#1 | |||||
pix of me when vtak kicked in...aahhh... http://images.honda-tech.com/set1/smile/emsmileo.gif |
#2 |
How do you plan on using 81.5 pistons with a 82mm bore? 82mm is the absolute limit on stock b18 sleeves. If its a track only car I wouldnt worry to much. Oh and ditch the gsr tranny for either a type r or b16 tranny. Just changing trannys will make the car faster.
The man cave |
#3 | |
anymore input on the injectors and so fourth...i can't really afford another tranny plus i don't like the fifth gear on the b16 and type r tranny...too much rpm for the freeway...
#4 |
Well 82mm leaves you with no room for a rebuild on stock sleeves.
The man cave |
#5 | |
my problem before was i never got it tuned and wasted hella money cause my motor was running hella lean...walls all scratched up and out of round...thats why 82mm is a must to get the cylinders back to normal...hope i dont' run into any issues with the walls cracking and crap even though i'm going to drive it like daily bout 250+ miles a week...so i'm crossing my fingers and hope the honda gods shine on me...hehehe...
#6 | ||
your compression number's are going to be a little off.
81.5mm piston...82mm bore, Hmm, how does that work ?
#7 |
well i ment to accommodate the 81.5mm pistons...my calculations got fawked...quest there really is a difference between .002" and .02" ...oops...piston to wall clearance was wrong here...but yea...still should be okay with the sleeves rite...and the setup should still be cool rite with the injectors...i'm going broke on the build already...
#8 |
Not if the block is already bored to 82. Those pistons wont work.
The man cave |
#9 |
naw still have the block...completely strip...sitting at the machine shop...waiting for the pistons so he can measure them and bore the block acurately...i just thought that p2w clearance was .02" when it was suppose to be .002"...cause with .02" clearance the bore will be 82mm but i was wrong...missed it by one zero...
but injectors...think they will be enough...
#10 |
The injectors will be ok. Are they prelude injectors?
The man cave |
#11 |
yea obd2 lude injectors...
| Bookmarks |
