#1 | |||||
#2 | |
POS civic krew #001 |
#3 |
sweet.......thank you so much.....
#4 | ||
let me try to break this down...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">my exaust is a dc sports 4-1 header going to a 2 1/2 apexi world sport2. i running a jdm J1 cable tranny for now. as far as my bottom end goes. i have a set of eagle H beam rods im usings. (now im a bit concerned because i heard an old desine of eagle used smaller rod bolts and they suposedly still break??? god i hope thats a mith.... lol )there brand new been sitting on the shelf waiting. </TD></TR></TABLE> i would get a better header with a 2.5'' collector. the eagle rods with the smaller 5/16 bolts are fine if you're not throwing a lot of power at them. they break in boosted setups making lots of power. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i talked to a good machine shop here in brevard (Scovals in merritt island.) and he said it will cost about 80 bucks to bore it out and 150 to balance everything in the bottom end but he wont blueprint it due to the fact that he said its alot of pointless work that usually only is done to sell a motor and if i plan to street it whats really the need. </TD></TR></TABLE> it sounds like he's just being lazy and doesnt want to do the work. blueprinting is always a good idea to make sure all clearances are within spec. i would go to a different shop if that's what he's telling you. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">im basiclly to the point where all i need to get the motor running is GSR head studs, Pistons, and the machine work done to the bottom end. another thing im not sure about is which ecu to run. i own a jdm p30 and also have my hands on a p28. theres a local guy who is supposed to be real good at tuning using chrome but i dont know if i want to go with him or someone maybe from orlando. i would really like to find someone who can give me a good tune using the jdm p30. </TD></TR></TABLE> either one of those ecu's can be chipped if they're obd1 so it doesnt matter which one you use. find a good tuner and let him handle it. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i think my compression will be around 12.5:1. not exacally sure but i know i was to run as high as compression as i can and still run 93 pump gas. i hear it hard to get that high but with a good tune its possible.</TD></TR></TABLE> it's possible, but why not go with less compression and make more power running more timing and be safer with it? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> i would like to be able to rev high and still be relyable. i dont plan on beating it everyday but it will be a daily driver and i want the power to be there. as far as race. i would rather be set up for auto cross than drag. drag is fun but i think it will get old quick and auto cross interests me more but i would still like to shoot for 13s or 12s in the quarter in a 92 civic cx hatch. </TD></TR></TABLE> i would be more worried about suspension if auto-x is your thing. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">maybe im asking a bit much. aspecially since im even wondering if i can spray for turbo later on while being that high of compression. let me know what you think. and hopefully someone will drop me that link. nate </TD></TR></TABLE> you can boost with high compression but you have less room for error when tuning. you better have a very good tuner. hope this helps ![]()
#5 |
dooooooooood.... lol thank you, what do you think about the block choices? should i use the good 81mm block or bore the 2nd block to 82mm. i dont want to sleeve. but i am thinking of thorwing in a block guard. i have heard 82 is largest recomended to go without sleeving?
#6 | |
i'd use the block you have now and keep it 81mm. but, how bad are the cylinders in the other block? see if you can do a slight overbore to 81.5mm to clean them up. if you can do that use it so you minimize downtime.
#7 |
any others???
| Bookmarks |
