#1 | |||||
06 Civic LX Sedan (Royal Blue w/ Tan Interior) |FA Squad Member #40| Injen CAI // PIAA Xtreme White Plus Hi & Lo Beams // Skunk2 Shift Knob // EBC Slotted & Dimpled rotors w/ "Red Stuff" Ceramic Pads // Kenwood KDC-X890 Head Unit // 2 - 12" Kicker Comp VR & Kenwood KAC-X812D Amp |
#2 |
NO MERCY!
I believe you're supposed to leave the oil that came in the car in there for the first $5000 miles or until the oil life gets low. Then you can switch to full synthetic after the first oil life.
"May God have mercy upon my enemies, because I won't." -- General George S. Patton |
#3 | |
and change my synth every 3k
^ ^^ ^^^AND YOU CAN QUOTE ME ON THAT |
#4 |
NO MERCY!
Yeah i change mine every 3k miles as well, but the first change wasn't until around 4100 miles or so. I guess it varies with driving style.
#5 |
i use Mobil Clean 5000.
i did my first oil change at 3200, and just did the second one at 3900. i know the % is supposed to vary on driving style but at my last oil change (3900mi) my oil life was a 50%. If it varies on driving style... i must be driving like grandma.
'06 Civic Si FG Squad - Member #175 http://www.wallacealaniz.com http://images.honda-tech.com/set1/smile/emsmile.gif |
#6 |
recommendation is to leave the break in oil in there for around 5k miles...change with normal oil until 15k, then switch.
#7 | |
your not suppose to change from regular motor oil to synthetic if the car has more than 5,xxx |
#8 |
I heard after 10,000 miles its best to change to syn if you wish thats what i am doing i am at 8,900 k now after the next oil change i am going full mobile 1 syn !
FG Squad Member - #46 06 Nighthawk SI - Navi////HFP/Injen SRI//20% tint//Neuspeed//Skunk2//XenonDepot//Auger//DC//TWM//Progress//Nitto//Alpine//Ingalls//Megan Racing//Enkei//Rotora//Vis//Hawk |
#9 | |||
Fg Squad #78 Quote:
#10 |
You can change to synthetic literally whenever the hell you want!! The only thing with some synthetics is they have a higher solvency, so say you have a car with 80,000 miles on that you have used dinosaur oil on the whole time, well some of your gaskets (valve cover, oil pan, rear main, front main seal) may actually be sealing better because of a buidlup of of old oil and crud on the inside of your motor, now you put the synthetic in and because of its solvency starts breaking down and melting away some of the built up crud that was actually HELPING to seal your gaskets--now you have a better chance of a leak. Its not a guarentee of a leak--but its really the only reason misinformed people say "you can't switch to synthetic if you have been using regular oil for the life of the car"--the synthetic has absolutely no negative effect besides possibly giving you a greater chance for leaks.
That is why they have these "high mileage" oils for cars with over 75,000 miles--the rubber in the gaskets starts to harden and eventually crack from all the heat over the years, these oils actually have "swelling compounds" that are absorbed into the gaskets and actually cause them to swell up a little bit--which may help to seal a leak. Its the same stuff that is in gasket conditioners.
Cusco EF master cylinder brace-- brand new, unopened, still in package $75 shipped obo (RHD ONLY!!!) WTB: 88-89 Civic hatch driver side door w/ glass and regulator. Losi xxx4 G+ Associated Rc10 t4 FT Losi xxx BK2 JConcepts BJ4 WE |
#11 | |
#12 | |
I find it comedic that people think its a good idea to change the oil out sooner than they should. Honda engineered the maintenance minder system for a reason! Changing the oil out before the oil life is less than 10% is a waste of money and time.
<FONT SIZE="1">http://images.honda-tech.com/set1/smile/emcocktl.gif '06 Si. <FONT COLOR="gold">WORK</FONT><FONT COLOR="blue">emotion</FONT><FONT COLOR="red">.HFP</FONT></FONT> |
#13 |
If you switch to synthetic to soon, before the engine has broke in, the rings won't seal properly, and you'll end up burning oil. Just wait til the engine has been broken in, then you can switch at anytime.
FG Squad #149 |
#14 | |||
Fg Squad #78 Quote:
#15 |
where does it say you must/ or cant use snyt. before being break in ? i did sny oil in 1,300 miles or so
MY CAR DOMAIN MYSPACE 06 CIVIC EX ASM Black LED Halo Projectors Altezza Black Tail Lights AEM CAI TINTED windows 5% rear 20 % front 225/40/18ZR DRAG DR11 BLACK GLOSS CHROME LIP NEXEN EIBACH PRO KIT FG Squad#242 |
#16 | |
NO MERCY!
Someone correct me if i'm wrong though.
#17 |
Yes i was told by everyone it s a special oil with break in additives changing it at 10% is ludacris i would never take that risk the lowest i go is 20% but i change it every 3500 miles anyway.
#18 |
vouch: b u n m a n g o, MHZ2010 rip randy G... 2008 CBR 600RR Graffiti Black: http://honda-tech.com/showthread.php?t=2466007 |
#19 | ||
Whats ludicrous is that people like you waste money AND oil when they don't need to.
#20 |
i had an EF with 330,000 on it, about 50k is from me. A college professor taught me something that made alot of sense. If you change your oil at 3000 miles, you will sometimes forget where you are if yo dont write it down. if you changed your oil every 2500 miles, you would never forget.
ex: 10,000, 12,500, 15,000, 17,500 etc because in 3000 increments, it could be 11,000, 14,000, 17,000, 20,000, 23,000. if in 2500 increments, you always know where you are. even with the maintenence minder, the tech or you may have forgotten to reset it. the 2500 increment system is fail proof. but it can get a lil pricey with synthetic oil : P
#21 |
The minder doesn do anything but help you keep track of the milage. Why would it go to megative mileage??? My first oil change at 600 miles (as stated in the manual) was done at the dealership and when I picked up the car the mainder was reading at 20% it only resets itself if a person does it. To me, if it actually read how good/bad your oil was then it would change it self.
My 2 cents
#22 | |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">My first oil change at 600 miles (as stated in the manual) was done at the dealership and when I picked up the car the mainder was reading at 20% it only resets itself if a person does it. To me, if it actually read how good/bad your oil was then it would change it self. </TD></TR></TABLE> Where in your owners manual did it state to change the oil at 600 miles? And yes the MM must be manually reset, doesn't seem all that complicated to me tho? Believe it or not the car DOES actually tell you how good or bad your oil is... thats the point of the system
#23 |
my first oil change was at 3000 miles now i change every 1500! i use royal purple the shits expensive about 8 bucks a quart but changing the oil early and using expensive oil to me is worth it to extend the life of the K20!btw try puttng an s2k oil filter on it has better clean compacity and it fit perfectly!
06 Galaxy Grey Civic Si Coupe No Navi http://images.honda-tech.com/set1/smile/emthup.gif AEM Cold Air Intake http://images.honda-tech.com/set1/smile/emthup.gif 16% Tint All Around http://images.honda-tech.com/set1/smile/emthup.gif Custom Cat-Back Exaust System w/Custom Catylic Converter http://images.honda-tech.com/set1/smile/emthup.gif HFP Lip Kit http://images.honda-tech.com/set1/smile/emthup.gif Yellow JDM Fog Lights http://images.honda-tech.com/set1/smile/emthup.gif Smoked Headlights & Taillights http://images.honda-tech.com/set1/smile/emthup.gif Tein S-tech Drop Springs http://images.honda-tech.com/set1/smile/emthup.gif Friends-Any Si Enemy-Any RSX The K20 War Begins! |
#24 | |
#25 | |
| Bookmarks |
| Tags |
| acura, additive, audi, bad, brakes, breakin, engine, factory, honda, maintenance, metal, minder, oil, shards, tsx |
