> Honda CRX / EF Civic
Old 10-26-2006, 05:37 PM   #1
cpuff
cpuff's Avatar
Default zc axles
i ahve a 91 hatch with a dohc zc, and zc tranny, i was wonderign what type of axles do i need for it?
cpuff is offline Report Post   Reply With Quote
Old 10-26-2006, 05:45 PM   #2
Bense
Moderator
Bense's Avatar
Send a message via ICQ to Bense Send a message via AIM to Bense Send a message via MSN to Bense Send a message via Yahoo to Bense Send a message via Skype™ to Bense
raxles.com
Bense is offline Report Post   Reply With Quote
Old 10-26-2006, 08:30 PM   #3
jlicrx
jlicrx's Avatar
Default Re: zc axles (cpuff)
90-93 Integra axles with ZC intermediate shaft
ZCspeed Racing
jlicrx is offline Report Post   Reply With Quote
Old 10-26-2006, 09:12 PM   #4
Targa250R
be professional
Targa250R's Avatar
Default Re: zc axles (jlicrx)
1991 Civic | 1998 CB750 | 2001 Integra | 2005 Giant Trance 2 | 2009 Redline Conquest Pro
Targa250R is offline Report Post   Reply With Quote
Old 10-26-2006, 09:30 PM   #5
julio_bOostamante
I'm a Jackass
Default Re: zc axles (Targa250R)
i used a 88 teg one on the driver and the 90 -91 teg one on the passenger
julio_bOostamante is offline Report Post   Reply With Quote
Old 10-26-2006, 10:06 PM   #6
Bense
Moderator
Bense's Avatar
wrong.
Old 10-26-2006, 10:09 PM   #7
SiRay13
SiRay13's Avatar
Send a message via AIM to SiRay13
Default Re: zc axles (Bense)
that's what i use...
SiRay13 is offline Report Post   Reply With Quote
Old 10-26-2006, 10:11 PM   #8
Mista Bone
Mista Bone's Avatar
Send a message via AIM to Mista Bone
you need either ZC axles, or custom units from Marty @ Raxles, or swap the side gears in the ZC diff and use DX/Si axles and axle seals.
"D" Tranny Guru
Mista Bone is offline Report Post   Reply With Quote
Old 10-26-2006, 11:02 PM   #9
Tyson
Tyson's Avatar
Default Re: zc axles (Mista Bone)
marty quoted me like $280 for his custom zc axles. thats probably not the right number, but it was enough for me not to consider it for my project. sold the hybrid tranny and intermediate shaft to SiRay anyway.
but i will vouch for marty and the quality of raxles anyday.
i hate when ppl just say "wrong."
im not going to say one way or the other, since i havent proceeded with my zc tranny project, but i would take jli_crx's advice anyday.
and wtf, "side gears"? lets just call it a differential...
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline Report Post   Reply With Quote
Old 10-26-2006, 11:05 PM   #10
jeremiah963
jeremiah963's Avatar
Default Re: zc axles (Tyson)
ive been using 90-93 teg axels for a while and ran at the track several times with no problems....
jeremiah963 is offline Report Post   Reply With Quote
Old 10-26-2006, 11:16 PM   #11
Bense
Moderator
Bense's Avatar
he doesn't mean the differential, he means the side gears.
it's been documented that 90-93 axles do not work properly with this setup. One of the 90-93 axles works.
What? you expect me to answer instead of saying wrong? Do you expect me to search and place the link in here? The answer has been documented on several forums. HT, d-series, thezcr, etc. The OP should already be searching for this, yet he shows no signs of it.
Old 10-26-2006, 11:19 PM   #12
Tyson
Tyson's Avatar
i see a lot more "documentation" that integra axles work fine. just take the hub ring out. sometimes i do hear about ppl with lowering issues (or maybe stock height.) but like i said, im not commenting either way since i havent done it myself. but i know jli has a lot of experience (as well as you and chuck) on this subject.
what do i expect? an explanation why its wrong. maybe a link to the many documents showing its wrong.
and really, im open to learning. whats side gears mean? how are the gears in the diff removeable and interchangeable?
Old 10-27-2006, 06:46 AM   #13
jlicrx
jlicrx's Avatar
the side gears are the differential gears that the axles fit into - splined on the inside - remove the pin that goes thru the pinion gears and all of the gears just fall right out - you can swap the side gears from DX/Si/LX/EX/HF into the ZC carrier and use the stock axles - you cannot, however, swap the side gears from the ZC into the DX/Si/LX/EX/HF carrier to use the larger axles - the hole in the carrier that the axles go thru is too small - the ZC carrier is not the same as all of the rest - having done around 40 DOHC ZC swaps with about half of them with the ZC transmission, i can tell you for a fact that the 90-93 Integra axles work perfectly - we have purchased complete ZC swaps that came with the JDM axles and have measured the axles and compared them with the 90-93 Integra axles and they are dimensionally the same - 86-89 Integra axles are shorter - we have had people come to us saying they bought 90-93 Integra axles and the axle on the driver's side was too long - in every case, they either had two passenger side axles or had the axles switched from side to side - there is a right and a left side axle and they only work one way
ZCspeed Racing
Old 10-27-2006, 09:01 AM   #14
Targa250R
be professional
Targa250R's Avatar
Originally Posted by Bense
wrong.
How is he wrong? '90-93 Integra axles work perfectly fine with the ZC diff and intermediate shaft in an EF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">it's been documented that 90-93 axles do not work properly with this setup. One of the 90-93 axles works.
What? you expect me to answer instead of saying wrong? Do you expect me to search and place the link in here? The answer has been documented on several forums. HT, d-series, thezcr, etc. The OP should already be searching for this, yet he shows no signs of it.</TD></TR></TABLE>
What sort of problems have been encountered? I haven't seen or heard of any. An H-T search indicates that '90-93 Integra axles are the proper axles to use with the ZC trans.
Old 10-27-2006, 09:16 AM   #15
civicflow
civicflow's Avatar
90-93 integra axles(non abs) and zc intermediate shaft on my hatch. works perfect
CRX Si Partout+MiscParts: http://hondamarketplace.com/showthread.php?t=2652859
civicflow is offline Report Post   Reply With Quote
Old 10-27-2006, 09:32 AM   #16
Tyson
Tyson's Avatar
i see now. thanks.
total rhetorical question, wouldnt it simply be easier to just switch carriers completely anyway???? wtf, just unzip the reverse threaded bolts and switch drive gears and be done with it if youre going thru that effort.... just to use stock axles. why would you want the carrier opening to be mismatched with the axles youre using. how is that a better solution...
Old 10-27-2006, 09:37 AM   #17
Bense
Moderator
Bense's Avatar
thats assuming that you have a ex/si trans to get parts from. you can pull side gears from a dx/std diff.
Old 10-27-2006, 09:38 AM   #18
Tyson
Tyson's Avatar
Default Re: (Bense)
carriers are different between DX and Si? (not a rhetorical)
Old 10-27-2006, 04:20 PM   #19
CRX1.4DualCarb
CRX1.4DualCarb's Avatar
From what jilicrx has told me (this guy knows it!) they are different. The standart (dx/hf?) carriers have a smaller splined hole by 2mm.
So.. You could swap carriers and use standart axles but wouldn't be able to use the intermidiate shaft (half-shaft) that is very good in eleminating torque-steer. The Half-shaft splines that go inside the carrier are 2mm wider, just like the teg and zc axle splines.
CRX1.4DualCarb is offline Report Post   Reply With Quote
Old 10-27-2006, 04:40 PM   #20
Tyson
Tyson's Avatar
Default Re: (CRX1.4DualCarb)
hmmmmm wait a sec. arent Si and DX axles interchangeable???
Old 10-27-2006, 05:11 PM   #21
Bense
Moderator
Bense's Avatar
Default Re: (Tyson)
zc case is the same case as an si case.
si/zc case = big bearing
dx/lx/hf/std case = small bearing
dx trans differential bearing = 72x35x17
si trans differential bearing = 80x40x18
inner diameter of DX diff bearing = 35mm
inner diameter of Si/ZC diff bearing = 40mm
can't use the dx/std carrier because it's 5mm too small for the zc/si bearings
solution? use side gears from dx diff in zc diff and run stock axles w/o the halfshaft. if you're worried about torque steer, get an LSD.
zc diff = si diff w/ cable b-series side gears
90-93 teg splines may fit the zc diff w/ halfshaft, but think about the placement of the D trans in the chassis compared to the placement of the B trans in the chassis.
So then the decision here is based on the goal of eliminating tq steer. 2 choices
1. get custom axles and run the midshaft ~$340ish
2. get an obx lsd and get it working for ~$400
spend $60 more and get an LSD.
Old 10-27-2006, 05:12 PM   #22
Targa250R
be professional
Targa250R's Avatar
Default Re: (Tyson)
Yes, they are. Actually, HF/STD axles are the same on the diff end as Si/DX axles, so they are all interchangeable as far as the diff goes (the hub end is a different story).
I'm not quite sure what he is talking about.
Old 10-27-2006, 05:15 PM   #23
Tyson
Tyson's Avatar
Default Re: (Bense)
dx trans differential bearing = 72X35X17
si trans differential bearing = 80X40X18
solution? use side gears from dx diff in zc diff.
and there we go.
now its documented.
now ill put this in the FAQ, so that everyone can see. and ppl can link, to help ppl.
(whether or not you guys agree or not)
Modified by Tyson at 5:26 PM 10/27/2006
Old 10-27-2006, 05:17 PM   #24
Targa250R
be professional
Targa250R's Avatar
Default Re: (Bense)
si case = big bearing
dx case = small bearing
Not all Si transmissions have 40mm carrier bearings - some of them use the 35mm bearings. Talk to Quaife if you don't believe me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">90-93 teg splines may fit the zc diff w/ halfshaft, but think about the placement of the D trans in the chassis compared to the placement of the B trans in the chassis.</TD></TR></TABLE>
Dude, '90-93 Integra axles work fine with the ZC trans. There are hundreds if not thousands of people using this setup with no apparent problems.
Old 10-27-2006, 05:22 PM   #25
Bense
Moderator
Bense's Avatar
Default Re: (Targa250R)
confusion was ex sedan d16a6, some were small bearing, some were big bearing.
Bookmarks
1991, 40mm, 89, axels, axles, bearing, big, case, crx, dohc, honda, series, swap, tranny, transmission, zc
