> All Motor
Old 02-08-2007, 08:50 AM   #1
j spec
j spec's Avatar
Send a message via AIM to j spec
Default P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance
Im putting together an ls bottom end with p30 pistons. On the top side is a gsr head with Skunk2 pro series 2 cams and itb's. Just wondering if any body has ran the pro2 cams with P30 pistons in an lsv. Really don't want to clay the motor so im looking for someone who has ran this setup. Also what cam gear setting it would be safe to start off with: 0,0 +1,+1 or whatever.
thanks for any help.
please don't tell me more power can be made on diff cams, i am aware of this, cams are already purchased and will end up in a high comp 2.0 engine which will be better suited for them.
honda-technician
j spec is offline Report Post   Reply With Quote
Old 02-08-2007, 08:51 AM   #2
Natural Aspirations
Natural Aspirations's Avatar
Location: Someone once said you can not fix stupid, and I am starting to believe it.
Send a message via AIM to Natural Aspirations
Default Re: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance (j spec)
D-Rob?
Keeping it clean since '04
I hear and I forget. I see and I remember. I do and I understand.
Natural Aspirations is offline Report Post   Reply With Quote
Old 02-08-2007, 09:21 AM   #3
dinko
dinko's Avatar
Send a message via AIM to dinko
Default Re: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance (Natural Aspirations)
Canon 7D
DINKODESIGN.COM - My graphic design portfolio
dinko is offline Report Post   Reply With Quote
Old 02-08-2007, 10:01 AM   #4
Grand
Grand's Avatar
Default Re: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance (dinko)
Originally Posted by dinko
He will be safe at +10,-10 no problems.
In all seriousness, you might as well quit building engines if your not willing to clay to check for clearances. Would you throw money in the garbage ? No, probably not. So why take such a risk with your investment ?
Somebody elses cam gear setting's are not going to ensure the safety of your engine, every engine is different and nobody really know's how much there head's been milled or block decked, there's just no way to know for 100% sure.
Pro2's also are not a drop in type of camshaft. They must be degreed properly or you might as well use stockers.
Originally Posted by Bobismoi
I DID look around in the engine compartment and learned a few things. I now know what jasma dust is ... the exhaust headers have that on them. It's a 4 into 2 into one system.
Originally Posted by drzbabyboy1606
aight now let me ask u something u think is da timing cause look i have a lsvtec with eagle rods, je 11.5 81.5 mm pistons, on da head the how valve train skunk2 with stage 3 camshaft....someone told me i have 2 do the spec of camshaft but i dont belive that
Grand is offline Report Post   Reply With Quote
Old 02-08-2007, 10:14 AM   #5
j spec
j spec's Avatar
Default Re: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance (LG_R32)
Im perfectly aware of this. Im currently running them in my gsr.
honda-technician
Old 02-08-2007, 10:46 AM   #6
92TypeR
FSAE
92TypeR's Avatar
If you degree them in, Skunk2 recommends +2i/+4e, if I remember correctly.
Be careful with that intake cam, you are treading in dangerous waters advancing it too much.
1997 ITR #110 -- 228whp/158tq 2.0L
2010 Honda Insight EX - Sky Blue Metallic - Saving the planet one gallon at a time!
92TypeR is offline Report Post   Reply With Quote
Old 02-08-2007, 02:04 PM   #7
mx621
mx621's Avatar
Send a message via AIM to mx621
Default Re: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance (92TypeR)
sent you a pm
1.8 ls/v 225whp/154trq 12.65 @ 108.0 in a 2550lb w/ driver DC2---SOLD!!!
02 C5 ZO6- 12.33@116 BONE STOCK
mx621 is offline Report Post   Reply With Quote
Old 02-08-2007, 06:13 PM   #8
Brick Top
Brick Top's Avatar
Originally Posted by Natural Aspirations
D-Rob?
MR EJ7 / LS Vtec
190whp / 123wtq
13.4@101 Blundell Tuned
Brick Top is offline Report Post   Reply With Quote
Old 02-11-2007, 10:49 AM   #9
j spec
j spec's Avatar
Default Re: P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance (brick top)
thanks for the input
honda-technician
Old 02-11-2007, 11:12 AM   #10
D-Rob
D-Rob's Avatar
Send a message via AIM to D-Rob
D-Rob?
I saw this post, and instantly saw your post, and started dying with laughter!
But anyway, my setup is very similar to the OP's planned build.
The setting that made the most power on my setup was:
+4 intake
+4 exhaust
Although, before the RMF Narrow header/SMSP 2.5" exhaust, the settings that made the most power were 0, +1.
Now, I did not degree these cams to begin with, but was very cautious as to how far we went on the dyno.
I'm pretty sure advancing the exhaust cam to +5 made 2whp more, but would NOT idle, no matter what was done.
If you know someone with the proper tools to degree these cams, do it. If not, be very conservative with the cam tuning.
- Derek
InnovativeMotorWorks
w w w . i n n o v a t i v e - m o t o r w o r k s . c o m
Cleaning Out Sale! --> http://www.hondamarketplace.com/show....php?t=2679505
D-Rob is offline Report Post   Reply With Quote
Bookmarks
itb, pro, skunk2
