#1 | |||||
#2 |
Put them in as soon as possible, otherwise your header will crack. I put mine on at the same time so I can't tell you how long you are good for. But I have seen several cracked headers. The install isn't as bad as it may seem, I dropped the subframe a coule inches and bam, in they went. You will most likley need to get an alignment when you are done, so if you need to install spings/struts/coilovers, do it all at the same time.
#3 |
Well you are half way there when you install the header. The ESMM are what 30$ and take maybe an hour more to install. It does help because it reduces engine movement which causes the header to crack. Your stock one has the springs around the screws and the new header. That flex pipe will take a beating if you do not put them in.
I say put them in and call it a day. If it is a DC sports header they will not cover it under warrenty if you do not have the ESMM.
-05 Yamaha R6 -97 Saturn SL1 |
#4 |
esmm will save your flex pipe.
*JDM Fronted EP3 Keeping it Clean and not expletiveing it up. Check out my Flickr! http://www.flickr.com/photos/fmarkovich |
#5 |
ESMM (Energy Suspension motor mounts) will also make your car vibrate at every stoplight. Gets kinda annoying, especially when you have the A/C on.
When under power it is fine, but the harmonics under 1000RPMs is really anoying. But to answer the question--as everyone else has said--definitely install them if you put on a race header. |
#6 | |
#7 | |
#8 |
I have both, the torque damper and the esmm's and my car vibrates like hell but its worth it for the stiffness...
#9 |
Right on guys, I ended up getting the ESMM. Ill post about how it ends up working out.
Hope this helps my autocross times
#10 |
#11 | |
///Mugen 無限 Equipped "Obsessed is a word the lazy use to describe the dedicated."- Arnold Schwarzenegger |
#12 |
So when getting a RH, definately get ESMM's. How hard of an install are they?
#13 |
#14 |
what the reason why you need an alignment for dropping the subframe a little and just inseting the esmm's??
#15 |
they are not hard to install, just hard to get the motor mounts out since there is hardly any room to do anything where the mounts are located.
Redline Time Attack SFWD RSX Type S #37 5th MFWD Autoclub Speedway 2008 Special Projects Motorsports, PCI, Amsoil, Blueprint, Spy Optic, LF.com, Innovative |
#16 | |
You answered my next question too.
#17 |
Definately get esmm. DCRH's are notorious for the flex pipe breaking as is
#18 |
*I have an EP3* with a DCRH that didn't crack w/o ESMM for 6 months so you probably didn't damage your's. Now I have Innovative mounts and a torque dampener
![]() (May sell torque dampener - PM if interested)
Selling my k20a2 ep3: http://www.hondamarketplace.com/show....php?t=2670508 FS: Parting out a 2002 White Pearl RSX Type S (Titanium interior). LMK if you need anything. |
| Bookmarks |
| Tags |
| 19, dc, esmm, fs, header, headers, install, konig, nj, ohio, race, raceheader, rsx, run, sale, sports, type |
