> Honda CRX / EF Civic
Old 06-13-2007, 02:06 PM   #26
dr_latino999
Global Instigator
dr_latino999's Avatar
Send a message via AIM to dr_latino999
Default Re: 90 (Wes V)
Originally Posted by Wes V
The only question I've got at this point is if both hubs have the same diameter raised section, where the hole in the rotor fits, is the same.
Wes
<FONT SIZE="2">EX Hub</FONT>
<FONT SIZE="2">SI Hub</FONT>
So, now I've got to find out how I can order beer over the internet.
Wes
I think there may be some legal issues shipping Alcohol over state lines, but if we ever cross paths I'll be sure to let you buy me a mug
One Step closer to finishing my short block: "Houston, 77mm CP's are in the sleeves, over."
Project D16 On Crack
dr_latino999 is offline Report Post   Reply With Quote
Old 06-13-2007, 02:16 PM   #27
Wes V
Wes V's Avatar
Default Re: 90 (CRX Toad)
Originally Posted by CRX Toad
Wes while you are shopping for head lights in Italy see if they have the hubs. Maybe they can ship you some vino.
Dang, I wish I was the one going to Italy. It's an architect that I work with and he is getting a free "visit" to one of the door and window manufacturers there. Ya, they are paying for the whole trip. And no, they are not the same type windows that you get at Home Depot. (I'm a Structural Engineer and I do real high end residential stuff in Montecito, near Santa Barbara)
Wes
Wes V is offline Report Post   Reply With Quote
Old 06-20-2007, 03:33 PM   #28
Wes V
Wes V's Avatar
Well, I went out and bought all my parts. New bearings, new SI hubs (and lug studs), and new DA rotors.
I'm thinking about making a "collar" to fill the gap between the rotor center hole and the raised section on the hub (although I don't really know if it's important).
This kind of brings up the next question;
If somebody was starting with an SI knuckle, what would it take to bolt up the DA caliper and have it line up correctly? (this doesn't apply to me due to already having EX knuckles)
Wes
Old 06-22-2007, 01:30 PM   #29
dr_latino999
Global Instigator
Wes, I should be able to provide an exact answer to this question in July hopefully as I will have a pair of SI knuckles and an extra set of DA Calipers to play around with.
Old 06-22-2007, 01:50 PM   #30
Zaakro
Zaakro's Avatar
Send a message via AIM to Zaakro
Wes
so hes not going to look at some Pella windows?
2002 Honda S2000 - Daily Driver
91 Civic Hatchback Si - R.I.P.
EF Civic parts for sale http://hondamarketplace.com/showthread.php?t=2594892
Zaakro is offline Report Post   Reply With Quote
Old 06-22-2007, 07:48 PM   #31
Boosted Chemist
Boosted Chemist's Avatar
Wes
Well there is a write up in faq, si knuckles + 10.3" rotors and itr calipers (trim 3mm off the bracket to line them up. Kinda like itr caliper onto da/dc knuckles with 11" redrilled 4x100 lude rotors.
Fullrace powered, Garret blown, Rywired, Evan's tuned, Mugen equipped
Boosted Chemist is offline Report Post   Reply With Quote
Old 06-22-2007, 08:15 PM   #32
esteen2
esteen2's Avatar
Default Re: 90 (Boosted Chemist)
With all this talk about hubs, and what will fit, (not trying to hijack this thread) I have a question, will si hubs fit on a civic std with small spline hub knuckle's?
esteen2 is offline Report Post   Reply With Quote
Old 06-23-2007, 01:17 AM   #33
bmg123
bmg123's Avatar
Default Re: 90 (S2R Honda)
I have two sets of EX knuckles for two of my cars and I am in the process of pressing in new bearings and ball joints for one set. I plan on reusing the original hubs. I didn't think the hubs were a part that wears out or needs to be replaced.
How do I know if I need to replace my hubs?
bmg123 is offline Report Post   Reply With Quote
Old 06-23-2007, 08:44 AM   #34
Wes V
Wes V's Avatar
Default Re: 90 (bmg123)
bmg123;
In a perfect world, hubs would never go bad or wear out.
The problem is if the car has ever been in an accident, it's possible to slightly bend the hub so that it doesn't run as true as it should (which is the problem that I have).
If the hub isn't true, then the rotor that mounts to it, also will not run true.
This is something that you can't tell by just looking at a hub. If you had hubs off of the car and wanted to check them, you would have to put them in a lath and use a dial indicator to measure "run-out".
If you bought a used knuckle (spindle) with hubs installed, you should use a dial indicator to verify that the hubs spin true. The factory manual gives the allowable run-out value.
If you have new hubs installed or are just replacing the bearings, you should have the run-out checked before you leave the machine shop! (if the machine shop has a lath, the hubs should be verified before pressing them in) It's possible (and I know it does happen) for a hub to be "bent" while being pressed in!!
If this happens, then the hub has to be replaced along with it needing a new bearing. If this happens, the machine shop should pay for any "damage" done while doing the press work. Something to make clear to the shop prior to doing the work.
Wes
Old 09-09-2007, 06:50 PM   #35
Wes V
Wes V's Avatar
I finally got around to doing the SI hub on EX spindle swap.
It all works but I decided to also make up a spacer / indexing collar between the hub and rotor.
Here is a complete write-up.
http://www.performanceforum.co....html
I really want to say thanks to both dr_latino999 and steronz for their input.
Wes
Old 10-15-2007, 07:04 PM   #36
#1nismo
#1nismo's Avatar
Send a message via AIM to #1nismo
for all you guys out there redrilling prelude vtec rotors, look into VW corrado G60( i think ) rotors they are the same size and already have the 4 x 100 bolt pattern. again im not sure if its that exact model bt i know for sure the rotor is off the corrado
#1nismo is offline Report Post   Reply With Quote
Old 12-04-2007, 03:40 PM   #37
Jared
Jared's Avatar
What is the outside diameter measurement of each hub? how much bigger is the ex?
ASE Master Technician - L1
Nissan Master Technician
GTR Certified
AEM Factory Trained
Jared is offline Report Post   Reply With Quote
Old 12-04-2007, 03:57 PM   #38
dr_latino999
Global Instigator
Default Re: (Jared)
EX Hub = 5.475"
SI Hub = 4.775"
Old 12-04-2007, 04:03 PM   #39
Jared
Jared's Avatar
Default Re: (dr_latino999)
Originally Posted by dr_latino999
EX Hub = 5.475"
SI Hub = 4.775"
thank you. is there room in the 90-93 teg/EX front rotor for a bigger hub? thanks!
GTR Certified
AEM Factory Trained
Old 12-04-2007, 04:20 PM   #40
dr_latino999
Global Instigator
Default Re: (Jared)
No, the stock rotor fits snug on the EX spindle.
Old 12-04-2007, 06:11 PM   #41
Jared
Jared's Avatar
Hmm, I wonder if there is a rotor that will allow a bigger hub but still a small enough rotor to allow a 13" drag wheel. the integra setup is damn close to the wheel now and has a spacer.
GTR Certified
AEM Factory Trained
Bookmarks
89, civic, corner, crx, door, dx, hatchback, hoda, honda, hubs, interchange, light, pictures, rotors, sh4, spring
