running a 22mm rear sway bar.
1 Post
Re: running a 22mm rear sway bar. (thehatchninja)
the bar doesnt attach to the subframe in the way the newer models do(dc,eg,ek), they have separate brackets that are bretty beefy and attach to the tow hook spots(ST bar anyway) so I would think if they are strong enough for your car to be pulled from I dont think they will tear out
Re: running a 22mm rear sway bar. (Crx Jimmy)
I have been driving and autocrossing my ST for 4 years now with no concern. As stated above it attaches at the tow hook locations. The old tow hooks bolt in on top of the sway bar brackets.
Modified by hughesl at 6:22 PM 10/11/2006
the difference as stated by others about the EF chassis is that the swaybar is not mounted on the subframe.
not saying its not ever possible, but it would be different and not a worry for you.
fireant
14
04-12-2006 11:43 AM
TegoDC5
Suspension & Brakes
14
09-13-2005 08:45 AM
