> Welding/Fabrication
Old 12-08-2006, 01:31 PM   #51
tepid1
tepid1's Avatar
Send a message via AIM to tepid1 Send a message via Yahoo to tepid1
Default Re: (B18C1CYA)
That looks great man.... I'm gonna have to play around some more.
Stewart Race Engines / RLZ ENGINEering / T1 Race Development / Speed Trapp Consulting
Arizona Forced Induction / Hasport / NRG-Tech / Bullhead Gears / Canton Racing Products
tepid1 is offline Report Post   Reply With Quote
Old 12-08-2006, 01:34 PM   #52
B18C1CYA
B18C1CYA's Avatar
Send a message via AIM to B18C1CYA
Default Re: (tepid1)
Thanks , all it takes is time , try try and try just stick with it is the best thing and dont give up
842whp & 508trq @ 35psi
Evans Tuning
DB8 Squad Member #89
B18C1CYA is offline Report Post   Reply With Quote
Old 12-08-2006, 01:48 PM   #53
*Boostwerks*
*Boostwerks*'s Avatar
Send a message via ICQ to *Boostwerks* Send a message via AIM to *Boostwerks*
Originally Posted by B18C1CYA
Ok guys here is some pics ,
Here is sch40 b4 you bevel it
after you bevel
tacked up
weld started
weld completed
pennatration side , just to note I did not have enoff gas to backpurge this weld but if I had backpurged it would have turned out alot nicer on the inside.
Here is a pic of my torch to show I dont use any thing to fancy , gas lense 1/16" tungsten, 1/16" 308 filler and about 28 argon flow
Holy shit that looks great man! Pm back at ya...
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com
Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
*Boostwerks* is offline Report Post   Reply With Quote
Old 12-08-2006, 02:23 PM   #54
RC000E
RC000E's Avatar
So, how about letting us in on the amps you used there....then I'ma head downstairs and check this out.
N/A time!
RC000E is offline Report Post   Reply With Quote
Old 12-08-2006, 02:31 PM   #55
B18C1CYA
B18C1CYA's Avatar
Default Re: (RC000E)
Honestly I dont know , I set my Tig at 145 amps and just use my foot so I have no Idea , its all in the puddle and heat control
Evans Tuning
Old 12-08-2006, 03:25 PM   #56
RCautoworks
Send a message via AIM to RCautoworks
The welds look good, but unless you are backpurging, this picture is not really good because it does not tell a lot.
http://www.we-todd-did-racing....7.jpg
RCautoworks is offline Report Post   Reply With Quote
Old 12-08-2006, 03:42 PM   #57
*Boostwerks*
Default Re: (90blackcrx)
Yeah, RLD could you do another weld like this, but with the purge flow rate turned up? I'm sure you can get a nice looking weld on the inside, but I'd be interested to see how it looks.
Old 12-08-2006, 11:10 PM   #58
B18C1CYA
B18C1CYA's Avatar
Default Re: (Boostwerks.com)
yeah I will do one tomorow , also this was done with no back purge so it will look way nicer inside, the pennatration is there so when purged it should almost take on the same bead look as the out side of the weld ,
Evans Tuning
Old 12-09-2006, 06:15 AM   #59
tony1
H-T Basic Sponsor
tony1's Avatar
The fact that it sugars on the back side when not purging does NOT mean that it will get full penetration when backpurging. I'm pretty sure you're going to find that you don't get full penetration most of the time you assume you would if it was backpurged...
T1RaceDevelopment.com
Check out the new site!
The ID2000 is here...
tony1 is offline Report Post   Reply With Quote
Old 12-09-2006, 06:54 AM   #60
TurboJesse
Guest
Posts: n/a
Default Re: (tony1)
I weld with about 85-90 amps...usually close to full pedal. Single Pass
Old 12-09-2006, 09:48 AM   #61
dave@passenger
Default Re: (TurboJesse)
Is that 1/16 or .045 filler you are using Jesse? Or something else? Good work
dave@passenger is offline Report Post   Reply With Quote
Old 12-09-2006, 10:00 AM   #62
TurboJesse
Guest
Posts: n/a
Default Re: (dave@passenger)
1/16 filler
Old 12-09-2006, 11:09 AM   #63
tepid1
tepid1's Avatar
Jesse you using 316SS? What grade filler and what schedule pipe is that?
Old 12-09-2006, 11:51 AM   #64
B18C1CYA
B18C1CYA's Avatar
looks like sch10 pipe
Evans Tuning
Old 12-09-2006, 12:12 PM   #65
tepid1
tepid1's Avatar
That' what I thought too. RLD, what grade filler should you use w/ 316ss?
Old 12-09-2006, 12:32 PM   #66
B18C1CYA
B18C1CYA's Avatar
To be honest Iam not sure because I have never welded with a 316 grade but they do make a 316/316l filler so I would have to guess that one , but it is just a guess , lol Iam realy not sure we will have to wait on Jesse for that answer
Evans Tuning
Old 12-09-2006, 02:45 PM   #67
B18C1CYA
B18C1CYA's Avatar
Ok here is one I did today , back purged and is slightly past 100% pennatration
Modified by B18C1CYA at 1:34 AM 12/10/2006
Evans Tuning
Old 12-09-2006, 03:00 PM   #68
RCautoworks
Looks good, but pic #2 makes the weld look concave.
Old 12-09-2006, 03:07 PM   #69
B18C1CYA
B18C1CYA's Avatar
yes it does , my camera sucks lol here is the best pic I could get to show they are flush with the pipe , also there is room for improvment in this weld I think but Iam happy with it for now
Modified by B18C1CYA at 1:31 AM 12/10/2006
Evans Tuning
Old 12-09-2006, 03:14 PM   #70
tepid1
tepid1's Avatar
Looks great. How many passes on that? Also what are you using to backpurge.... Argon or Helium?
I have not messed w/ SS a whole lot. I also need to make a backpurge rig. Any suggestions on what I should do/use?
Thanks for your help.
Old 12-09-2006, 03:22 PM   #71
B18C1CYA
B18C1CYA's Avatar
Single pass , 1/16" tungsten , still dont know how many amps cus I never look flow was about 5 for the purge and 28 for the torch , also I just use tin foil , kinda ghetto but the dollar store is key , lol and I use 100% argon , I know with a helium argon mix the arc burns hotter , but I dont need any more heat so I just saty with argon .
Evans Tuning
Old 12-09-2006, 03:49 PM   #72
Lamchop0000
Lamchop0000's Avatar
Send a message via AIM to Lamchop0000
what size was the filler for those
LRS
the stable: ED9, ED6
http://www.Lamracing.com
Lamchop0000 is offline Report Post   Reply With Quote
Old 12-09-2006, 03:55 PM   #73
B18C1CYA
B18C1CYA's Avatar
Default Re: (Lamchops)
for both of the welds I used 1/16" 308L
Evans Tuning
Old 12-09-2006, 04:22 PM   #74
tepid1
tepid1's Avatar
I guess I should have made it a little more clear in my question.... What do you use for regulation? Do you use a seperate tank or tap off of your one tank and regulate that for backpurging? Pics maybe?
Old 12-09-2006, 04:31 PM   #75
B18C1CYA
B18C1CYA's Avatar
same tank 330cuft with 2 regulators on it
Evans Tuning
Bookmarks
