> Honda CRX / EF Civic
Old 03-04-2007, 09:06 PM   #1
Tyson
Tyson's Avatar
Default How to pop off a balljoint. (Videos)
i replaced a wheel bearing this weekend. you need to take off the knuckle and in order to take off the knuckle you need to separate the 3 balljoints.
so i took a video.
i used my favorite method, 3lb sledge hammer. youll see how easy it is on a tie rod end. its the same with the lower and upper balljoint.
http://www.norcalcrx.org/tyson...1.wmv
then i got to use the official honda balljoint separater tool. it was easy too. i would prefer it over the hammer method, EXCEPT its kind of expensive. in all, i think its just easier to just have a 3lb hammer available to pop off a balljoint.
http://www.norcalcrx.org/tyson...2.wmv
feel free to host it on youtube or distribute wherever. i dont care.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 03-04-2007, 09:45 PM   #2
dr_latino999
Global Instigator
dr_latino999's Avatar
Send a message via AIM to dr_latino999
Default Re: How to pop off a balljoint. (Tyson)
Going to put some porn music on the videos and then hosting them Otherwise, this was just the information I was looking for my brake swap coming up.
One Step closer to finishing my short block: "Houston, 77mm CP's are in the sleeves, over."
Project D16 On Crack
dr_latino999 is offline Report Post   Reply With Quote
Old 03-04-2007, 10:06 PM   #3
Smokinsax
The Boot
Smokinsax's Avatar
Send a message via AIM to Smokinsax Send a message via MSN to Smokinsax
Default Re: How to pop off a balljoint. (dr_latino999)
yeah...same situation here except going to do the big four lug swap.
good info!
Sleeper ED9
#004 EFSFTMFW!
Smokinsax is offline Report Post   Reply With Quote
Old 03-04-2007, 10:19 PM   #4
ED9man
ED9man's Avatar
Send a message via AIM to ED9man
P/N for the honda tool?
ED9man is offline Report Post   Reply With Quote
Old 03-04-2007, 10:23 PM   #5
n3h3bkau
n3h3bkau's Avatar
Send a message via AIM to n3h3bkau
Here's my solution...
n3h3bkau is offline Report Post   Reply With Quote
Old 03-05-2007, 05:54 AM   #6
Fuster_Cluck
Fuster_Cluck's Avatar
Send a message via AIM to Fuster_Cluck
Great info / vids
Pelican 1624 containing: 2 Gripped Canon 50D's, XT, XTi & XSi ♥ 10-22mm ♥ (2) - 18-55mm ♥ (2) - 50mm f/1.8 ♥ 24-105mm f/4L IS ♥ 70-200mm f/2.8L IS
Fuster_Cluck is offline Report Post   Reply With Quote
Old 03-05-2007, 07:51 AM   #7
Ti Rider
Ti Rider's Avatar
Default Re: (Hybrid93Hatch)
Easiest method on the face of the Earth for popping the lower balljoint - http://www.honda-tech.com/zero...age=1. On an EF you don't even need the jack, just pull the control arm down and put the wrench in between the knuckle an arm. Requires no special tools, doesn't even touch the ball joint so it doesn't damage it all.
'89 Blade Silver CRX Si
Ti Rider is offline Report Post   Reply With Quote
Old 03-05-2007, 07:56 AM   #8
Tippyman
Tippyman's Avatar
Default Re: (Ti Rider)
That's what I do everytime. I use a 22 mm wrench I have laying around. Peice of cake.
I don't see why people ever have trouble with it.
-95 Miata DD
-91 Civic Turbo
Tippyman is offline Report Post   Reply With Quote
Old 03-05-2007, 08:15 AM   #9
wiZCo
Harnessing the Wind
wiZCo's Avatar
Great info. Subscribed!
XBL/PSN: DERS315
DPN: It's intelligible
Sláinte
wiZCo is offline Report Post   Reply With Quote
Old 03-05-2007, 08:24 AM   #10
rarejdmkid
rarejdmkid's Avatar
Send a message via AIM to rarejdmkid
good info!
rarejdmkid is offline Report Post   Reply With Quote
Old 03-05-2007, 09:39 AM   #11
Jonathan_ED3
Jonathan_ED3's Avatar
Send a message via AIM to Jonathan_ED3
The sledgehammer method doesn't work too well for the lower ball joint. At least it never has for me. There's too many things in the way, space is too tight. There's no good angle to strike it from.
Now I've seen guys with lifts in the shop use the hammer method, but they're able to stand up and get a good angle and take good swings.
On the ground in my driveway, it's never worked.
I use the ball joint seperator (pitman arm puller, not pickle-fork) almost all of the time as a result.
Great videos Tyson!
Modified by Jonathan_ED3 at 11:27 PM 3/5/2007
My Vouch Thread
'93 Civic DX Coupe 40mpg
Jonathan_ED3 is offline Report Post   Reply With Quote
Old 03-05-2007, 10:50 AM   #12
94eg!
94eg!'s Avatar
If it's so great, then please explain how you would you get the entire knuckle off with that method? It only works on the LOWER ball-joint.
Originally Posted by gabebauman
Screws are useless.
94eg! is offline Report Post   Reply With Quote
Old 03-05-2007, 11:08 AM   #13
fireant
fireant's Avatar
Default Re: (94eg!)
Good videos and good thread idea, I've got two more ways to try that wont hurt the boot:
1.) Use a "Pittman arm puller" from an autoparts store. Mine was $7.99, works great. Some places might loan them out too.
And if a puller is not available:
2.) Take off the castle nut, turn it over and screw it back on a little ways to where its flat edge is even with the flat base of the stud. Whack it upwards with the hammer from below, using a piece of wood to cushion the nut and stud from being damaged.
2000 civic hatchback hypermiler
1991 CRX Si track toy
95 Ford Ranger 3.0 mule
fireant is offline Report Post   Reply With Quote
Old 03-05-2007, 09:29 PM   #14
Jonathan_ED3
fireant,
I've found that even with the pitman arm puller, it's best for me to turn the castle nut upside down and thread it back onto the joint.
In my experience it seems to preserve the threads better than leaving it right-side-up.
Have you had similar results?
My Vouch Thread
Old 03-06-2007, 04:44 AM   #15
civictrix
civictrix's Avatar
Send a message via AIM to civictrix
Default removing castle nut
good vids, and great info. Now what about when u try to take the castle nut off and the whole ball joint just spins
civictrix is offline Report Post   Reply With Quote
Old 03-06-2007, 10:55 AM   #16
*Boostwerks*
*Boostwerks*'s Avatar
Send a message via ICQ to *Boostwerks* Send a message via AIM to *Boostwerks*
Default Re: removing castle nut (civictrix)
I Had that problem. Try clamping the U/LCA down to the knuckle to put more force onto the ball joint (I used vise grips). That should keep it from spinning and allow you to take the nut off. If not... it's time to take the cutting wheel to the grinder...and then the grinder to the nut.
Or just do a DA brake swap with new UCA's.
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com
Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
*Boostwerks* is offline Report Post   Reply With Quote
Old 03-06-2007, 10:58 AM   #17
Tyson
Tyson's Avatar
use an impact wrench.
then rethread the nut with a tap.
Old 03-06-2007, 11:18 AM   #18
civictrix
civictrix's Avatar
Default Re: removing castle nut (Tyson)
I was using an impact wrench, lol. The ball joint is completely shot, I will probably end up cutting it off.
Old 03-06-2007, 11:24 AM   #19
*Boostwerks*
Try clamping it down first...
Old 03-06-2007, 11:36 AM   #20
fireant
fireant's Avatar
Default Re: (Jonathan_ED3)
Originally Posted by Jonathan_ED3
fireant,
Yep, even with the pittman puller I flipped the bolt too, just to avoid any potential damage to the threads. And it helps prevent it from jumping out too.
Old 03-06-2007, 11:39 AM   #21
redefsir
redefsir's Avatar
put pressure under the balljoint you want to seperate with a jack. it should stop spinning
http://b20vtec.com
redefsir is offline Report Post   Reply With Quote
Old 03-06-2007, 12:19 PM   #22
94eg!
94eg!'s Avatar
Try cutting a flat-head screwdriver notch in the end of the stud with a dremmel (before you hack the whole thing up). Hold the stud with the screwdriver, and take the nut off with a wrench. Once you get it off, it's best to chase the stud threads with a die if this is where the problem threads are. If the problem threads are in the nut, just replace it...
Screws are useless.
Old 03-06-2007, 12:23 PM   #23
94eg!
94eg!'s Avatar
Default Re: removing castle nut (redefsir)
You want to put the jack under the LCA to support it. Then have a friend press downward on the rotor. This creates added pressure between the LCA and the stud to help keep it from spinning. I've gone as far as installing the wheel and standing on the lip of the rim for extra pressure. If your wheel doesn't have a lip, stand atop the tire. Just be careful as the wheel can spin & your friend will quickly hit the floor...
Screws are useless.
Bookmarks
2002, civic, headlights, honda
