will paypal 20$'s who can help me with my problem (99 ek owners )
Old 02-14-2007, 04:27 PM
EK FLY's Avatar
Default will paypal 20$'s who can help me with my problem (99 ek owners )
I'am dead serious
well 99 ek
99 ex coupe engine harness
obd1 conversion
jdm gsr ecu
problem
car is cranking but no spark , no fuel pump
when i turn the key to the on (III) I only get a oil light on my cluster my main relay doesn't click 2 times like it should
got a brand new main relay from honda yesterday check all my engine grounds and use sand paper on the ground for good contac and nothing I need steps and procedure on how to find out whats wrong
THANKS
Old 02-14-2007, 04:41 PM
ej1_lsvtec's Avatar
Default Re: will paypal 20$'s who can help me with my problem (super-hatch)
if it doesn't click twice then that means the fuel pump dosent prime, check if the pump is getting voltage, and also check the fuel pump relay as for the spark check your coil, cap, and rotor good luck
Old 02-14-2007, 04:45 PM
EK FLY's Avatar
Default Re: will paypal 20$'s who can help me with my problem (ej1_lsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1_lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">if it doesn't click twice then that means the fuel pump dosent prime, check if the pump is getting voltage, and also check the fuel pump relay as for the spark check your coil, cap, and rotor good luck</TD></TR></TABLE>
where is the fuel pump relay located ? u mean the main relay ? btw i will test my dizzy with my friends car tomorrow
Old 02-14-2007, 04:48 PM
ej1_lsvtec's Avatar
Either the underdash or the engine bay...not sure
Elevorett's Avatar
also don't forget to check your fuses. that can be your problem.
Old 02-14-2007, 04:49 PM
EK FLY's Avatar
ow and btw on those 2 dead end plugs behind the manifold wich one is the one thats suppose to have the cap ??????? u know the dead end plugs?
Old 02-14-2007, 04:52 PM
ej1_lsvtec's Avatar
im not sure which ones your talking about
Old 02-14-2007, 05:00 PM
EK FLY's Avatar
dead end plugs right behind the intake mani there are 2 of them with a bunch of yell/black wires coming out of it
Old 02-14-2007, 05:07 PM
ej1_lsvtec's Avatar
i think they're just ground wires let those be
Old 02-14-2007, 05:45 PM
EK FLY's Avatar
I THATS MY PROBLEM NOWWWWWWWWWWWW??????????????i'AM SOO HAPPY i HOPE THATS IT
Old 02-14-2007, 06:05 PM
ej1_lsvtec's Avatar
whats the problem? could also be the ecu you might want to barrow one
Modified by ej1_lsvtec at 9:36 PM 2/14/2007
Old 02-14-2007, 06:18 PM
sql_civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">dead end plugs right behind the intake mani there are 2 of them with a bunch of yell/black wires coming out of it </TD></TR></TABLE>
Those aren't dead end plugs. They are "junction connectors". One of them distributes power to several wires, the other ground. The caps must be plugged in.
Good Luck.
Old 02-14-2007, 07:21 PM
MassScene's Avatar
sounds like the ecu.
paypal-massscene@hotmail.com
thank you.
Old 02-15-2007, 03:11 AM
EK FLY's Avatar
Default Re: will paypal 20$'s who can help me with my problem (sql_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic &raquo;</TD></TR><TR><TD CLASS="quote">Those aren't dead end plugs. They are "junction connectors". One of them distributes power to several wires, the other ground. The caps must be plugged in.
Good Luck.</TD></TR></TABLE>
in wich junction connector ? they are 2 of them , wich one should have the cap ?
ow btw I try 3 differents ecu and same ****
Old 02-15-2007, 03:47 AM
EE_Chris's Avatar
What are the wire colors going into each connector? Does one have Yel/Blk wires while the other uses Grn/Blk wires? If yes, then cap both. One is for grounds and the other is for power.
Get a Helms - it helps here.
Old 02-15-2007, 04:14 AM
RATED EG's Avatar
Default Re: will paypal 20$'s who can help me with my problem (EE_Chris)
if you look behind the glove box. right above the ECU. you will see a small black box (relay) thats your main fuel pump relay. my friend had same problem and he replaced it and that was it.
Old 02-15-2007, 04:15 AM
JDMFantasy2k's Avatar
dead battery
don't laugh, happened to me
Old 02-15-2007, 04:20 AM
RATED EG's Avatar
Default Re: will paypal 20$'s who can help me with my problem (JDMFantasy2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k &raquo;</TD></TR><TR><TD CLASS="quote">dead battery
don't laugh, happened to me</TD></TR></TABLE>
or that lol
Old 02-15-2007, 07:25 AM
puropower's Avatar
check the conversion harness.. maybe you got the wrong one.. check if all the wire from the car is conected to some wire on the harness. if you got your car harness conected to the empty spot on the conversion harness email me and i show u some pic...
stickerguynyc@yahoo.com
Old 02-15-2007, 09:49 AM
sql_civic's Avatar
Both junction connectors should have caps. It's the cap that completes the circuit.
Old 02-15-2007, 11:18 AM
* B A N N E D *
spork motorsports's Avatar
i dont have paypal can you send a check??????
Old 02-15-2007, 11:21 AM
alacard's Avatar
Default Re: will paypal 20$'s who can help me with my problem (RATED EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RATED EG &raquo;</TD></TR><TR><TD CLASS="quote">if you look behind the glove box. right above the ECU. you will see a small black box (relay) thats your main fuel pump relay. my friend had same problem and he replaced it and that was it.</TD></TR></TABLE>
aka the main relay. which he said he replaced already
Old 02-15-2007, 12:54 PM
platinumx6's Avatar
Default Re: will paypal 20$'s who can help me with my problem (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">i dont have paypal can you send a check?????? </TD></TR></TABLE>
go buy your ls1 and do us a favor and get off ht.
Old 02-15-2007, 01:32 PM
EK FLY's Avatar
replaced with a brand new one from honda and same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic &raquo;</TD></TR><TR><TD CLASS="quote">Both junction connectors should have caps. It's the cap that completes the circuit.</TD></TR></TABLE>
only one have the cap, I'am 100 % sure that thats my problem i will see whats up today after I get off work
brand new battery cant be that, about the 20 $'s no one gave me a good answer soo yea I get to keep them
Old 02-15-2007, 03:04 PM
EK FLY's Avatar
well today i try to start it i didnt want to get deep in to it since is damm cold and my car is under the snow soo icant really work on it
i try that cap thing and now I can heard the fuel pump and the 2 clicks I didnt want to crank it bc is open header
Quick Reply: will paypal 20$'s who can help me with my problem (99 ek owners )
