> Suspension
Old 01-15-2007, 09:18 AM   #1
tecnic1
tecnic1's Avatar
Send a message via AIM to tecnic1
Default pic request: diy extended top hats.
All of the pics in the archived threads are dead. I am planning to extend my top hats, but would like to see some pics to clear a few things up.
thanks.
-<FONT COLOR="red">brandon...</FONT>
tecnic1 is offline Report Post   Reply With Quote
Old 01-15-2007, 10:16 AM   #2
chrisdavis6
chrisdavis6's Avatar
Default Re: pic request: diy extended top hats. (tecnic1)
Very Interested too.
I found this pic in a 12 page thread on this topic
http://www.honda-tech.com/zerothread?id=469485
However, all of the other pics that go along with the DIY seem to be broken links.
Maybe if someone PM's K. BENEN or 2.0L EK they will hook us up and we
can host the pics in this thread, or just fix the links in the original DIY thread.
EDIT: I just contacted one of the members who created the DIY and he said he no longer has the photos.
There is another mod that im very interested in doing as well, Move you rear shock down
so that your springs dont see full extension, this will insure that your rear springs
constantly have load on them and you dont have to worry about you rear springs coming unseated.
EDIT: Without the pics this doesnt make sense. If you move the shock down, wouldnt that create more space for the springs to come unseated??
Modified by chrisdavis6 at 1:30 PM 1/15/2007
Modified by chrisdavis6 at 2:01 PM 1/15/2007
chrisdavis6 is offline Report Post   Reply With Quote
Old 01-15-2007, 10:59 AM   #3
Tyson
Tyson's Avatar
Default Re: pic request: diy extended top hats. (chrisdavis6)
btw, youre talking about a separate mod than the top hats. its cutting off the brake bracket to get more shock travel on the front shocks.
and the springs becoming unseated shouldnt be a concern. the shock wont fully extend while driving, unless you totally jump off a cliff.... especially if you have a swaybar holding the inside suspension up.
adding an extended top hat actually does the opposite effect. which can lead to coil bind or too much preload if the spring length is too long.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 01-15-2007, 11:04 AM   #4
chrisdavis6
Default Re: pic request: diy extended top hats. (Tyson)
Yup, I was actually interested in both mods, Top hat extesion for front and
the Full Droop Mod for the rear.
If you read my post it says there is another mod i would like to do as well.
So you are saying in addition to the Top Hat extension for more shock travel, you
can ALSO cut off the brake bracket to get more shock travel on the front?
This would let the shock sit lower in the fork right?
Old 01-15-2007, 12:41 PM   #5
Tyson
Tyson's Avatar
yeah, but doing both is redundant. its "either/or" in my opinion.
Old 01-15-2007, 01:13 PM   #6
tecnic1
tecnic1's Avatar
That pic more or less answered my questions. I was not sure where to cut the stock tophat..
I read that people are using 2 inch OD tubing, but the 2 inch I have looks like it would be a really tight squeeze into the chassis...
Old 01-15-2007, 01:17 PM   #7
chrisdavis6
I totally understand that, I would like to do the Top Hat extension in the front, but the
Brake line bracket mod seems like it would be easier.
Is there any advantage to the top hat extension over the brake line bracket mod
to increase shock travel in the front?
Old 01-15-2007, 01:22 PM   #8
Tyson
Tyson's Avatar
extending the top hat brings it closer to adding preload and may require a shorter spring. if you use a shorter spring, its not an issue.
this actually may be of benefit in the rear where i used a shorter spring anyway.
in the front, i found it sufficient to do the brake collar mod to get more travel and set a lower ride height. i did find it limited how high i could go tho. like i tried to raise it up and found the spring too preloaded and hard to adjust any further.
Old 01-15-2007, 03:35 PM   #9
Big Teggie
Big Teggie's Avatar
Send a message via AIM to Big Teggie
Here are some pictures of the ones I did for myself...
Big Teggie is offline Report Post   Reply With Quote
Old 01-15-2007, 04:49 PM   #10
kcjohnnyboy
1999 Acura Integra
kcjohnnyboy's Avatar
Send a message via AIM to kcjohnnyboy
Default Re: pic request: diy extended top hats. (Big Teggie)
what size piping did you use? ID and OD measurements please if you remember?
i'm working on doing this mod myself but cant figure what size piping
kcjohnnyboy is offline Report Post   Reply With Quote
Old 01-15-2007, 05:41 PM   #11
Big Teggie
Big Teggie's Avatar
Default Re: pic request: diy extended top hats. (kcjohnnyboy)
I used 2" but the fit was really tight. I needed to grind some of the paint off the stock top hat openings.
I made a few other sets with some sch 10 pipe which has an OD of 1.9" and they fit well.
Old 01-15-2007, 05:46 PM   #12
tecnic1
tecnic1's Avatar
2 inch is really tight...
I test fitted it over the top of the top hat, and it seems barely too big. I guess we'll see.
Old 01-15-2007, 07:30 PM   #13
kcjohnnyboy
1999 Acura Integra
where do you go out to buy sch 10 pipe which has an OD of 1.9"?
Old 01-15-2007, 09:15 PM   #14
Big Teggie
Big Teggie's Avatar
Default Re: (kcjohnnyboy)
You can make it fit, just do some grinding to the top hat mount.
Local metal supply warehouse.
Old 01-16-2007, 05:27 PM   #15
happyabortion
happyabortion's Avatar
Send a message via AIM to happyabortion
Default Re: (Big Teggie)
does anyone have any pix of the other mod about cutting off the brake bracket??
WTB a PAIR of RC Starks! Fully built b16a block for sale!! http://www.hondamarketplace.com/show....php?t=2615375
98-01 INtegra DB8 rear valances http://hondamarketplace.com/showthread.php?t=2623415
happyabortion is offline Report Post   Reply With Quote
Old 01-18-2007, 10:46 PM   #16
TEGNO1
TEGNO1's Avatar
Hi i tried putting a 50mm pipe through the hole and it wouldnt go through, a 48mm pipe goes through but still touches the sides, it would be good to go 50mm wide if someone knows how, cause my shocks are 45mm, so 48mm substract 2mm thick piping that doesnt leave much room for the shock to slide in if needed, i also measured around 50mm high before contact to my hood, and that doesnt include the thread and adjuster, so im gonna drill my bonnet out to get some clearance for the thread part and give me some extra height, later.
TEGNO1 is offline Report Post   Reply With Quote
Old 01-20-2007, 05:55 PM   #17
Audi RS4
Lover
Audi RS4's Avatar
when did you learn how to weld?
Glock 9X19..... http://images.honda-tech.com/set1/smile/emwink.gif
06' CBR600RR
03' Audi A4 1.8T Quattro (BEAST)
Jack "YACK" Harris & P1 Auto http://images.honda-tech.com/set1/smile/emthup.gif
PLEASE HELP ME!
Taking $1 to $5 donations. Paypal 03Audi@comcast.net Any help is appreciated.
Audi RS4 is offline Report Post   Reply With Quote
Old 01-20-2007, 07:26 PM   #18
tecnic1
tecnic1's Avatar
Default Re: pic request: diy extended top hats. (Audi RS4)
Last summer. My boss sent me to school and bought me a mig welder..
I used the 2" tube, but I ended up having to grind on the inside of the shock tower a little. Not a lot, but basicly remove the paint and maybe increase the diameter by 1/32.
Of course I didn't take pics. i suck.
Old 01-20-2007, 10:04 PM   #19
VRD^don
VRD^don's Avatar
i did some awhile back...using exhuast tubing..i know..its not safe..but so far its held up for 3 years now..some hard auto-x..daily driven on some harsh roads...its held quite good...dont worry...the supsension setup going to be changed over the winter...
OLD^skool
VRD^don is offline Report Post   Reply With Quote
Old 01-21-2007, 09:33 AM   #20
gabebauman
1993 Honda Civic
gabebauman's Avatar
Send a message via AIM to gabebauman
Default Re: pic request: diy extended top hats. (k_motor)
I gave my dad, (who has been a welder for 35 years) a spare set of oem upper mounts to make some extended ones...I don't think he's started yet...but I'm sure he'll let me know what size material he uses. However...I will only need t use the rears, (if they work), because I just bought some GC mounts for the front.
MY EIGHT YEAR PROJECT...now I drive a 5th gen hatch.
gabebauman is offline Report Post   Reply With Quote
Old 05-22-2007, 09:20 PM   #21
Slystone
Slystone's Avatar
Default Re: pic request: diy extended top hats. (gabebauman)
un local friend here did a one piece one inch top hats at a good price!!
nice crafmanship
tpisly@hotmail.com
Slystone is offline Report Post   Reply With Quote
Old 05-23-2007, 07:08 PM   #22
defythemall
defythemall's Avatar
Default Re: pic request: diy extended top hats. (Slystone)
more info on these please
defythemall is offline Report Post   Reply With Quote
Old 05-24-2007, 08:40 AM   #23
Liquidgsr
Send a message via AIM to Liquidgsr
can you friend make me a 4 of those?
Muslim...and proud of it - DB SQUAD #29
94 DB8 aka POT HOLE with 174k making 160whp/118tq w/I/H/E.
Darkside - 2/10/08 178K 300whp/223tq 15psi boost
Stolen, stripped, and gone 4/19/08 RIP
Liquidgsr is offline Report Post   Reply With Quote
Old 05-26-2007, 06:59 AM   #24
blaak-crx
blaak-crx's Avatar
Default Re: pic request: diy extended top hats. (Liquidgsr)
This was a group buy thread in Canada: it is in french but you can contact the fabricator for more info. I will let him know about potentiel US buyers.
http://forum.clubcivicquebec.c...75795
ASE Lapping Club instructor (Montreal)
1991 Crx Si Special Edition, track use!
blaak-crx is offline Report Post   Reply With Quote
Old 07-08-2007, 02:01 PM   #25
Formisfunc
Formisfunc's Avatar
Send a message via AIM to Formisfunc
any for a 1990-1993 accord?
Function=<U>Form.</U> http://images.honda-tech.com/set1/smile/emthup.gif
Formisfunc is offline Report Post   Reply With Quote
Bookmarks
a4, buy, civic, crx, diy, extend, extended, extending, hat, hats, kit, rear, shock, top, tophats
