#1 | ||||||
I <3 my Honda. Quote:
#2 |
wow thats a 1st for me. I am in for some more on this one.
it has a short ram intake, so the vtec hit real hard http://images.honda-tech.com/set1/smile/emwink.gif posted by kadeem71 People I have bought from or sold to: :Anderew, Rials, Vanos Pusha, SpoonEG, JUN., Bense, I Kick Squirrels, JDM SUV, TheHAtchNinja, 1990Si, DaisySi, mr.EGg, prjctwhteg., raven3dr, YKracing, Jdmb20coupe, Erik-B, HogHead, IceySC, TURBODC4TEG, AnotherEJ, Lucky-R, e she i, C_Rock77, Jay_Sensing, ED3_FTW, slickciv, Workless, too much vtAK, TURBODC4TEG, blackccoupe, alupso http://images.honda-tech.com/set1/smile/emthup.gif |
#3 |
I have no idea, but i would assume the engine really doesn't care much which way the crank is turning since the piston motion is up and down. The cam lobe profiles may be a problem if they are turning backwards, but otherwise should stay in their original configuration, I would think.
I would imagine the water pump and oil pump would need to be modified, as well as any tensioners. Interesting, thought though. (You have too much time on your hands )
2003 PWP RSX-type S "Need Help" or "Quick Question" = NO CLICK "I may not always be right, BUT I'm never wrong." |
#4 |
you would probably have to flop the motor around in the engine bay too...
otherwise, you'd be going pretty fast in reverse! I think it would be cheaper and MUCH easier to get a motor that spins the direction you want.
Crazy Dave Onate 1997 Honda Civic EX SOLD 2001 Honda Accord LX 1998 Nissan Frontier 1987 Honda CRX Si STOLEN 1 week after I got it 1994 Honda Civic Si HB |
#5 |
agreed this is crazy talk! crazy! oh my god i just noticed your name is crazy dave for some reason that makes your question ok, lol how weird! i think you'd need a different starter...
ek9.org <--- a place for the ek/ej lovers [b]FS: Racing Hart C2's 17x7 4x100 otaku squad member #004 http://images.honda-tech.com/set1/smile/emsmile.gif |
#6 | ||
As for the engine rotation, redo the timing belt, so that the cam(s) still rotate in the original direction.
2002 Accord SE 5 speed Quote:
#7 |
[quote=02 accord]
Rewire the car for a positive ground. That will reverse the starter. Or just fix the starter by reversing its pos/gnd. QUOTE] That's a lot of work but it still won't work.The drive is directional. This has been done on a B.New cams and a new tensioner set up are the biggies.Then you can run a standard rotation transmission (many more choices).
http://www.rrcycles.com GSR Head f/s http://www.hondamarketplace.com/show...1#post37508201 |
#8 | ||
thanks for the input guys.
#9 |
1988 Honda CRXMy Garage Join Date: Dec 2005
Don't forget the head. Valves would need to be switched. Tensioner would be on the otherside of the belt. Water pump needs to be reversed. Oil pump would suck instead of blow.
I would start with a different motor that is already the way you want tit
If you spent the time to fix it.... Fix it better than it was! |
#10 |
Moderator
http://people.clemson.edu/~ABense |
#11 | |
#12 | ||
i was just thinking the same thing!
#13 |
Moderator
i think what they did was flip the cams around and put the head on backwards. It was some crazy euro team that wanted ram air
#14 |
i get it.... wait no i dont....hold i know Im confused, thats what it is.
thats alot of work. but what about the trany cant you just change the way the tranny moves the wheels...
http://laskeyracing.com |
#15 |
Moderator
I don't think that you'd want to reverse a tranny.
#16 |
That one was too early for me too. (headache) but whoa.. I, I, I, dumbfounded...
.... damn.
#17 | ||
#18 |
We converted B series 1.8 and 1.6 engines to clock rotation 10 yeare ago. You need custom cams, some work in the oil system, a dry sump oil pump, a little work in the water passages, a mugen "clockwise" water pump impeller or the one we made, plus a different belt tennsion ing system. We used a Tilton starter for a Posche and a custom starter bracket for it, I still have one of those lying around.
#19 | ||
#20 |
We did the first rear wheel drive Acura for GT3 in the SCCA. We also did Ralt and swift conversions for Formula Atlantic and CSR in SCCA using the B-16
#21 |
That was a BTCC 2.0 liter f20b or h22 right? I heard some teams would spin the head around for precisely the reason you said--to have the intake facing the front of the car--8500 rpm ceiling and over 300 hp--they must have been doing something right!! I think that b16 in the Formula Atlantic is awesome Don,--I had no idea you didn't have to use the 4age until you told me. The current claim--even in a Toyota ad from about 2 years ago was 255 hp (crank) at 1600cc. Were your b16s in that area?
Cusco EF master cylinder brace-- brand new, unopened, still in package $75 shipped obo (RHD ONLY!!!) WTB: 88-89 Civic hatch driver side door w/ glass and regulator. Losi xxx4 G+ Associated Rc10 t4 FT Losi xxx BK2 JConcepts BJ4 WE |
#22 |
248 crank. And about $12,000 cheaper.
| Bookmarks |
