> Welding/Fabrication
Old 12-06-2006, 04:03 PM   #26
Race Egr
Race Egr's Avatar
Send a message via AIM to Race Egr
Default Re: (Boostwerks.com)
Damn 120 amps im using around 75
me.
Race Egr is offline Report Post   Reply With Quote
Old 12-06-2006, 04:12 PM   #27
B18C1CYA
B18C1CYA's Avatar
Send a message via AIM to B18C1CYA
Well you have the right method , set it high and learn heat control I have mine set around 135 amps or so , I never touch the setting on the welder for any thing realy , also rebeveling is a must on sch40 to get 100% , you can on sch10 without rebeveling , I have benn messing around with diffrent sch's for the past few weeks and was almost going to make the change , but I would just stay with sch 40 for the added strength also PM me any time if you have any ??? 's Bryson
842whp & 508trq @ 35psi
Evans Tuning
DB8 Squad Member #89
B18C1CYA is offline Report Post   Reply With Quote
Old 12-06-2006, 04:15 PM   #28
Race Egr
Race Egr's Avatar
Default Re: (B18C1CYA)
So b181cya you only do one pass correct? Thats all I did when I was welding sch10 and it filled the bevel perfect. I was usin 1/16th filler I dont weld sch10/40 much and its a pita to work with
me.
Old 12-06-2006, 04:18 PM   #29
B18C1CYA
B18C1CYA's Avatar
Default Re: (dr.NAPIER)
yes singal pass I also found with sch10 there is alot of stress on the tubes when you cut them , and when you weld them they shrink up alot more than sch40 ,
Evans Tuning
Old 12-06-2006, 05:01 PM   #30
CSaddict
CSaddict's Avatar
Send a message via AIM to CSaddict
I root pass and cap pass all my schedule 10 piping. Heavy bevel with a 90 amp root pass, with an 85 amp fill pass. Seems to work well for me. I am just a hobby welder. I make mostly manifolds when I have free time. Bryson, I am the guy from the Jeep site that remembered you from EF-honda.com Your work is very much improved since I last saw your work.
CSaddict is offline Report Post   Reply With Quote
Old 12-06-2006, 05:19 PM   #31
RCautoworks
Send a message via AIM to RCautoworks
Originally Posted by Boostwerks.com
Why not? I think if you can completely fill the bevel with the puddle and not have the weld be concave, there is nothing wrong with doing one pass.
Are you gapping the pipe at all, I still don't see how some of you guys are doing one pass. I have never ever gotten away with one pass, I just don't see it happening either.
I also have received advice in the past and talked to engloid, and searched and read everything the guy says. A few things he says
". Many people think that full penetration means that you have to weld the entire thickness in one pass, and this is seldom the case. If I weld 1/4" material and want full penetration with tig, it will likely be done in 3-4 passes. "
"And, although it's commonly thought of otherwise, you don't have to weld the entire thickness in one pass. In fact, in every industrial welding job I've ever had, they'd be rather upset if we welded it in one pass. Military weld specs require 2 passes, at least. On sch10 pipe, I'd probably make 2 passes. One would just be focused on getting the inside root pass to look nice. The other would fill the bevel and put a nice final pass on the outside.
Notice in the weld below, this is the "root pass." There was no effort made to fill the bevel, only to put a nice bead on the inside. (this is carbon steel)"
I don't doubt anything this guy says, he knows his stuff.
RCautoworks is offline Report Post   Reply With Quote
Old 12-06-2006, 05:25 PM   #32
cua0
cua0's Avatar
Send a message via AIM to cua0
no, he was a good asset around here.
shame he was banned over some stupid shit in the bike forum
cua0 is offline Report Post   Reply With Quote
Old 12-06-2006, 05:26 PM   #33
RCautoworks
Default Re: (cua0)
No doubt, I'm still in contact with him.
Old 12-06-2006, 06:25 PM   #34
RC000E
RC000E's Avatar
Default Re: (90blackcrx)
Bro, I'm with you 100%, I have NEVER single passed any of these. Hotrex use to preach about his one pass wonders and his manifolds damn near fell apart on their own in the early days.
Bryson, do yourself a favor man....bevel, do a root pass, and work on your consistency. I think you'll find that if you do a root, then a fill, your welds will look a hell of alot better, and penetration is guaranteed. On runners, I can't recall ever even using beyond 90 amps much less 125....and even at 90 I am backing off.
N/A time!
RC000E is offline Report Post   Reply With Quote
Old 12-06-2006, 07:19 PM   #35
*Boostwerks*
*Boostwerks*'s Avatar
Send a message via ICQ to *Boostwerks* Send a message via AIM to *Boostwerks*
Default Re: (RC000E)
I just want to make it clear that i never said I wasn't beveling the pipes. I match straight pipe or any cut pipe to that of the pre-beveled surfaces. Theres no way I would weld up pipe this thick that hasn't been beveled. I'd also like to make it clear that I've never had a single cracking issue, personally or with any of my customers.
Yeah I'll definetly try doing a root pass, and then filler pass and see how it turns out, but I've been taking RLD's advice ever since i started TIG welding, and have had great success.
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com
Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
*Boostwerks* is offline Report Post   Reply With Quote
Old 12-06-2006, 07:26 PM   #36
B18C1CYA
B18C1CYA's Avatar
Default Re: (CSaddict)
The secret to singal pass is heat control , it took me over a year to figure it out , just do search's and you will see from many how it is done , some people to learn from , Tinker219 and the full race team , there are lots of pics around of there stuff that you can study from , If I get time 2 marrow I will get some pics for you guys of step by step prep and the end result also no need to double pass sch10 you should kill that in a single pass and be at 120% penn ,
Evans Tuning
Old 12-06-2006, 07:32 PM   #37
RCautoworks
That's good, but there is always room for improvement you know, I mean sch10 and 40 is plenty strong that a monkey could weld a top mount and it probably would not crack, that does not mean it was done right.
I'm not doubting or arguing with you but I still can't see it being done, I would imagine you would have to sit in the same spot for awhile, and push the rod in enough times to get the weld to where it needs, sitting on one spot with that much heat can't be ideal. Have any links to read what you are stating ?
Old 12-06-2006, 07:41 PM   #38
RC000E
RC000E's Avatar
To further clarify to readers, I in no way meant to imply your manifolds would fall apart. I was merely citing that other "one pass" guys had manifolds that did, despite their claims to getting big penetration.
N/A time!
Old 12-06-2006, 08:13 PM   #39
*Boostwerks*
Thats exactly what I thought. It's hard for me to beleive that when welding in the bevel, that the metal underneith the puddle isn't getting formed into the bead. If the heat is hot enough, but not overly hot to burn it, the base metal will easliy form with the puddle. Thats at least how I've seen it.
That would be great man! I was thinking about welding up a pipe several different ways, and then using a crush method to see how well the seam holds up. It would definetly be interesting for me to see.
Of course! I'm not trying to imply that your wrong or anything. It's just that several other's have done single passes with great results. although If it works, then it's kinda hard to argue whether or not it was done right or not.
Hehe. . we just don't want the thread getting into a "pacesetter makes ferrari exhaust" thread again...lol.
Old 12-06-2006, 08:59 PM   #40
B18C1CYA
B18C1CYA's Avatar
Here is a link to Tinker219 (Cody) aka love fab , http://www.honda-tech.com/zerothread?id=1103067 you can learn alot from this post , you just need to work at it
Here is one about Full-race http://www.honda-tech.com/zerothread?id=898516
Figure if you want to be the best , Y not try to learn from the best , these 2 threads help out alot
Evans Tuning
Old 12-06-2006, 09:29 PM   #41
RC000E
RC000E's Avatar
No doubt...hahaha...we schooled those rednecks
N/A time!
Old 12-06-2006, 11:49 PM   #42
anusol
B A N N E D
2 passes for me thanks. looks better, but theres still a ways to go
do yourself a favor and never write on the flange with the torch again. thats hotrex territory.
anusol is offline Report Post   Reply With Quote
Old 12-07-2006, 10:31 AM   #43
RC000E
RC000E's Avatar
Checked this thread out....200+ amps for single pass penetration. Welds look a little funky though like they are too hot in places, which is how most buyers judge the product [looks]. A balance of strength and "prettiness" is what people like to buy in my opinion.
N/A time!
Old 12-07-2006, 10:35 AM   #44
RCautoworks
Also thought the welds looked rough.
Old 12-07-2006, 04:18 PM   #45
*Boostwerks*
Yeah, I'm pretty sure he doesn't use that method anymore. I know he's using mainly the walking the cup technique, but I don't know if he still does that with one pass.
Old 12-07-2006, 04:44 PM   #46
Throwdown
Throwdown's Avatar
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Send a message via AIM to Throwdown
nice mani ..
<FONT COLOR="red">MY OLD EG </FONT>
I <FONT COLOR="red">♥</FONT> STRAIGHT EDGE forever together united represent
<FONT COLOR="brown">VOUCHES IN PROFILE</FONT>
<FONT COLOR="olive">Tree Top Soldier</FONT>
Throwdown is offline Report Post   Reply With Quote
Old 12-07-2006, 06:41 PM   #47
9bells
9bells's Avatar
Send a message via AIM to 9bells
Default Re: (CTP_MADDOG)
Stainless in particular is more prone to stress build-up from multiple passes.
The thermal conductivity presents it's own problems, as does carbide precipitation.
Higher welding current and fast travel is key to letting the weld metal cool sooner.
Too much heat with slow passes increases grain growth near the weld, decreasing
strength and ductility.
If two passes are used, the first should be relatively hot, and fast, while the second
should be the same.
It was mentioned earlier that this is how a few gus were doing it.
I think 2 generally looks better on the heavier stuff, but some guys get carried away with the cap.
Nice manifolds though. This section is full of talented guys.
9bells is offline Report Post   Reply With Quote
Old 12-08-2006, 03:13 AM   #48
CoreyR
CoreyR's Avatar
Send a message via AIM to CoreyR
Default Re: (9bells)
nice work bryson, much better than your older stuff. but seriously 2 passes (root/cap) especially on a topmount.
CoreyR is offline Report Post   Reply With Quote
Old 12-08-2006, 12:41 PM   #49
B18C1CYA
B18C1CYA's Avatar
Default Re: (CoreyR)
Ok guys here is some pics ,
Here is sch40 b4 you bevel it
after you bevel
tacked up
weld started
weld completed
pennatration side , just to note I did not have enoff gas to backpurge this weld but if I had backpurged it would have turned out alot nicer on the inside.
Here is a pic of my torch to show I dont use any thing to fancy , gas lense 1/16" tungsten, 1/16" 308 filler and about 28 argon flow
Evans Tuning
Old 12-08-2006, 12:44 PM   #50
B18C1CYA
B18C1CYA's Avatar
also another thing to think about , is it is true about when you over heat the steel , and also if you can do a single pass and get great looking welds with 100% pennatration you save time , wich we all know time ='s money
Evans Tuning
Bookmarks
