> Honda CRX / EF Civic
Old 02-10-2007, 02:29 PM   #51
fireant
fireant's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (UltimX)
The 91 USDM factory service manual lists them as 'C953 and C954 (Option)'
The fact that they are wired means they were meant for some kind of optional accessory, but it beats me what.
2000 civic hatchback hypermiler
1991 CRX Si track toy
95 Ford Ranger 3.0 mule
fireant is offline Report Post   Reply With Quote
Old 02-10-2007, 02:31 PM   #52
gospeedgo1
gospeedgo1's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (fireant)
prolly foglights
88 CRX SI
02 S2000
gospeedgo1 is offline Report Post   Reply With Quote
Old 02-10-2007, 02:49 PM   #53
UltimX
UltimX's Avatar
Send a message via AIM to UltimX
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (gospeedgo1)
so does that mean if they were indeed for lights that one is ground and the other is power? wouldn't an alarm go into these clips too?
FS: d16a6 head complete, LS head minus rockers, eibach sportline springs & aftermarket struts, Catalytic Con., sparco speed seat, NEW Traction bar, aftermarket header. 1800 lbs and dropping...
UltimX is offline Report Post   Reply With Quote
Old 02-11-2007, 03:19 PM   #54
synergy10
synergy10's Avatar
Just got this done and it works great! Best $4 I've spent in a while.
synergy10 is offline Report Post   Reply With Quote
Old 02-19-2007, 10:55 PM   #55
ridin_on_rims
ridin_on_rims's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (synergy10)
ok so i did this just like it says to red wire on the right black wire on the left. it did not work for me ,but i did noticed a slight humm! so just to make sure i did this correct i put it in my crx and it worked kool . i checked all my fuses and there good could this be a ground issue ? got any sugesstions? thanks
ridin_on_rims is offline Report Post   Reply With Quote
Old 02-20-2007, 06:48 AM   #56
gen2fanatic
gen2fanatic's Avatar
Send a message via AIM to gen2fanatic
I'm all over this one! Just gotta make a run to radio shack later on
A whole new world... www.vwvortex.com
DA squad #262
Nikon D40::18-55mm::55-200mm::
gen2fanatic is offline Report Post   Reply With Quote
Old 02-20-2007, 07:34 AM   #57
fireant
fireant's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (ridin_on_rims)
It might be the buzzer. What are the specs on the packcage?
Old 02-20-2007, 01:05 PM   #58
ridin_on_rims
the specs are voltage range 3.0-20vdc rated voltage 12vdc sound preasure level 75db min i thought it could be the buzzer but it worked on the crx just fine still lookin for sugesstions thanjs
Old 02-20-2007, 01:55 PM   #59
PINKS
I want a CRX tattoed on my butt
PINKS's Avatar
PINKS is offline Report Post   Reply With Quote
Old 02-20-2007, 07:33 PM   #60
gen2fanatic
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (PINKS)
Got the buzzer today. Installation tomorrow at work!!!
DA squad #262
Old 02-21-2007, 05:27 PM   #61
91ed9
91ed9's Avatar
Send a message via AIM to 91ed9
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (gen2fanatic)
does the buzzer sound when the key is on and the headlight are on?
i dont see how this only works when the key is off and headlights are on?
91crx si- junked 91crx dx-Sold!
2006 Audi A4 Tein coilovers,Custom FMIC Apr stage 2 software, 2.5" testpipe, 3" custom single exhaust, South Bend stage 2 clutch, 16lb lightwieght flywheel
91ed9 is offline Report Post   Reply With Quote
Old 02-21-2007, 05:34 PM   #62
apple
apple's Avatar
Send a message via AIM to apple
good easy how to.
thanks.
apple is offline Report Post   Reply With Quote
Old 02-21-2007, 05:42 PM   #63
fireant
fireant's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (91CRXed)
The buzzer will sound when the car is off, whether or not the key is in the ignition.
Old 02-21-2007, 05:47 PM   #64
91ed9
91ed9's Avatar
i did this and it also sounds when the key is on and the headlights are on
what the hell man lol , i checked all fuses and wires and everytign looks good and i also found out why my ac controler wasnt workin fuse blew
Old 02-21-2007, 06:59 PM   #65
grog
grog's Avatar
I had some other brand buzzer that didnt work. the piezo buzzer did work, i dont know why, the specs seem the same, maybe they trigger in different ways.
i was taking my dash apart and i figured out these connecters have something to do with the rear defroster, with the defrost switch disconnected the buzzer does not work. so a bad defroster switch could prevent the buzzer from working. I asume if the light on the defroster switch comes on its working
Originally Posted by xerowatts
I HAVE A 1990 CRX HF AND THE ENGINE BLOWED UP.
Originally Posted by mackadocious
its prolly piece of rust that fell inside the rotor causing it to be cricket and make the car shake ..when stoping or ...or prolly motor over flooded with oil leaks
grog is offline Report Post   Reply With Quote
Old 02-21-2007, 07:11 PM   #66
grog
grog's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (grog)
If that method doesnt work for your car you might have to do the fuse method. you find 2 fuses to connect the buzzer to with the fuse connecters (pictured on page 2 i think). you need a signal (a headlight fuse) and power (I think i used slot #10, i forget what it is)
these connectors stretch out the fuse slots so make sure they work before you cram it in there
Old 02-21-2007, 07:51 PM   #67
PINKS
PINKS's Avatar
Default Re: (grog)
Just finished
Worked great
Power on the right, ground ont he left
I used a 76db little Piezo from radioshack and the light ****er is pretty loud, high pitched lol
Definetely wont be caught again
Old 02-23-2007, 08:40 PM   #68
stemiched
stemiched's Avatar
Send a message via AIM to stemiched
Default Re: (PINKS)
anyone know if this would work with hooking a little light up to that same spot?
all parts listed are OBO
sorry for all the part listings... but mod complained when i put it all in one thread... told me they need to be all separate for better searching
stemiched is offline Report Post   Reply With Quote
Old 02-23-2007, 09:44 PM   #69
fireant
fireant's Avatar
Default Re: (stemiched)
as long as its twelve volts and not drawing too many amps, it should work.
Old 02-23-2007, 09:47 PM   #70
stemiched
stemiched's Avatar
Default Re: (fireant)
cool, im going to try this and post up my results... as soon as i get my ass to radio shack...
Old 02-24-2007, 09:09 PM   #71
Arethereanynamesleft
Arethereanynamesleft's Avatar
Is there any way to turn off that annoying "beep beep beep beep.... beep beep beep beep.... beep beep beep beep" when you leave the keys in and open the door. I like to leave the door open and listen to the stereo when I clean my interior, but can't with my honda...
Arethereanynamesleft is offline Report Post   Reply With Quote
Old 02-24-2007, 10:03 PM   #72
UltimX
UltimX's Avatar
Default Re: (Arethereanynamesleft)
find the buzzer and disconnect it or wire a switch into it so u can cut it off and turn it on.
Old 02-25-2007, 08:35 AM   #73
RockinthEFhatch
RockinthEFhatch's Avatar
Default Re: (UltimX)
I did it by bridgeing the fuses...
8 is power. 18 is ground.
This way is even easier!
'91 CRX Si
RockinthEFhatch is offline Report Post   Reply With Quote
Old 02-25-2007, 12:20 PM   #74
stemiched
stemiched's Avatar
Default Re: (RockinthEFhatch)
well i don't know what buzzer i picked up but it isnt any beeping it just buzzes, but i didn't install it to sound pretty, definitely never going to leave my head lights one again...
Old 02-25-2007, 05:38 PM   #75
Tyson
Tyson's Avatar
Default Re: DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER (Tyson)
Originally Posted by Tyson
theres a combination of fuses that you bridge and just stick the bare ends of the wire into (no plug required) and will trigger just like a headlight warning.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Bookmarks
accord, beeper, buzzer, civic, crx, diy, ef, headlight, honda, leave, lights, on, prelude, problem, warning
