#1 | |||||
#2 |
Read through the forum. There's lots of info on this subject.
Try the all motor forum. There are tons of info there. Even a couple of threads with an exact part list.
Homeowner 07/01/2007 http://images.honda-tech.com/set1/smile/emthup.gif 1998.5 BMW M3 e36 Estoril blue 10/15/2008 http://images.honda-tech.com/set1/smile/emthup.gif 1992 Honda Civic VX w/OBD1 GSR Swap BAR Certified 11/16/2006 http://images.honda-tech.com/set1/smile/emthup.gif XBOX Live GT = JayCue45 |
#3 |
ls vtec raises your compression mainly because you also need to add vtec(b16) pistons.
im not sure exactly where power is gained if it even is ls low-end vs lsvtec low-end? and ls high-end vs lsvtec-vtec? i have never seen this stated
( )( ) ( 0'o) WAT (/--) |
#4 | |
1994 Honda CivicMy Garage Join Date: Mar 2005
Location: chillin on brighton ave sippin wawa peach iced tea in my eg
vTeC pIsToNs y0!!!11!!!! w3rd
#5 |
lsvtec
B18a/b block with a B16a/b or b18c1/c5 some might argue it makes more power then a B18C1 I'm about to add vtec head on my LS this spring
92 Custom Black EG8 Stock Winter Beater 92 <FONT COLOR="red">Imola Red</FONT> EH2 on 15" Mugens B18B with a GT28R dyno tuned at 211WHP 187lbs @ 10psi 13.4 @ 106 street tires I'm am a JDM whore |
#6 |
is it the same only until you hit vtec?
how would an ls turbo rate against a lsvtec turbo?
#7 | |
Hardparker Extraordinaire -Kswap Certified- k20a.org circuithero.com Have you driven your Special K today? DBSquad #216 |
#8 | ||
here's a nice graph showing what can be gained from doing a proper lsvtec ![]() from this thread: http://www.honda-tech.com/zerothread/1850050
POS civic krew #001 |
#9 |
is that graph with changed pistons?
for non to vtec i thought you HAD to change the pistons maybe im thinking of only d-series so we all could a gree that lsturbo has more potential than a lsvtec turbo?
#10 |
u dont have to change pistons its a preference, if u want higher or lower compression then u change the pistons.
#11 | |||||
Though my views disagree with many others as I also think the plain LS is a great daily driver .Quote:
You can slap a mini-me head on a D series much like you can w/ an LS/V - same principal. Quote:
It's a weird misconception that a lot of people seem to have that VTEC is bad for boost or something. Everybody's all like "NA = LS/V, FI = LS" - which is completely ass backwards like most of the rumors floating around. Quote:
You don't NEED to add "VTEC" pistons. Regular, stock ass LS pistons will work fine. Underlined Part: I'm not really sure what you mean by that. Every engine can be altered to be better at low end opposed to high end and vice versa. ANY engine.
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome '97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E |
#12 |
thanks you Syndacate
I was too lazy too correct all the crap that he said
#13 |
i must have read that incorrectly somewhere because i had that piston thing stuck in my head
thanks for all the good info
#14 |
if u put b16 pistons into a lsblock, would u need to resleeve or something? since its 1.6liter pistons going into a 1.8liter block?
#15 | |
you dont have to sleeve or anything they are both 81mm bore, the .2 liters of displacement come from the throws of the crankshaft
#16 | ||
x 20.as answer to: Quote:
@ others: No prob...any time...feel free to IM me any time...
#17 |
The LS/VTEC motor consists of a B18A or B18B block and a B16A head, B18C head, or a Type-R head. Basically, it is still an LS motor, but with performance cams and a port & polished head. Also, the B16A intake manifold flows better than the B18A intake manifold so airflow into the motor is greatly increased. Basically in a CRX a B18A powered CRX (1.8L DOHC non-VETC motor) has a lot of low-end power to accelerate down the ¼ mile. Off the line, the B18A CRX will easily beat the B16A CRX (assuming both are stock or have the same bolt-ons). However, on the long stretch, such as on the freeway, the DOHC VTEC really shines and pulls the car hard at high speeds for more horsepower. Now imagine getting the beat of both worlds the LS/VETC motor, which utilizes the B18A, block (for all the same torque) and the B16A head (for all the top end horsepower). That is basically what the LS/VETC motor is. In addition, others who have built a LS/VETC motor have prepped it to full race status and have already run 11.9-sec ¼ mile times, all motor. With a stock LS/VETC motor, plan on not revving the motor past 7500 rpm, and expect low 14s to high-mid 13-sec ¼ mile times.
Why the LS/VETC motor? B18A or B bottom-end has longer stroke thus capable of generating better torque response than VETC bottom-ends. B18A or B top-end has port and cam limitations to produce high-end horsepower, although B18B is slightly higher. Unavailability of billet aftermarket cams for B18A or B. All aftermarket cams for B18A or B are reground cams and are notorious for accelerated wears on top-end components. Also, cars with aftermarket high lift cams usually have rough idle which affects derivability. And price for head porting and cams is much higher than the LS/VETC conversion. With the LS/VETC conversion, smooth idle is maintained while flat torque and high-end horsepower is maximized. Availability of factory performance parts for VETC top-end is more readily available which include Type-R cams, manifolds, and other components. Disadvantages and limitations Require complete engine overhaul for installation. Rev limitations similar to B18A or B. Hope it helps bro |
#18 |
the deal is, when you mod your LS either FI or vtec you want to drop you compression down. its because of the high compression that the motor is less reliable. LS reliable LS/V less reliable LS/FI even more less LS/V FI not at all for each, if you can get the compression right, you shits gonna last forever. http://www.zealautowerks.com/dseries.html
Euro H23V EJ8 10:1 No track times yet guessing high 11's with n2o, and a lot of it. ---K.E.C--- Full ECU service, PM! http://hondamarketplace.com/showthread.php?t=2660478 |
#19 | ||
you can blow up any one of those engine combo's if you just slap parts together with no tuning and expect it to make power.
#20 | |
Risky Business
2005 Toyota Corolla |
Con: You're still alive Advice: Take a bath with a hairdryer
My comprehensive preview of the 2010 Formula 1 Season http://www.honda-tech.com/showthread.php?t=2676702 |
#21 | |
#22 | ||
#23 |
Next time your having a bad day imagine this: You are a siamese twin. Your brother, atttached to your shoulder is gay. You are not. He has a date coming over tonite. You only have one ass!!! |
#24 | ||
#25 |
how do u increase stroke? hehe im so threadjackin, sry, but im trying to picture all of this in my head, but its kinda confusing when u try to incorporate all the different factors that change compression.. imma have to draw it out or something..
| Bookmarks |
