> All Motor
Old 01-27-2007, 01:40 PM   #1
allmotorpackage
allmotorpackage's Avatar
Default 2.0L lsvtec
hey guys , after some research, i m starting on my engine build. I just picked up a bored/sleeved 84mm ls block with crankshaft from a good friend of mines and i had a gsr head laying around in the garage that i will send out for headwork. I am building this for daily driver here in CA where we only have 91oct. I want to make this as reliable as possible but somehow hoping to get pass the 230whp mark.
I am wondering, as far as compression goes , will running 11.5 and 12.1 compression be a big difference ?
I ve narrowed down my cams to skunk2 pro1s or pro2s / rocket m22x and ****, which cams will better fitted for this kind of setup ( want more high rpm power over midrange).
I ve heard that Ti retainers tend to wear , but also heard that it doesnt apply to the rocket motorsport line of retainers. Is this true and if so, why is that ?
thanks for the input guys
allmotorpackage is offline Report Post   Reply With Quote
Old 01-31-2007, 05:58 PM   #2
allmotorpackage
Default Re: 2.0L lsvtec (allmotorpackage)
bump
Old 01-31-2007, 09:03 PM   #3
clean rice
clean rice's Avatar
Your compression level will be fine assuming that your motor will be tuned. The whole TI retainer wear apply's to many different VT's on the market today, the reason you never see Rockets retainers wear is because there is actually a TON of r&d to them. The gen 1 and 2 series were incredible, the new SL line is even better. If you're looking for top end power and depending on who is doing the head, I would look into the **** or the Pro2. The Pro2's are a bit larger yes, but in a healthy and properly tuned motor, I would stack them against the Pro2 anyday. The M22xx would also be another great option as they have carried power past the 9k mark many many times, an AWESOME drag race cam. What intake and header are you using? What are you going to tune with?
Rocket Motorsports and MFactory dealer.
Rest in peace Gramma...
clean rice is offline Report Post   Reply With Quote
Old 02-02-2007, 01:18 PM   #4
allmotorpackage
Default Re: 2.0L lsvtec (clean rice)
i m thinking about using the skunk2 proseries IM with a 68 TB and a rage big tube header and most likely tuning with crome. can the m22x cam perform well with this setup because a guy around my area is selling a lightly used set with the gen2 valvetrain for cheap or will i benefit a lot more with the **** and pro2 ?
and also will choosing a regular forged piston with 11.5 compression instead of a 12.1 change power output and charateristic of the engine alot ?
realisticly, my goal is to have 240whp + and also last 50k + abusive miles. is this goal acheivable with this setup ?
Old 02-05-2007, 10:41 AM   #5
allmotorpackage
bump
Old 02-06-2007, 12:53 PM   #6
allmotorpackage
still in need of a little help
Old 02-06-2007, 01:39 PM   #7
acydphryck
acydphryck's Avatar
so this is your goal then right???
i have cast RS ITR pistons in this motor with a full portflow GSR head. the blox b cams are cheap and they make good power throughout entire power band...that's what i'm using too. i'm not sure about the titanium retainer issue but my motor is over a year old now and it's been beat at sanctioned and non-sanctioned events (if you know what i mean )
the b20b motor has stock sleeves, crank and rods held together with ARP rod and head bolts. i have JG Victor X manifold with a port matched 70mm throttle body. injectors are RC370's fed by an intank walbro 190lph fuel pump. air/fuel ratio and ignition is controlled via hondata s300.
motor has well over 150 passes on Prostreet Import's dynojet alone (shop owner learned hondata tuning on my motor ). motor has been revved up and beyond 9500 rpms in most of the passes. motor is daily driven about 2-3 times a week and on the weekends. hope this helps out in your build...you don't necessarily have to have forged pistons on high compression motors. get a reputable machine shop to build up your head and you should be looking at 230whp through the exhaust np
FS:
Quaife/Wavetrac LSD's BACK IN STOCK!!! pm me for homie hook up priceshttp://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emsmile.gif
Complete B20 Block RS ITR pistons. SOLD.
MacBook Pro SEALED IN BOX. SOLD.
acydphryck is offline Report Post   Reply With Quote
Old 02-06-2007, 02:31 PM   #8
ImportechPerformance
ImportechPerformance's Avatar
Default Re: 2.0L lsvtec (acydphryck)
The above graph is really nice..
Cant wait to build my LS/Vtec 2.0
ImporTech Performance
ImportechPerformance is offline Report Post   Reply With Quote
Old 02-06-2007, 05:58 PM   #9
mar778c
mar778c's Avatar
Mad props.
That is a nice build.
Good people:
Synapse Motorsports,JDogg,b18c1_powered _si,CHEETAH, 86si,NA_is_best, Astig, McNews Automotive, geardog, 4g hatch, Innovative Motorworks
mar778c is offline Report Post   Reply With Quote
Old 02-06-2007, 06:02 PM   #10
MikeSarr_GSR
MikeSarr_GSR's Avatar
Send a message via AIM to MikeSarr_GSR
Default Re: 2.0L lsvtec (mar778c)
its amazing how that motor carries tq all the way out
MikeSarr_GSR is offline Report Post   Reply With Quote
Old 02-06-2007, 11:06 PM   #11
acydphryck
acydphryck's Avatar
Default Re: 2.0L lsvtec (MikeSarr_GSR)
Originally Posted by mar778c
Mad props.
thanks for the props guys...i have nothing to do with the motor build except pay for it
the guy who deserves all these props is Eugene Castro...the engine builder and tuner... check out http://www.ProstreetImport.com
FS:
Old 02-07-2007, 01:00 AM   #12
smileycvc
smileycvc's Avatar
I have heard some nasty things about blox cams.
B20Vtec 220whp/156 ft/Lbs Torque. RIP
B18 198whp 128 ft/lbs Sold
02 WRX 204 and 197ft/lbs New Whip
smileycvc is offline Report Post   Reply With Quote
Old 02-07-2007, 03:57 AM   #13
SlammedDC2
Semper Fidelis
2000 Acura Integra
SlammedDC2's Avatar
Send a message via AIM to SlammedDC2 Send a message via Yahoo to SlammedDC2
Default Re: 2.0L lsvtec (smileycvc)
I'm also in for hearing what people have to say in here.
<--will be building a 230whp+ 2.0 in the future
00 NHBP Integra GS-R **Build in Progress**
96 GMC 1500 4" lift
SlammedDC2 is offline Report Post   Reply With Quote
Old 02-07-2007, 09:47 AM   #14
acydphryck
acydphryck's Avatar
what kind of bad things have you heard about them? i'd like to know as well as others on here cuz i'm sure i'm not the only one running their stage 2 cams
FS:
Old 02-07-2007, 10:08 AM   #15
mar778c
mar778c's Avatar
Wow, that was helpful.
Here's the converse of that statement:
"I heard some nice things about blox cams."
Seriously, stop the explective gossip.
I run the stg 1's and would like to know if there is a problem.
Good people:
Old 02-07-2007, 09:50 PM   #16
DARKB20
DARKB20's Avatar
running blox b, great power........no issue........
b20/vtec 231whp dyno-jet@pro-street import.....
Pro-Street Import (714)739-5683
www.insaneshafts.com***INNOVATIVE MOUNTS
F/S Crx B20v 230whp http://www.hondamarketplace.com/show....php?t=2659819
DARKB20 is offline Report Post   Reply With Quote
Old 02-07-2007, 11:04 PM   #17
SiB16A
SiB16A's Avatar
Default Re: 2.0L lsvtec (DARKB20)
acydphryck, what vs/retainers are you using?
SiB16A is offline Report Post   Reply With Quote
Old 02-08-2007, 12:49 PM   #18
acydphryck
acydphryck's Avatar
Default Re: 2.0L lsvtec (SiB16A)
vs/retainers = Portflow
same company that ported my cylinder head
2 x for Tom
FS:
Old 02-08-2007, 12:50 PM   #19
acydphryck
acydphryck's Avatar
your setup sounds familiar
FS:
Old 02-08-2007, 01:44 PM   #20
SiB16A
SiB16A's Avatar
2 x for Tom
cool thanks...Im waiting for my Blox B's to come in also Thanks for answers!
Old 02-08-2007, 02:41 PM   #21
MikeySpec
MikeySpec's Avatar
Send a message via AIM to MikeySpec
I have heard about some nasty high dyno numbers and have seen some outstanding quality from these cams. My own personal pair of blox c's have seen almost 30k miles with no unusual wear. Word!
Pro Function
http://www.profunctionauto.com
MikeySpec is offline Report Post   Reply With Quote
Old 02-08-2007, 03:39 PM   #22
DARKB20
DARKB20's Avatar
Default Re: 2.0L lsvtec (MikeySpec)
I wonder why? ..................Eddy's car is running, call when you can.
Old 02-08-2007, 04:24 PM   #23
acydphryck
acydphryck's Avatar
what the?!??! he got it up and running??? NICE!!!!!!! hehehe...i'm gonna have to head over there with the white EG and check her out
FS:
Old 02-08-2007, 05:57 PM   #24
EK Josh
1997 Acura Integra
EK Josh's Avatar
I'll be in here on the prostreet bandwagon soon
I just had my motor tuned by Eugene last friday night and I'm looking to have him build me a 2.0L lsvtec.
||'97 Integra GS-R||
EK Josh is offline Report Post   Reply With Quote
Old 02-08-2007, 09:38 PM   #25
acydphryck
acydphryck's Avatar
Default Re: 2.0L lsvtec (EK Josh)
OH SH*T S0N!!!!!!!!! watch out now!!! hehehe...i smell another 2xx whp motor coming up?? oh...and...what's that??? on pump gas too?? what's this world coming to?
FS:
Bookmarks
build, ls, turbo, video, vtec
