> All Motor
Old 01-12-2007, 05:42 AM   #1
7rrivera7
7rrivera7's Avatar
Default ? On buying ACL bearings for my LSVTEC build
The B18 engine is currently running fine. I'm going to remove it and rebuild it as an LSVTEC. I'm gathering the parts I need and I'm about to purchase an ACL Race Bearings kit. I'm assuming I need to purchase the standard size kit right?
...or do I have to take measurements after I tear down the block?
7rrivera7 is offline Report Post   Reply With Quote
Old 01-12-2007, 06:00 AM   #2
LSVTEC 91 Civic
Banned
They should clearance out perfect. Get the STD bearings.
LSVTEC 91 Civic is offline Report Post   Reply With Quote
Old 01-12-2007, 01:42 PM   #3
91SiZ6
91SiZ6's Avatar
Always take measurements. Triple check everything and assume nothing.
91SiZ6 is offline Report Post   Reply With Quote
Old 01-12-2007, 06:26 PM   #4
bambam
bambam's Avatar
Send a message via AIM to bambam
Default Re: ? On buying ACL bearings for my LSVTEC build (7rrivera7)
Ding ding ding.
-Vouches are in my Bio.
http://images.honda-tech.com/set1/smile/emthup.gif All-Motor Forum
'03 ABP RSX Type-S
NAVY. Out to sea until Early September. Sorry fellas.
bambam is offline Report Post   Reply With Quote
Old 01-13-2007, 04:47 AM   #5
ExospeedAMcrx
H-T Basic Sponsor
ExospeedAMcrx's Avatar
Send a message via AIM to ExospeedAMcrx
Default Re: ? On buying ACL bearings for my LSVTEC build (bambam)
Originally Posted by bambam
Ding ding ding.
haha. ya you cant assume that all blocks will measure the same. you never know, your ACLs may not even fit the clearances you need for your motor.
Exospeed Racing Products/Exospeed Racing Wheels(New 3piece wheels!) Exospeed 3 Piece Racing Front Ends.
New website up now. Work in progress! sales@exospeed.com
ExospeedAMcrx is offline Report Post   Reply With Quote
Old 01-13-2007, 11:05 AM   #6
BearsEK-KMSU
BearsEK-KMSU's Avatar
Default Re: ? On buying ACL bearings for my LSVTEC build (exospeedAMcrx)
If std. bearings worked every time it wouldn't be an import.
BearsEK-KMSU is offline Report Post   Reply With Quote
Old 01-13-2007, 12:04 PM   #7
Phil M
Phil M's Avatar
Send a message via AIM to Phil M
Default Re: ? On buying ACL bearings for my LSVTEC build (bearsEK)
There was this machine shop once upon a time I used to bring cylinder heads to... the guy that build the blocks didn't measure anytrhing. NOTHING. He used acl bearings and never even plastiguaged it, he said that they are always within spec. The word around San Diego is that his motors suck and aparently ALL aluminum pistons "will not work with street engines and smoke alot." Well, you can guess where I'm going with this. If you want to be lazy just buy a new engine from honda or dish out the cash to have it done right. Good luck with your build...
Phil M is offline Report Post   Reply With Quote
Old 01-13-2007, 12:34 PM   #8
bambam
bambam's Avatar
Default Re: ? On buying ACL bearings for my LSVTEC build (theyoungone)
Steer away from the uneducated employees at the shop.
'03 ABP RSX Type-S
Old 01-13-2007, 12:44 PM   #9
7rrivera7
7rrivera7's Avatar
I'll be buying bearing (standard, not race) after the tear down. Now I just need to e-educate myself on taking measurements and checking clearances. I really want to do this on my own
Old 01-13-2007, 03:20 PM   #10
91SiZ6
91SiZ6's Avatar
Open your repair manual to the section on Engine Overhaul. That will show you how to check your block, crank, and rods for the OEM bearing sizes as well as what to do with the Plastigage.
Since nobody's mentioned it, ACL/Cleavite/King/etc. bearings are sized for Honda's Green (middle) sized bearing. With bearings you can either have "within spec" with aftermarket bearings or you can have the exact clearance you want with OEM bearings. Food for thought.
Oh, and LS2 is the engine from the '05 'Vette...possibly other GM cars, but I don't feel like looking it up right now.
Old 01-13-2007, 03:31 PM   #11
ExospeedAMcrx
H-T Basic Sponsor
Default Re: ? On buying ACL bearings for my LSVTEC build (91SiZ6)
Bearing sizes are like choosing shoe sizes. You try and fit which size is the best for you, lets say yours is a size 10 shoe. But they only have a 10.5 for your left foot and 9.5 for your right foot. Both sizes may fit alright and I'm sure you can walk around with them. But both are not perfect. One is on the looser end of the spectrum and the other is on the tighter, but theyre not extreme that your feet hurt like a bitch.
ok guys this is a rough analogy, but I hope you get the picture. haha.
Old 01-13-2007, 03:37 PM   #12
7rrivera7
7rrivera7's Avatar
Hmm...repair manual. I need to add this to my list
I'm assuming Helms? Should be the Acura Integra LS. Need to couple this with a VTEC manual - should I get a 2000 Si?
Any good links on digital Helms manuals?
Old 01-13-2007, 03:59 PM   #13
DonF
Just curious, when you change the rod material to 4320 ( Eagle, Scat, Crower, etc.) and get the motor to temp. !90 water, 200 oil, is the clearance the same as using stock rods? Which expands more, less? What is the main Cl. at temp, Should the al. block and cast iron caps be taken into consideration? Would the clearances be the same for AL. or Titanium rods? The only numbers that matter would be under operating temperature. With better rods ( more consistant ) under temp. and load what do you do?
DonF is offline Report Post   Reply With Quote
Old 01-13-2007, 08:27 PM   #14
Phil M
Phil M's Avatar
He was the owner.
Old 01-13-2007, 09:29 PM   #15
BearsEK-KMSU
Default Re: ? On buying ACL bearings for my LSVTEC build (DonF)
But i think if you start with the same clearances they will at least grow or shrink within the same spec other than buying a std set of bearings and having the clearances up and down, I don't think most people grind honda cranks dead nuts on every journal then re-nitride them and most od the time the main bores aren't perfect. just my 2 cents.
Old 01-13-2007, 10:19 PM   #16
bambam
bambam's Avatar
What about bi metal vs. tri metal bearings? Do they expand at different rates? Or different bearing manufacturers, are they chemically the same and expand at the same rates? What about different oils? Different oils expand at different rates as well. This is a VERY good question...one of the better that has been asked for awhile actually. Thanks Don.
'03 ABP RSX Type-S
Old 01-13-2007, 10:20 PM   #17
bambam
bambam's Avatar
He was the owner.
In that case, you should shit in his bushes. If he has them, of course.
'03 ABP RSX Type-S
Old 01-14-2007, 03:58 AM   #18
7rrivera7
7rrivera7's Avatar
Old 01-14-2007, 11:43 AM   #19
DonF
Thougt you might like it. Carrillo and Oliver are the only rod mfg. that gives a theoretical cl. with their rods. Your cl. is the tighest on start-up so what oil do you use, especially if you are planning on switching to synthetic? How about if you have .0015 crank runout on the center main, what cl.?
Old 01-14-2007, 03:31 PM   #20
The Destroyer
The Destroyer's Avatar
So what tool is used to measure clearances? And whats the process?
SM Prepped EG8.
The Destroyer is offline Report Post   Reply With Quote
Old 01-14-2007, 06:01 PM   #21
The Destroyer
Default Re: ? On buying ACL bearings for my LSVTEC build (Skeletor!)
I know you can use plastigauge, but that means you already have bearings. What if the bearings arent the correct clearance? Where do you go from there?
SM Prepped EG8.
Old 01-15-2007, 06:10 PM   #22
91SiZ6
91SiZ6's Avatar
for answer.
Combustion Contraption made a good post about it. Search it out.
Old 01-15-2007, 06:33 PM   #23
bambam
bambam's Avatar
for answer.
Same here. I've never even thought about it, and it's scary to even try.
'03 ABP RSX Type-S
Old 01-15-2007, 06:59 PM   #24
The Destroyer
TY, that was a very good read.
SM Prepped EG8.
Bookmarks
2006, accord, acl, b18, bearings, build, code, engine, honda, operating, temperature, under
