#76 | |||||
Guest
Posts: n/a
#77 |
Jesse, you use 316ss now? What are the reason's you switched?
Regards, Justin
77 Datsun 280z w/ 2JZ swap in progress S480 Turbo |
#78 | |
I find it a lot easier to regulate the flow and on/off of the gas that way.
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
#79 |
I have a few full tanks around @ all times just so I never run out , also I have a on-off valve after my purge regulator so once it is set I can just turn it on or off,
842whp & 508trq @ 35psi Evans Tuning DB8 Squad Member #89 |
#80 | |
RDR 12.009@113, 11.53@121 ....all motor streetcars Modern Automotive Performance (763)545-3800 |
#81 |
B A N N E D
i use 2 330's with separate regulators, works the best for me
#82 | |
#83 | |
#84 |
great job
#85 | ||
![]() also, most reputable builders are against bracing (using a separate support other than the tubing supporting the system) bracing actually becomes a hinderance to longevity due to stress associated w/ extreme temp changes
<FONT COLOR="green">Beater: '94 2.7L 6cyl</FONT> |
#86 | |
#87 |
I have to disagree. If done right 16g is pretty strong. I don't think I would hang a 42R off of it, but something like a 35R would be fine I'm sure.
Stewart Race Engines / RLZ ENGINEering / T1 Race Development / Speed Trapp Consulting Arizona Forced Induction / Hasport / NRG-Tech / Bullhead Gears / Canton Racing Products |
#88 | |
Tony1 might be able to chime in more since thats all he ever deals with. |
#89 |
That would be great if he would shed some light on this....
#90 | |
#91 |
I believe even if there done right, 16ga needs to be braced. Just my opinion, I myself will not make 16ga manifolds for anyone, unless I myself am bracing the turbo.
#92 |
1991 Nissan 240SX |
it has to be braced, regardless.
EM1 Crew Member #004 - The true OG Killswitch Performance /\ Atlanta's 240sx Shop |
#93 | |
Eric Urness R/TErnie Race Engineering 541.980.6022 SRT-4 and Neon Turbo Manifolds, Tuning, and Fabrication! |
#94 | |
But I'd agree with the 16g manifolds. For it too last, it's going to need to be braced. Sure some manifolds are more durable than others (JG's 16g ram horn isn't braced for instance), but if the turbo has enough leverage on the manifold to where cracking might even be remotely possible, I'd brace it.
#95 |
B A N N E D
hell yeah they are. they pulse over the mig weld. ive noticed that forever now.
#96 |
so do you guys mostly still use sched 40 to make your stuff?
My local fab guy gives me an attitude every time i bring my stuff in for finish welding, hes like sched 40 is too damn heavy, blah blah blah. I continue to use it because its strong as hell, but after working with some sched 10 stuff i dont really think sched 40 is necessary, 10 is real beefy as it is, especially to support the 28/30/35r series.
Force Fed Engineering - Home of the fastest MK4 VW 10.65@137mph old, 812whp and 511tq, S372R 1.8T, worlds most powerful 4cly VW - |
#97 | |
A cracked manifold is going to cost me money. Especially because right now, I don't have the sales that some of these other guy's do (I've kept it that way on purpose, until I can really invest my time into it). So in essance, the stronger I can make it, the better. I'll probubly end up making the switch at some point though. It's quicker to cut, quicker to weld, quicker to bevel...and so on.
#98 |
B A N N E D
sced 40 does not cut quicker than 10 and its the same amount of work to prep it.
sched 10 is less work period.
#99 | |
#100 |
B A N N E D
easy killer
| Bookmarks |
