#1 | |||||
#2 |
bump, I need to know this too
J2ned Turbo Kits - You'll See... |
#3 |
Moderator
Wes, you don't know? Man I am shocked I thought you knew all. I learn from your website.
I wonder if Tyson or Targa knows. I know that I read something about swapping hubs over in the RR/AX forum. I'll see if I can dig it up. http://www.honda-tech.com/zerothread?id=824838 http://www.honda-tech.com/zerothread?id=992212 http://www.honda-tech.com/zerothread?id=913543 http://www.honda-tech.com/zerothread?id=1263038
Hondworks Need a write up on how to fix your CRX cracked climate control, PM me |
#4 |
wes, i thought you went thru this all before. i would have told other ppl to go to YOU for answers....
actually i dont know the answer myself. ive sold several sets, never actually used them. i know ryan (rywire) will know. he's done 5 lug conversions for customers. that requires hub swapping, so he might be familiar with whats already on there and is compatible.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
#5 |
Moderator
Dang Tyson you don't know either....what is HT coming to Wes, you and myself and we don't know. I hope the space time continum doesn't screw up.
#6 |
i just got new bearings and had my Si hubs pressed in... didn't even think to check the part numbers. now i'm worried... so far everything fits, but I don't have the brakes on yet.
edit - i just need to pick up some DA caliper brackets, which i have planned for tomorrow, and i'll be able to mock everything up and tell you how successful the Si hubs are.
I drive a 4 door Integra. I drive it slowly because I'm no good. It's maroon and boxy. |
#7 | |
Moderator
#8 |
ZCspeed Racing |
#9 | |
pictures on request... got everything put on today. the setup is: EX knuckles, bearings, DA/EX rotors, caliper brackets, and calipers. Si/DX hubs.
#10 |
be professional
Wes, did you have your Honda parts dealer do a locate on the EX hubs? They are sure there are none left in the country?
For reference, the EX knuckles use the same small wheel bearing as the Si/DX/LX knuckles, and not the larger Integra wheel bearing - which is why the bearings and hubs don't have an SK7 part number. However, I'm not sure why they aren't listed as the SH1 (Si/DX/LX) parts. Have you tried physically comparing the SH4 (EX) hubs with the SH1 hubs? Are there any dimensional differences that would pose a problem? Additionally, does anyone know if the EX knuckles could be bored out to accept DA wheel bearings and hubs? I don't have any EX knuckles in stock to check, so I don't know if this would be possible.
1991 Civic | 1998 CB750 | 2001 Integra | 2005 Giant Trance 2 | 2009 Redline Conquest Pro |
#11 |
jlicrx; Thanks for the link to the diagram, but I've already got it.
Targa250R; I'm real good friends with the local Honda Parts manager and he did a complete search for them. As for comparing one against another, it's difficult due to the fact that the car is all together and I can't take dimensions off of the existing hub. I also don't know if the inside diameter of the SI bearing (same as EX) is larger or smaller than the DA one. If the DA bearing has a larger inside diameter, then it may be possible to take a DA hub and turn it down to fit the SI bearing. I know this sort of thing is done when converting to 5 lug. Thanks for everybody's input. |
#12 |
Moderator
I assumed you were talking about all Si kunckles and hubs. Sorry for the confusion.
Wes or anyone when the answer to this is actually found please post the follow up info up so that we know. I say this in regards to the 5 sets of EX knuckles on cars that I will/have worked on for myself and friends.
#13 |
i figured the context of the thread would make things clear, but i should have specified. no harm.
so here's the picture i took this afternoon... nearest i can tell, whatever differences there are between the Si/DX/LX hub and the EX hub, it doesn't affect the operation of anything. everything bolted up just fine, the rotor turns freely, etc. i'd be interested if someone found out why they're different part numbers, but i declare the two to be interchangeable. ![]() ^^ EX knuckles, Si hubs
#14 |
Global Instigator
So is the official conclusion for now is that the DX / LX (44600-SH1-A00) hub is a suitable replacement for the EX wheel hub (44600-SH4-A50)?
FIXED Modified by dr_latino999 at 1:35 PM 1/13/2007
One Step closer to finishing my short block: "Houston, 77mm CP's are in the sleeves, over." Project D16 On Crack |
#15 | |
be professional
I really don't see any problem in using the SH1 hub; it seems to install fine, and any dimensional difference would have to be in the diameter of the brake rotor backing plate (that the wheel studs are pressed through). Since the wheel studs and rotor screws locate the rotor - and rotors are also hubcentric so they sit on the lip in the center of the hub if you don't use rotor screws - I don't think it would pose a problem if it was different. I'd go ahead and order SH1 hubs. Make sure to take pictures or measure dimensions when pulling the old SH4 hubs off and compare them to the new SH1s, so we can settle this discussion.
#16 |
Global Instigator
Oh ya, I think I meant hub but was looking at the bearing on the parts diagram, time to re-edit
#17 |
Global Instigator
Bringing this back up as I'm now replacing the hubs on both sets of EX Knuckles I have. I have contacted a local Honda Dealer about having a new SI hub delivered to the dealer so I can see for myself where the difference is in the part numbers. I see that steronz used this setup successfully, but I'm hesitant to jump right in and purchase 4 SI hubs and have the offset or some other minute factor changed. Call me worrisome
Wes, what did you end up using in the end?
#18 |
Moderator
There are some hardened race ones on the market too. I think OPM makes them. So you are going to replace the hubs int he EX spindles/knuckles? I am interested to know if this will work. Make sure you let us know the results.
#19 | |
Global Instigator
I have purchased a SI hub, hopefully I'll have it at the end of next week for pictures.
#20 |
I still haven't done anything in regards to my EX hubs and really can't wait to see what dr_latino999 comes up with.
Possible things that could be different would be the "offset" of the surface that the rotor bolts too. A difference would cause the rotor to sit further outward (or inward). Another possible difference would be the center indexing section. In other words, does this match the ID that is present on the DA (or EX) rotor. Things we can rule out; the bearing surface is the same (Si same as EX) due to using the same bearing. The lug spacing is the same (4X100). I'd REALLY like to feel comfortable about ordering a set of SI hubs. Who is "OMP" and do they have a cross-reference that can be used? Do they list an "EX" hub? It's nice that steronz was able to bolt up everything (really gives me hope). However due to the fact that the caliper is a floating design, it would offset to match the rotor placement (not necessarily a bad thing). Also, in his photo, it doesn't look like the center indexing section is smaller than the hole in the DA rotor. I REALLY approciate everybody's help! Wes V |
#21 |
Global Instigator
I come bearing gifts, information, and part numbers
![]() <FONT SIZE="2">SI Hub vs EX Hub Top View</FONT> ![]() <FONT SIZE="2">SI Hub vs EX Hub Side View</FONT> ![]() <FONT SIZE="2">EX Hub inside 10.3" Rotor</FONT> ![]() <FONT SIZE="2">SI Hub inside 10.3" Rotor</FONT> ![]() The only difference that I can find between the two hubs is that the face is smaller on the SI hub. I am now confident to say that the SI hub (44600-SH1-A00) is a suitable replacement for the EX hub.
#22 |
Moderator
Wes,
OPM has hardened hubs available since the OEM ones are prone to letting loose in racing conditions. http://www.opmautosports.com/index.html Hummm so the Si is a tad smaller. There is hope for good replacement.
#23 | ||
Global Instigator
#24 |
The only question I've got at this point is if both hubs have the same diameter raised section, where the hole in the rotor fits, is the same.
The smaller diameter on the SI provides less support for the studs (less material around the stud), but by no means is this a step backwards from what came originally on the car. In other words, the EX hub would be better if it was possible to buy them. So, now I've got to find out how I can order beer over the internet. Wes |
#25 |
Moderator
Wes while you are shopping for head lights in Italy see if they have the hubs.
Maybe they can ship you some vino. This has been added to the FAQ so please make sure the pictures don't turn into red boxes.
| Bookmarks |
| Tags |
| 89, civic, corner, crx, door, dx, hatchback, hoda, honda, hubs, interchange, light, pictures, rotors, sh4, spring |
