With Quote
Old 03-08-2007, 08:10 AM   #11
crx_si-r
crx_si-r's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Super79Dave)
no i didnt miss it cuz he didnt have it. lol. how did u undo the e-brake cables without touching the tank? im gonna be doin the rear brakes on my hatch in couple of weeks. im curious cuz when i did my crx i had to move the tanks also.
Old 03-08-2007, 08:20 AM   #12
89efDUSTY
89efDUSTY's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Cheeech)
RIP CIAC
MASSIVE PARTOUT!!!! 56k http://www.hondamarketplace.com/show....php?t=2656420
89efDUSTY is offline Report Post   Reply With Quote
Old 03-08-2007, 08:27 AM   #13
CRX Toad
Moderator
CRX Toad's Avatar
The bolts in front of the tank can be taken out with a wrench. As the bolts approach there last thread they can be take out over the top of the lip on the tank. You will need your fingers to do this. It just saves a lot of hassle that is associated with dropping the tank.
The bolts then go back in the exact same way.
Hondworks
Old 03-08-2007, 08:42 AM   #14
92civicfreak
92civicfreak's Avatar
Send a message via AIM to 92civicfreak
why did u have to drop the tank?
92civicfreak is offline Report Post   Reply With Quote
Old 03-08-2007, 08:56 AM   #15
92civicfreak
i pulled like wholy hell
Old 03-08-2007, 08:25 PM   #16
CW-ITR
CW-ITR's Avatar
Can you or someone pleae corlaborate more on this please...
Here is the H-T vouches:
http://www.hondamarketplace.co...76568
Here is the local vouch(Norcal):
http://hondamarketplace.com/zerothread?id=1876565
CW-ITR is offline Report Post   Reply With Quote
Old 03-08-2007, 08:31 PM   #17
Crx Jimmy
Crx Jimmy's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (CW-ITR)
You definitely do not have to drop the tank. all bolts can be accessed with an open end wrench its tight but it can be done pretty easy. And you do not need the 40/40 valve to function properly. Im using the stock valve and prefer the bias compared to the 40/40 valve
Crx Jimmy is offline Report Post   Reply With Quote
Old 03-08-2007, 08:34 PM   #18
crx_si-r
crx_si-r's Avatar
Default Re: REAR DISK BRAKE CONVERSION w/pics (Crx Jimmy)
yea im runnin the stock prop valve. i dunno i just never thought of squeezing my hands in between there. but now i know. so it will make my conversion that much easier when i do my hatch. thanks for the help and helping me see things a bit clearer now.
Old 03-08-2007, 08:44 PM   #19
EL Vap133
Moderator
EL Vap133's Avatar
Send a message via AIM to EL Vap133
Default Re: (ED9man)
That's what I was going to say!
EL Vap133 is offline Report Post   Reply With Quote
Old 03-08-2007, 11:27 PM   #20
90goldhatch
90goldhatch's Avatar
Send a message via AIM to 90goldhatch
phat write up this should get put in faqs
90goldhatch is offline Report Post   Reply With Quote
Old 03-08-2007, 11:45 PM   #21
justseeingifitistaken
justseeingifitistaken's Avatar
Default Re: (xXLevoNXx)
BTW for the guy asking about the 88 struts...you will either have to replace them or find rear trailing arms that are the same setup for the struts with a bolt through and not the fork over. 90-91 CRXsi/Civic si trailing arms use that different mounting.
justseeingifitistaken is offline Report Post   Reply With Quote
Old 03-09-2007, 12:08 AM   #22
freakystyley_73
freakystyley_73's Avatar
Great write-up, i'm saving this for a possible future 5-lug conversion. A lot easier than i thought. Pictures are nice and pretty.
crooked as a hook now suck my thumb. anybody wanna come get some?
freakystyley_73 is offline Report Post   Reply With Quote
Old 03-09-2007, 01:25 AM   #23
Tyson
Tyson's Avatar
yeah i dont see the point of touching anything with the fuel lines or draining the tank.
but A for effort and clear pics with highlights to what youre talking about.
you also forgot to mention to tighten the bolts AT RIDE HEIGHT. which means jacking up the suspension so all the weight is on that corner before tightening all the suspension parts. it saves bushings.
and dont forget to get the wheels ALIGNED. it saves TIRES.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 03-09-2007, 04:31 AM   #24
CRX_CRAZY07
CRX_CRAZY07's Avatar
Send a message via AIM to CRX_CRAZY07
Default Re: (Tyson)
94 integra ls rear brakes work on a 91 crx done this same way?
1991 Honda Crx Getting a D15B As i speak
1991 Honda Civic PIECE OF SH*T
CRX_CRAZY07 is offline Report Post   Reply With Quote
Old 03-09-2007, 05:44 AM   #25
ComeOnKip
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
Send a message via AIM to ComeOnKip
NYET! use DA trailing arms and brakes. And also, i didn't have to touch my tank what so ever on my 91 sedan... as far as I'm concerned the only aligning I needed done afterwards was a rear toe setting..just my .02
on the nice write up tho.
We all knew what consequences could be with the crew we had at the controls, there's no harbor age for the USA-holes. I doubt there's a benign God to save our souls, cuz no one else is gonna save the USA-holes
ComeOnKip is offline Report Post   Reply With Quote
Bookmarks
97, arm, brake, cb750, conversion, disk, door, drum, hatch, honda, integra, rear, removing, swap, trailing, wobble
