will 90-93 integra rear disc brakes and master cylinder work on a 95 civic hatch eg?????
Old 10-13-2006, 07:25 PM
Markb16a's Avatar
Default will 90-93 integra rear disc brakes and master cylinder work on a 95 civic hatch eg?????
i have a set of 90-93 gsr rear disc brakes that I was selling but now I heard that they can fit on a hatch 92-95 style eg. Is this possible cause I thought you had to use 94-01 integra rear disc brakes? just wondering if anyone has done this or knows this can be done? also the master cylinder and brake booster can that work as well? thanks
Old 10-13-2006, 07:35 PM
jdeemseerx's Avatar
Default Re: will 90-93 integra rear disc brakes and master cylinder work on a 95 civic hatch eg????? (Markb1
as far as i know only the DC conversions will work, not the DA..
Old 10-13-2006, 09:32 PM
MattsGreenEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know only the DC conversions will work, not the DA.. </TD></TR></TABLE>
x2
Old 10-14-2006, 09:51 AM
Markb16a's Avatar
thanks guys im glad i asked before I started seeing if this would work.
Old 10-14-2006, 01:24 PM
92b16si's Avatar
Default Re: (Markb16a)
i heard they do fit they just need your rear lower control arm not sure double check
Old 10-14-2006, 01:50 PM
be professional
Targa250R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markb16a &raquo;</TD></TR><TR><TD CLASS="quote">i have a set of 90-93 gsr rear disc brakes that I was selling but now I heard that they can fit on a hatch 92-95 style eg. Is this possible</TD></TR></TABLE>
Yes. '90-93 Integra rear disc hubs and calipers will bolt up to any '88-00 Civic, '90-01 Integra, '88-91 CRX, and '93-97 del Sol trailing arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">cause I thought you had to use 94-01 integra rear disc brakes?</TD></TR></TABLE>
You thought wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">just wondering if anyone has done this or knows this can be done?</TD></TR></TABLE>
Yes. Me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also the master cylinder and brake booster can that work as well? thanks </TD></TR></TABLE>
You don't need that for a rear disc conversion. Don't bother unless you are upsizing the front brakes as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know only the DC conversions will work, not the DA.. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MattsGreenEG &raquo;</TD></TR><TR><TD CLASS="quote">x2</TD></TR></TABLE>
Wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16si &raquo;</TD></TR><TR><TD CLASS="quote">i heard they do fit they just need your rear lower control arm not sure double check </TD></TR></TABLE>
You don't need any arms. All you need are the hub assemblies, calipers, soft lines, rotors, pads, and a set of appropriate e-brake cables for your chassis. Proportioning valve will depend on what fronts are being used.
Markb16a
13
01-24-2008 05:19 PM
92hatch_cx-t
01-01-2007 01:51 PM
HFpower
10-14-2006 11:22 PM
Baggy Spandex
08-31-2005 02:11 PM
Quick Reply: will 90-93 integra rear disc brakes and master cylinder work on a 95 civic hatch eg?????
