| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Dealer Listings | Garage | Vendor Directory |
#1 | |||||
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
#2 |
H-T Basic Sponsor
From the other thread...
"That tube fits up to the opening of the t3 flange terrible, and it doesn't seem to fit up to the collector very good either. Let's not forget the basics of what this piece is designed to do, smoothly transfer air from the head to the turbo. I'd step down the elbow after the collector to something that properly fits up to the T3 flange. Congrats on building something different though."
#3 |
H-T Basic Sponsor
Oh, and it obviously wasn't backpurged at the tube to turbine inlet flange, was the rest of it?
#4 | ||
I appreciate your input Tony.
#5 |
H-T Basic Sponsor
Actually, might want to check that post again, i said the exact same thing to him. Porting the collector is still going to give it a very excessive angle there, why not just use the right pipe? Don't you think that is going to affect the performance having the collector dump into such a big pipe before the turbo?
How do you not have a "method" to backpurge the end part? Aluminum foil and some tape, not really much of a method to it. Any inside pics of the runners, at the back side of a weld perhaps? |
#6 |
Yes on the s2000 I welded in some of the lip and went at it with a carbide , it took some time , but I think I crushed mine more to fit the flange better , also the end of that collocter was angle cut so the opening was not round any more so I hade to crush that end also , but not bad for the first one and only needed to fix some small things
and you will find the dollar store is great for all the tin foil you need
842whp & 508trq @ 35psi Evans Tuning DB8 Squad Member #89 |
#7 | |
#8 |
H-T Basic Sponsor
He said his was 3/32" over the opening, yours is way more than that. I can't say if his 3/32" is correct or not, he never showed the inside, but you can clearly see the inside of yours.
For what it's worth, my opinion is you don't use the wrong size pipe for T3, just so it'll fit a T4. You use the right size for each application. |
#9 |
pics look pretty good man..
tallkyle called me wondering what the rad info i gave you was! haha..radiator, not rad. good job man, looks like a good start to what could be a different and power-producing design
custom EF traction bar and a cheap K24 for sale too! PM! WTB: useable h22 of h23 block/girdle..no crank needed |
#10 |
I give you props bro, becasue I know how much time and effort goes into it. Good luck with the rest of the setup!
I like it.
04 Srt4 325whp |
#11 |
what i like about the design is the room you have for the dp and the simple backdoor access for the intercooler. nice work.
my RWD CRX2000 build thread |
#12 |
On Fire!
Its new and its got a few things that need taken care of which tony already brought up, glad you built something different than whats out on the market already..
Now make a gt42 fit in there
Half-Assed = Half Fast. |
#13 |
i'm sure bryson will make it flow nicely inside...he seems to know a bit about making power..
prototype FTW..good luck man.hope it throws down some big numbers
#14 | |
Trial and Error.
#15 | |||||
)Quote:
#16 |
H-T Basic Sponsor
Pretty easy to figure out, what's the i.d. of the 2" and the 2.5" pipe? Go take a piece of paper and roll it up to that size and see which fits better. The one you used is too big all the way around, i don't see it shaping to fit that hole very easily. For what it's worth, i used a transition from burns on the evo header i did, it was a 2.25" o.d. tube to a T4 flange.
#17 | |
#18 | |
#19 |
I like it Bryson. Nice design.
#20 |
would have been nice to see the turbo braced to the block instead.
"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction." -Albert Einstein |
#21 | |
#22 |
H-T Basic Sponsor
What's the difference, if the mount is solid? The mount needs to support the weight of the turbo, but still allow the manifold to expand and contract with heat. Anything solid will not do that.
#23 | |
![]() But I don't think we'll see any problems with it braced how it is.
#24 | |
ever see an f1 motor on the engine dyno? manifolds move up to 5" those manifold builders are amazing
#25 |
H-T Basic Sponsor
That's how my manifolds are, so far on the evo, a lot of street driven miles, and a very violent anti lag setup, over a year now and no cracks, 16ga. 321 stainless.
| Bookmarks |
