> Tech/Misc
Old 02-23-2007, 02:25 PM   #26
vestalfootball72
Guest
Posts: n/a
Default Re: Common Honda Bolt thread pitch size dimension (JCracer723)
Originally Posted by JCracer723
im thinking:
M8-1.25 (common) (probably most of our 12mm head bolts)
Thanks a ton- I was thinking it was M8 by the standard 1.25 but wanted to double check. Cant wait to machine some spacers on the lathe
Report Post   Reply With Quote
Old 02-23-2007, 02:34 PM   #27
Eran
HT White Ops
Eran's Avatar
Because I'm down there right now ....
Front LCA Bolts:
Subframe flange bolt: 14x1.5mm
Bushing bracket flange bolt: 14x1.5mm
Bushing nut: 14x1.5mm
Shock fork lower bolt: 12x1.25mm
Shock fork upper bolt: 10x1.25mm
Swaybar endlink nuts: 8x1.25mm
Swaybar bushing bolts: 8x1.25mm
Jason -- 97 VSM del Sol <2WAYPARADISE>
Proclivity to Hatership
[ Flickr. ][ anti|hero ][ dSoc ]
Eran is offline Report Post   Reply With Quote
Old 02-23-2007, 02:42 PM   #28
XkjeldorX
XkjeldorX's Avatar
Default Re: (Eran)
This is exactly the info i needed to clean all the threads on my block when i get it back from the machine shop. Now all i need is a Tap and Die set.
Does anyone know what size are the bolts that bolt down the Main caps on a 93 LS motor?
I vote Sticky
XkjeldorX is offline Report Post   Reply With Quote
Old 03-02-2007, 11:28 AM   #29
vestalfootball72
Guest
Posts: n/a
Default Re: (XkjeldorX)
Hey guys- I was looking around and found this site- pretty good stuff on it
http://www.boltdepot.com/faste....aspx
Im placing a order right now for some stuff. They have honda clips and fasteners too.
Old 03-06-2007, 01:12 PM   #30
Bense
Moderator
Bense's Avatar
Send a message via ICQ to Bense Send a message via AIM to Bense Send a message via MSN to Bense Send a message via Yahoo to Bense Send a message via Skype™ to Bense
Default Re: Common Honda Bolt thread pitch size dimension (Bense)
edited + cleaned up
Bense is offline Report Post   Reply With Quote
Old 03-06-2007, 01:24 PM   #31
D50boy
D50boy's Avatar
Send a message via AIM to D50boy
Great information for some extra security measures. I'm sure it would seriously hinder how long it would take a thief to strip a car!
http://www.mcgard.com/security/intimidator.asp
'99 B18C5 Civic Hatchback- for fun
'08 L15A Fit Hatchback- for the wife
D50boy is offline Report Post   Reply With Quote
Old 03-23-2007, 08:43 AM   #32
TrueNorthStar
TrueNorthStar's Avatar
Send a message via ICQ to TrueNorthStar
Default Re: Common Honda Bolt thread pitch size dimension (D50boy)
Anyone have the thread size for the port on the i'/m side of the head used for ls/vtec?
I need to hook up a oil pressure sending unit after the filter.
TIA
TrueNorthStar is offline Report Post   Reply With Quote
Old 03-23-2007, 10:04 AM   #33
IN VTEC
IN VTEC's Avatar
Send a message via AIM to IN VTEC
Default Re: Common Honda Bolt thread pitch size dimension (TrueNorthStar)
TIA
3/8" BSPT, but I usually retap it for 3/8" NPT and use a 3/8" NPT plug.
XBL: Dr Eugh
For Sale:
http://hondamarketplace.com/zerothread?id=1810378
IN VTEC is offline Report Post   Reply With Quote
Old 03-23-2007, 11:38 AM   #34
TrueNorthStar
Default Re: Common Honda Bolt thread pitch size dimension (IN VTEC)
I remeber reading somewhere that it was a 3/8npt but couldn't understand why honda would choose to use a npt thread on that one plug vs. the rest of the bspt threads they use on the rest of the engine.
I can't tap it out (still on a running engine) so I guess I will get an adapter for it.
Thanks!
Old 03-23-2007, 05:45 PM   #35
stumpyf4
M18X1.5 O2 Sensor Bung
Great Vendor Experiences: LSD Motorsports, Lightning Motorsport, Innes Performance Group, VS Racing.
Poor Vendor Experience: Kteller
stumpyf4 is offline Report Post   Reply With Quote
Old 03-23-2007, 06:43 PM   #36
IN VTEC
IN VTEC's Avatar
I thread gauged the port one time and it is metric thread (BSPT). The NPT thread is only different by 1 thread per inch.
XBL: Dr Eugh
For Sale:
Old 05-03-2007, 10:57 AM   #37
W O T
W O T's Avatar
How big are the bolts that hold your radius rod to the LCA?
M14?
Need to re-tap that hole, its chewed
W O T is offline Report Post   Reply With Quote
Old 05-03-2007, 12:07 PM   #38
IN VTEC
IN VTEC's Avatar
Default Re: Common Honda Bolt thread pitch size dimension (W O T)
M12x1.25, same as all of the other 17mm head suspension bolts.
XBL: Dr Eugh
For Sale:
Old 05-03-2007, 12:48 PM   #39
89s1
89s1's Avatar
yikes, just enough to chew the threads right out.
GREAT info thread guys, yet another .html save on my HD thanks to H-T
Keepin it oldskool.
R.I.P. Kills Forum/ZeroForum. You'll be missed.
89s1 is offline Report Post   Reply With Quote
Old 05-04-2007, 08:54 AM   #40
W O T
W O T's Avatar
I dont believe its an m12 X 1.25 for the lca bolt
the thread is to fine
Old 05-04-2007, 10:42 AM   #41
IN VTEC
IN VTEC's Avatar
Says it in the suspension diagram. Any Honda suspension bolt with a 17mm head is a M12x1.25. The rear trailing arm bushing bolts are the same thread size and pitch.
XBL: Dr Eugh
For Sale:
Old 05-04-2007, 10:43 AM   #42
W O T
W O T's Avatar
Its to fine of a thread for 1.25, Im going to honda right now since knwone here has them
Old 05-04-2007, 10:47 AM   #43
B16b-EJ8
B16b-EJ8's Avatar
Where has this thread been all my life
WTB: Complete AC for an EJ8
B16b-EJ8 is offline Report Post   Reply With Quote
Old 05-06-2007, 11:37 AM   #44
Batmite
Batmite's Avatar
Default Re: (Bense)
Come on man! If it's 13mm it's a 1/2" SAE fastner.
Batmite is offline Report Post   Reply With Quote
Old 05-06-2007, 12:12 PM   #45
Batmite
Batmite's Avatar
OK guys and girls I copied all of the bolt spec's listed in the previous posts to have them in one place. I can't vouch for the correctness, but here they are.
M6-1.0 --- common (most of our 10mm head bolts)
M8-1.25 -- common (probably most of our 12mm head bolts)
M10-1.25 - some headbolts) (probably most of our 14mm head bolts)
M11x1.5 -- some headbolts)
M12x1.0 -- flywheel bolts + shift fork ball spring bolts)
M12-1.25 - common (probably most of our 17mm head bolts)
M12-1.5 -- lugnuts)
M14-1.25 - crank bolt?)
M14-1.5 -- oil pan drain plug. 19mm head bolt that connects rear trans bracket to trans
M16-???
M20x1.0 -- 10mm allen bolt
M20x1.5 (oil filter threads????)
M22x??? d-series countershaft nut
M28x1.5 - 14mm allen bolt
Flywheel bolts (B and D the same, dont know about H and K): M12 x 1.0
Pressure Plate bolts (same b and d dont know about h and k): M8 x 1.25
Oil pan/Trans drain plug: M14 x 1.5
Trans case bolts that hold that little ball bearing in place with spring: M12 x 1.0 (oddly enough this is a hard tap to find, and timesert hasnt even made an insert for it yet so dont screw this one up)
Oil Pressure Sensor (back of block): 1/8 - 28BSP
Bumper screw/bolts: M6 x 1.0
Crank Bolt: M14 x 1.25
14mm Allen Bolt: M28 x 1.5
10mm Allen Bolt: M20 x 1.0
19mm bolt that connects rear trans bracket to trans: M14 x 1.5
D-series head stud thread: M10x1.25
B-series head stud thread: M11x1.5
Also, if it's an unusual thread, like the oil filter for example, Please put it like this
M20x1.5 (oil filter threads)
M12 x 1.25 - rear inner seat rail bolt
M10x1.5 - Shifter (for all you poor saps that need a locknut for your
Type-R knob)
Front LCA Bolts:
A. M12x1.25, same as all of the other 17mm head suspension bolts.
M16 is for the thermoswitch,under the water pipe.
I never tried a crank pulley bolt to see if it fits.
Old 05-10-2007, 10:45 PM   #46
mattminer
mattminer's Avatar
Default Re: (Batmite)
Anyone know the thread and pitch of the coolant port in a B series head next to the water neck. I think its M19x1.0?
M@
mattminer is offline Report Post   Reply With Quote
Old 05-14-2007, 03:58 PM   #47
b20beast978
b20beast978's Avatar
Send a message via AIM to b20beast978
what bolts would i need to bolt on a b series tranny to the block? im taking a wild guess, is it a m14 x1.5 ?
b20beast978 is offline Report Post   Reply With Quote
Old 05-15-2007, 07:45 AM   #48
dfoxengr
dfoxengr's Avatar
Send a message via AIM to dfoxengr
Default Re: (JerseySiPOS)
oil pressure sensor on back of block 1/8 BSPT
maybe try to compile all of these sizes into the first post, by drivetrain, suspension components, etc.
that would help a ton so people dont have to search all over.
dfoxengr is offline Report Post   Reply With Quote
Old 05-24-2007, 09:55 PM   #49
slo90si
slo90si's Avatar
Default Re: (dfoxengr)
yaeh we should get a list as a sticky or something.. just not so many question marks after the bolt size
slo90si is offline Report Post   Reply With Quote
Old 06-01-2007, 07:07 PM   #50
phoebs
phoebs's Avatar
Default Re: (RedEj8)
Originally Posted by RedEj8
LOL!
phoebs is offline Report Post   Reply With Quote
Bookmarks
94, arp, bellhousing, bolt, civic, crank, find, head, honda, hood, pitch, pulley, size, studs, thread
