> Tech/Misc
Old 06-04-2007, 07:32 PM   #51
B18EG6
B18EG6's Avatar
Default Re: (phoebs)
You sure about the rear PCV fittings being 28x1.5? I coulda swore those were 1.0
Originally Posted by mattminer
Anyone know the thread and pitch of the coolant port in a B series head next to the water neck. I think its M19x1.0?
M@
Also, the water pipe on the side of the head that gives water to the heater valve is M20x1.0
MAP sensor bolts M4x.7
Small bolts that hold down the fuses in the underhood fusebox, and also the battery and starter leads are M5x.8
Andddddddd the oddest nut I think!
The throttle rotor nut, M6x1.0 with an 11mm head
Baby you know how I am at the end... you are alwys with me
B18EG6 is offline Report Post   Reply With Quote
Old 06-05-2007, 04:50 AM   #52
-DC2-
-DC2-'s Avatar
Default Re: (B18EG6)
additionally (if it hasn't been posted yet):
you can find OEM bolt LENGTHS on many of the honda/acura parts websites as honda lists them by diameter and length
http://www.hondapartsdeals.com/honda_parts.php
or
http://www.acuraoemparts.com/d...y.jsp
<FONT COLOR="blue">formerly DOHCDX, DOHCvtecDX</FONT>
<FONT SIZE="1">
Vouches, buy from good sellers
</FONT>
-DC2- is offline Report Post   Reply With Quote
Old 06-16-2007, 10:59 PM   #53
Airbag Club
Airbag Club's Avatar
Send a message via AIM to Airbag Club
Default Re: (-DC2-)
GREAT thread!!!
Airbag Club is offline Report Post   Reply With Quote
Old 06-25-2007, 03:26 PM   #54
dannydos
dannydos's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (Bense)
Good stuff...lowells has more of these bolts then home depot....atleast the ones i got to
dannydos is offline Report Post   Reply With Quote
Old 07-09-2007, 04:09 PM   #55
Papi4baby
Papi4baby's Avatar
Guys quick help the bumper bolts, the actual steel beam, PN 93405-08020-08 it says 8X20 on the website for the honda parts? Help.
A CNN reporter, while interviewing a Marine Sniper, asked. "What do you feel when you shoot a terrorist?"
The Marine shrugged and replied, "Recoil."
Papi4baby is offline Report Post   Reply With Quote
Old 07-09-2007, 08:07 PM   #56
B18EG6
B18EG6's Avatar
Default Re: (Papi4baby)
8mm x 1.25mm thread , 20 mm length
Old 07-10-2007, 03:50 PM   #57
Papi4baby
Papi4baby's Avatar
Thanks bud.
Old 07-10-2007, 04:31 PM   #58
B18EG6
B18EG6's Avatar
no problem - lemme know if yer stuck, I'm in MD too and may be able to drop by.
Any other random unknown Honda threads???
Old 07-19-2007, 11:08 AM   #59
Lost_clearance
Lost_clearance's Avatar
reminds me of when i had to order everysingle bolt for my car lol in stainless
Lost_clearance is offline Report Post   Reply With Quote
Old 07-26-2007, 06:36 AM   #60
2point2
2point2's Avatar
Default Re: (allricedout)
no one posted the spark plug thread size/pitch!?!
Turbocharged CRX w/Stock H22
10.73 @ 137mph
Pics and Info
2point2 is offline Report Post   Reply With Quote
Old 07-26-2007, 06:59 AM   #61
B18EG6
B18EG6's Avatar
Default Re: (2point2)
14 x 1.25mm
B-)
Old 08-03-2007, 05:07 PM   #62
E-Money
E-Money's Avatar
Send a message via AIM to E-Money
bump... looking for a 12 mm nut for a endlink. honda says 12mm flange nut. and i only found a 12mm nut with a thread pitch of 1.75 i checked a couple of sources
PSN: yurpindude
FS: First gen RSX Type S wheels w/tires. Local NJ Tristate area.
http://www.hondamarketplace.co...72139
E-Money is offline Report Post   Reply With Quote
Old 08-04-2007, 01:27 AM   #63
B18EG6
B18EG6's Avatar
Default Re: (E-Money)
mcmaster part number 90576A141 is one
search some more
Old 08-04-2007, 12:25 PM   #64
dblock2x
dblock2x's Avatar
Fuel tank drain bolt? its a 14mm head.
dblock2x is offline Report Post   Reply With Quote
Old 09-23-2007, 11:26 PM   #65
0TT
0TT's Avatar
is the M28x1.5 Allen-head bolt the blanking plugs for the back of the B16a blocks?
Im trying to find a tap for them thats why I ask.
0TT is offline Report Post   Reply With Quote
Old 10-02-2007, 06:20 PM   #66
66fasty
66fasty's Avatar
Send a message via AIM to 66fasty
Nut pitch/size For the 3 Catalytic convertor to exhaust nut?
66fasty is offline Report Post   Reply With Quote
Old 10-23-2007, 05:11 PM   #67
bimmeracer
bimmeracer's Avatar
Can anyone tell me what size bolts I need that I can get from Home Depot for the following:
-Starter
-Throttle Body and cable
-Fuel Rail
-Shift Linkage
-Hydrolic Slave cylinder
BTW, this is for a LS in a EG Hatch.
THanks
///M RATED E36 M3 - Supercharged
EG Hatch - LS non-vtec swap
bimmeracer is offline Report Post   Reply With Quote
Old 11-30-2007, 09:54 PM   #68
Power of Dreams
Power of Dreams's Avatar
Looking for the thread, pitch, and length (if you know that also) for the camshaft gear retaining bolt on a D15B7 engine.
I believe it's M8 x 1.50. That's what I measured with the pitch gauge, but because the bolt was snapped in half near the shoulder of the head, I couldn't get a very accurate measurement.
Help is greatly appreciated.
Thanks.
Power of Dreams is offline Report Post   Reply With Quote
Old 12-25-2007, 06:35 PM   #69
StorminMatt
Originally Posted by Bense
I believe that most of our M8-1.25 bolts are what we use the 12mm sockets for. However most of the nuts/bolts that we buy in conventional hardware stores that are M8-1.25 use 13mm heads.
This brings up something else. Although factory 10mm bolts use a 14mm head, 10mm bolts purchased at a hardware store generally use a 17mm head. And while factory 12mm bolts use a 17mm head, 12mm bolts purchased at a hardware store use a 19mm head. I am not sure why this is. But while this is not a problem most of the time, I have run into situations were the larger head caused fitment issues.
VTEC or non-VTEC? BOTH!
1988 B20Z Civic DX 4DR Sedan
1988 B18C5 CRX DX
1995 Allmotor GSR (All motor, no car!)
Coming soon: 1989 D15Z1 Civic STD HB - The Gas Saver!
StorminMatt is offline Report Post   Reply With Quote
Old 01-04-2008, 03:31 PM   #70
Mikey3000
Mikey3000's Avatar
Send a message via AIM to Mikey3000
Default Re: Common Honda Bolt thread pitch size dimension (StorminMatt)
Because I don't see the H series head bolt.
M12 x 1.5 mm x 185 mm long. The head is 14 mm.
92 Civic CX - Turbo H22A, 680 whp, 441 lb-ft 28psi
10.42@144mph
Mikey3000 is offline Report Post   Reply With Quote
Old 01-08-2008, 06:57 AM   #71
JDM JEFFREY
JDM JEFFREY's Avatar
I need the thread size for the 17mm bolt that hold the tranny to the block.
(89.5x97h2b)286whp214tq 11:54@115 fastest allmotor street car in OR
POWERED BY PARRIS RACE ENGINES
project 300+ coming soon
JDM JEFFREY is offline Report Post   Reply With Quote
Old 02-01-2008, 07:27 AM   #72
ClemsonS197
ClemsonS197's Avatar
Noob here not in the Honda world, but I'm having a heck of time finding a set up nuts. I need a M14-1.5 flange nut, and a M12-1.25 flange nut.
I came across this thread and saw:
"Subframe flange bolt: 14x1.5mm"
Is there a flange nut for the other end of that? Can someone tell me how I can get a local Honda dealer to find these parts? Car, year, model, etc? Thanks in advance.
ClemsonS197 is offline Report Post   Reply With Quote
Old 02-03-2008, 07:59 PM   #73
draperj09
draperj09's Avatar
Send a message via AIM to draperj09
Default Re: Common Honda Bolt thread pitch size dimension (ClemsonS197)
motor mount bolt size? d15b2 ef
1990 Honda Civic hatchback
WTB: driver side fender, bumper filler
FS: driver side corner light, no tach gauge cluster
draperj09 is offline Report Post   Reply With Quote
Old 02-14-2008, 02:26 PM   #74
Boosted Rex
Boosted Rex's Avatar
Send a message via ICQ to Boosted Rex Send a message via AIM to Boosted Rex
Default Re: Common Honda Bolt thread pitch size dimension (draperj09)
awesome info
I eat steak N' rice and shit out diesel.
Squad S-RD
Boosted Rex is offline Report Post   Reply With Quote
Old 02-18-2008, 07:55 PM   #75
DIRep972
Smarter than you
DIRep972's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (Boosted Rex)
I am having to re-calibrate my tps sensor by changing the position. Basically the stock rivit screws that I have with cut ends aren't giving me any leverage. I tried to use the map sensor bolts and they did not thread all the way in.
Anyone know the thread/pitch? thanks
Chris Stein
Crew Chief - Team Arturbo - 10.006 @ 149.2
www.Arturbo.com
www.fast-turbo.com 817-439-3748
www.t1racedevelopment.com 214-607-9022
DIRep972 is offline Report Post   Reply With Quote
Bookmarks
94, arp, bellhousing, bolt, civic, crank, find, head, honda, hood, pitch, pulley, size, studs, thread
