| Thread Tools | Search this Thread |
#1 | |||||
J2ned Turbo Kits - You'll See... |
#2 |
89 civic Si
10.43 @ 137 463whp old setup B16A car is currently gettting tore down to build a CRX current parts in closet Golden Eagle sleeved B16A, stock bore Arias 10:1 flat top pistons Manley Turbo Tuff rods Supertech Springs/retainers .5mm over intake valves 1mm over exhaust valves aeromotive a-1000 pump and 10 micron filter Zex direct port kit Victor-X mani 68mm STR tb PWR air to water intercooler 4x8 turbonetics t3/62-1 .82 exhaust stage 5 blah turbonetics evolution wastegate turbonetics raptor BOV Custom turbo mani custom piping/DP Precision 1000 cc injectors JDM P30 w/ hondata s200b MSD digital 6 plus ice water setup for intercooler M&H 26x8.5x13's on gunmetal lensos custom ladder bar/traction bar setup 1 gallon JAZ fuel cell AC autotechnic fuel rail ATI super damper prolly more, but thats all i can think of. Shooting for 650 whp, 9's and 145+ traps
510whp/310ftlbs 89 crx drag car 10.55@134 new setup 600/380 on 24lbs 435whp EF hatch b16 turbo 10.43 @137 / nitrous only, 11.13@122.5 88 Wagovan, 302/270 12.1 @ 112 XBLive pedobearattack |
#3 |
JERRYBUILT NUFF SAID'
damn.Only two ef's that are boosted..
JERRYBUILT Nuff Said' 00 TAFETTA WHITE CTR REP 600 WHP EK http://www.youtube.com/aDJMproduction |
#4 |
Banned
90 SI
1.6 D16Z6 Crower rods Endyn Pistons, coated Endyn ported head, w Supertech valves Endyn Springs and Ti retainers SM Racing shorty turbo manifold SM Racing 3in downpipe w/ integrated wastegate dump SM Racing 3in exhaust SM Racing custom intercooler SM Racing Welded and ported Y8 intake manifold 58mm GSR TB T3 50trim/.48AR Hondata S300 Tial 35mm Wastegate DSM 450 injectors Shooting for 350 at wheels. Can't use much more. Want to be able to run 1:45s or better at RD Atlanta. Waiting on a bigger turbo something along the lines of a TO4E or GT something or other. Can't decide if I want to keep putting money into my street car instead of my race car. |
#5 |
The Boot
in to watch this thread!
Sleeper ED9 ![]() #004 EFSFTMFW! |
#6 |
nice builds lets see some more...
A GSR-T Will be born soon . To start Owning DC....... |
#7 |
LS/VTEC
GE Sleeves 84mm Eagle Rods/Arias Pistons 9.0:1 B16 Head, stock ports Super Tech Valves/Valve Springs/Ti Retainers/Ferrea valve seals/Manley keepers CTR cams Victor X Intake Manifold RPM Service 70mm T/B InlinePro SS T4 manifold GT4088R Turbocharger Tial 44mm WG Tial BOV GE Fuel Rail 1000cc Injectors Bosch 044 fuel pump/Aeromotive Fuel filter/-8an feed line/OE return line Precision "600 HP" Intercooler Turbosmart 2 stage boost controller Accel DFI Gen.6 (upgrading to a Autronic SMC at the end of the year) MSD Digital 6 and SS coil VP C16 race gas ![]() Haven't gotten a real dyno number, as we haven't been able to keep traction on the dyno. Approximate hp # is 460 at 18psi. Spins even while doing 4th or 5th gear pulls. Gonna try drag radials next, I heard they hold the best. On the track, best ET is a 11.44 @ 131mph, fighting for traction. Best 60ft so far is a 1.65 using M&H 24.5x8.5x13 slicks at 6psi. Modified by Redline130 at 9:00 AM 10/5/2006 Modified by Redline130 at 9:01 AM 10/5/2006
89 CRX GSR Turbo~ 10.75 @ 139 94 Civic Coupe LS Turbo ~ Project/Play Car |
#8 |
pics people.... pics
10 Second EG Project - not there yet. 493whp 337 TQ @ 21 psi....more coming!! Topmount GT3582R 84mm LS/Vtec GE Sleeved, Pauter Rods/CP Pistons R.I.P. Earl Laskey |
#9 |
90 red hatch
d16a6-SRP/eagle bottom end/ARP head studs stock head, delta 272/260 turbo cam lame dead clutch (being replaced by an action 2md as soon as it gets here) custom manifold (by myself and brother) custom piping/custom big-ass back door IC(me fabricated w/lil brother's welding) walbro255/prototype deatschwerks 560 cc injectors (amazing lil guys), street tuned to a hair over 300 whp on turboedit. did 300.08 w/o the cam. also ran 12.9@115 on DR's w/0 the cam. not sliping clutch then. shooting for 350 whp and then calling it a day. ON A STOCK NONVTEC HEAD. thats my only requirment. simple setup all together t3.63/t4 60-1 hifi, tial 38mil, 20 psi, 24.5'' slicks, 12.4@116, burning the clutch through 4th, 12.4@105 not flooring it at all in 4th, same day. should run high 11's with the new clutch and a nice day. ![]() ![]() ![]() ![]()
custom EF traction bar and a cheap K24 for sale too! PM! WTB: useable h22 of h23 block/girdle..no crank needed |
#10 |
91 crx si
Block: Dart tall deck block 84.5mm CP 9.0/1 Pistons Crower rods Crower 92mm crank ITR oil pump Moroso Pan + pickup ATI dampener Head: GSR head Portflow full P&P Supertech +.5mm Valves Supertech springs, retainers CTR Cams GE Cam Gears (Modified by T1 for hall effect pickup) Intake + Fuel: AIR/Endyn Carbonfiber intake manifold RPM Services 70mm TB BDL Fuel Rail RC 1000cc injectors walbro 255hp intank Custom 1/2 gal. Surge tank Weldon 2015 Fuel pump from the surge tank Weldon Regulator -10 feed -8 return earls pro-lite 350 Turbo: 321ss HyTech Turbo Manifold PTE GT35R .63hot .70 cold 321ss 3" dp Tail 46mm wastegate Tial 50mm BOV Laminova Liquid-air intercooler Custom water tank Meziere Water pump Custom PWR Front mount heat exchanger -12 earls pro-lite 350 lines Engine Management/Ignition: MoTeC M400 Custom Mil-spec harness M&W Pro-14 Ignition box T1 Hall Effect trigger setup Honda CBR 600f4i Coil sticks AEM 3.5bar MAP MoTeC/GM 105kpa Baro sensor AIM Sports Strada Dash (via CAN bus) Transmission: GSR Trans Quaife LSD Tilton Twin disc, Carbon/Carbon Tilton Hydrolic T/O Bearing Tilton reverse mount clutch pedal Tilton 3/4" Master Cylinder DSS Stage 3 drive shafts HaSport linkage Suspension: Energy Suspension poly bushings all around. LCON Traction bar (Welded in) Coilovers.... (undecided and un-purchased) <--last thing needed ![]() I'm Sure I missed something.... Heres a old pic before when i was running a AEM EMS+AEM C2DI COP setup ![]() With GSR Cams it made 420@12psi on 91octane pump gas. EDIT: side view Modified by TrueNorthStar at 2:50 PM 3/5/2007
***R.I.P. Earl Laskey*** Laskey Racing Engines http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif http://www.laskeyracing.com |
#11 |
Amazing setups guys!!! Keep 'em comin!
#12 | |
www.PhillyDynoWorks.com For all your Tuning Needs <U>Need Any Fab Work Done At Reasonable Rates Pm Me</U> |
#13 |
Bump!
This is the thread I have been waiting for!
90 HF - B18B swap 03 Cobra - 566rwhp/515rwtq |
#14 |
Wow, those cars definately make me miss my hatch.....
#15 |
1994 Toyota Supra |
Block: b20z2 rs sleeved 84.5mm JE 9.0/1 Pistons Crower billet rods stock b20 crank ITR oil pump stock crank pulley oem honda b16 bearings Head: b16 head ferrea stainless valves Supertech springs, retainers CTR Cams hayame cam gears Intake + Fuel: edelbrock victor x manifold hondata img mr. gasket 68mm tb mr. gasket fuel rail Fuel Rail RC 1000cc injectors Bosch 044 fuel pump 5 gallon fuel cell aeromotive fuel regulator -6 feed -6 return earls lines Turbo: custom made ramhorn Turbo Manifold (lovefab replica) garrett GT35R .63hot .70 cold 3" open dp Tail 44mm wastegate Tial 50mm BOV ebay fmic 2 1/2" stainless piping Engine Management/Ignition: Hondata s300 MSD pro billet distributor setup magnecor 8.5mm wires ngk 9's Gm 3 bar MAP Transmission: type r tranny Trans stock LSD Exedy Twin disc DSS Stage 5 drive shafts HaSport linkage hasport mounts Suspension: Energy Suspension bushings all around. Avid Traction bar K-sport suspension function7 rear lca's suspension techniques rear sway bar 464whp 301tq on 93 pump 549whp 345tq on 110 race gas (peeling out in 4th on the dyno as you can see in graph)![]() ![]()
sold to dinuguan, robs_b18c, vtecn8ive, joedubovik, civicdxtyper, themilman, ludeDVR,PinkMaggit,CheechJDM,igotcrx,two_cam_ham,r ice a roni,VspecSiR,krayjeegsr,rogue3221,gabebauman |
#16 |
^^ Wow, your setup makes my pants tight...
#17 |
As soon as I get home I will post pic and the set up but for now made 461hp at 25psi and 370ftlb on a t3t4 57trim turbo times are in my sig. and yes I drive it to work just in case old boy in his Mustang wants some
Modified By KC 91 EF Dailey driver 10.90 131mph 25psi on slicks 12.6 114mph 15psi on street tire 92 EG 10.31 145mph SFWD 91 CRX 9.81 151mph HOTROD |
#18 |
Oh that sounds nice, can't wait.
#19 | |
#20 |
wrenchin'
i'll post up mine later, posting to save my spot!
96 Frost White GSR Sedan- greddy kit on 10 psi tuned on crome-current 95 Cypress Green Accord EX wagon- cruisin' |
#21 |
Banned
here are a couple of pics.
Modified by turboteener at 5:09 AM 10/6/2006 Modified by turboteener at 5:25 AM 10/6/2006 |
#22 |
i'll add mine dont really have any new pics, havent had any time to work on the car in the last 2 months. setup is as follows;
ls/vtec stock sleeves weisco's/eagles crane cams springs/retainers act clutch/phantom grip lsd edelbrock jg intake holset hx35 custom topmount/2.5"charge piping/3" dp & exhaust tial wg/bov precision 600hp cooler precision 780cc inj turbosmart dual stage zdyne gold ecu no numbers or even a decent tune yet but hopefully soon, or next year ![]() ![]()
Holset powered 91 civic dx ls/vtec 11.5 @ 124mph (12psi) |
#23 |
Banned
Damn why are my pictures so big?
#24 |
lol, just resize with paint or something
#25 |
can you run the head light with the filter
and the car is very clean looks nice under the hood
| Bookmarks |
| Tags |
| 84mm, boosted, dsm, ef, ej1, felpro, gasket, gsr, hatch, head, honda, intercooler, mount, side, tech, thread |
