> Acura Integra Type-R
Old 10-02-2006, 11:10 AM   #1
Gadget
Gadget's Avatar
Send a message via AIM to Gadget
Default MAJOR Differences between B-series CTR/ITR and USDM transmissions..
5 REASONS JDM CTR/ITR TRANSMISSIONS ROCK YOUR SOX!
1) Reverse Needs to be just as strong as any other gear.. Who knows! It might come in REALLY handy when you're running from the cops! =0 So they used a long shoulder Reverse anchor bolt that's ALOT stronger than the USDM performance counterpart on the left..
2) They have Keyed pinion shafts that have ALOT nicer alloy steel and keyed shaft to prolong HIGH RPM operation during long intense workouts!
3) They have Keyed Pinion spring washers! It may sound like jibberish.. But in fact, this washer is sandwiched between the 5th gear load bearing and the nut that holds the ENTIRE shaft together.. If it spins, the nut will follow.. That could be REALLLLLY bad!! The key in the washer prevents this from happening!
4) When you're slamming gears at 9,000 RPM the last thing you wanna hear or feel is the "nails on a chalk board" sound of gears grinding.. This is put in check by using FORGED STEEL shift forks (Right) where as the flimsy USDM sheet metal ones are known to flex under load.. (left)
5) EVERYONE will agree "LSD or NOT-LSD? IS NEVER A QUESTION!" Since it's a standard option on ANY TYPE-R, they are some of the most desired..
TYPE-R is more than just a HP number and a badge.. It's about superior performance..
Modified by Gadget at 7:39 PM 10/2/2006
95 Civ DX coupe, ITR suspension, GSR brakes, B18C1, S4C trans..
Ready to kick ass.. http://images.honda-tech.com/set1/smile/emsmile.gif
Gadget is offline Report Post   Reply With Quote
Old 10-02-2006, 11:44 AM   #2
Stinkycheezmonky
Suspetise...
Stinkycheezmonky's Avatar
Send a message via AIM to Stinkycheezmonky
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (Gadget)
Sheet metal shift forks? Are you smoking crack?
ShifterKart Mafia Member 005
Originally Posted by .one lane View Post
spec miatas are killers of everything on the track. if you're lucky to pass one, it's most likely on the straights.
Stinkycheezmonky is offline Report Post   Reply With Quote
Old 10-02-2006, 11:54 AM   #3
type B16
type B16's Avatar
Send a message via AIM to type B16
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (Stinkycheezmonky)
theye are thinner than the jdm
this is gona be another JDM IS BEST thread
baaaaahhhhhh "vtec!" BAAAAAHHHHHH :chirp: "oh shit thats fast!"
type B16 is offline Report Post   Reply With Quote
Old 10-02-2006, 11:58 AM   #4
Dat1BVtecN
Dat1BVtecN's Avatar
Send a message via AIM to Dat1BVtecN
i like this thread! good shit man!
SpoOlinDC4u
DC Squad member #0390
Keeping my car... aiming for 450whp Spring 10'
Dat1BVtecN is offline Report Post   Reply With Quote
Old 10-02-2006, 12:05 PM   #5
Stinkycheezmonky
Suspetise...
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (Dat1BVtecN)
Thinner or not, they're not made of sheet metal.
Old 10-02-2006, 05:32 PM   #6
BlueTeg
BlueTeg's Avatar
LOL.
06 Nissan Frontier, daily driver and tow rig
94 Civic, track toy
BlueTeg is offline Report Post   Reply With Quote
Old 10-02-2006, 10:43 PM   #7
WickedKP
WickedKP's Avatar
I agree. almost makes me wanna get a REAL JDM RHD Type R.
01-0843
Stuff 4 Sale Click Me
WickedKP is offline Report Post   Reply With Quote
Old 10-02-2006, 10:48 PM   #8
spock_rocker
memoryFAB.com representative
Send a message via AIM to spock_rocker
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (WickedKP)
i love the last picture.. makes me smile cause i have one!
spock_rocker is offline Report Post   Reply With Quote
Old 10-03-2006, 02:10 PM   #9
Gadget
Gadget's Avatar
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (spock_rocker)
Sheet metal dosen't JUST refer to thin flimsy "sheets of metal"..
metal is refered to as "Sheet" because thats the form it takes before it's made.. It's a large piece of steel that is flat and has uniform thickness.. Sheet metal can refer to 1/4" (.250") thick sheet metal.. Would you rather I say "Plate"??? It means almost exactly the same thing.. Learn to use a dictionary..
"sheet metal." WordNet® 2.0. Princeton University. 03 Oct. 2006.
<Dictionary.com http://dictionary.reference.com/browse/sheet metal>
Anyhow, if you couldn't tell, the "SHEET" of steel is stamped into the shape of a shift fork then welded to the shift rod and slightly machined then coated.. The design was simple and cost effective since forging steel is alot more labor intensive and takes more resources to produce..
The shafts are VERY similar but I was also noticing that the 1-2 shift fork on the USDM version is 3 pieces whereas the JDM-R Version is 2 piece! That's one of the most abused pieces in the whole shift assembly and in the JDM version, it's one of the strongest pieces!
Old 10-03-2006, 02:21 PM   #10
Mr. TopFuel
Mr. TopFuel's Avatar
Makes me rest a little better since i have a JDM ITR tranny.
FS: 98 Rear bumper
*Legendary Status*
Mr. TopFuel is offline Report Post   Reply With Quote
Old 10-03-2006, 02:26 PM   #11
. a d a m
. a d a m's Avatar
LOL
Adam
2003 Tarmac Black Mitsubishi Lancer Evolution VIII
2009 Yamaha VX110 Waverunner
. a d a m is offline Report Post   Reply With Quote
Old 10-03-2006, 04:36 PM   #12
blinx9900
blinx9900's Avatar
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (. a d a m)
me too i have ctr but third grinds
ek9.org <--- a place for the ek/ej lovers
[b]FS: Racing Hart C2's 17x7 4x100
otaku squad member #004 http://images.honda-tech.com/set1/smile/emsmile.gif
blinx9900 is offline Report Post   Reply With Quote
Old 10-03-2006, 05:16 PM   #13
743power
743power's Avatar
Send a message via AIM to 743power
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (cusco9900)
when i rebuilt my us gsr trans, it had the jdm style shift forks. . .
"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
-Albert Einstein
743power is offline Report Post   Reply With Quote
Old 10-04-2006, 05:27 AM   #14
Stinkycheezmonky
Suspetise...
Sheet metal means a sheet of metal, like the kind you buy at Home Depot. That implies extreme flimsiness. Stamped metal would've made sense, as there are lots of stamped pieces, like ITR LCAs. I don't think I've seen anyone complain about how weak and flimsy those are.
Old 10-10-2006, 09:59 PM   #15
kepani
kepani's Avatar
let's not get all wound up in semantics...
thanks for the excellent post!
*information is power*
kepani
2008 SSM Honda Fit Sport
2001 NBP Acura Integra Type-R #1053
http://www.corner3garage.com
kepani is offline Report Post   Reply With Quote
Old 10-10-2006, 10:02 PM   #16
cambopheonix56
cambopheonix56's Avatar
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (kepani)
Hmmm, I have read this befor somewhere. Either way, good info
Vouches: civic_speed99, accordinglyevil, 95greenteg, 92integra_gs, whiteef6, travis420
cambopheonix56 is offline Report Post   Reply With Quote
Old 10-10-2006, 10:30 PM   #17
Rene M
1973 Acura Integra
My Garage
Rene M's Avatar
Default Re: MAJOR Differences between B-series CTR/ITR and USDM transmissions.. (cambopheonix56)
a)I can say i have never found shift forks that look like that in an s4c or an s80.....
b)I can say that CTR lsd from what i have learned is not very reliable and the thorson works much better "Personal extreame track use experence"..
c) the forks/deep slot on the shaft and the reverse bolt are all found in 99 and up s80 and s4c trans. you left out the new design of the reverse rear which no longer has a shim and is an all cast piece " hense the odd bolt"..
there are at least 6 other diffrences in the late model Hydro trans that i can also point out if you would like. These are the result of failures in the early hydo design not and effort to build a better trans to run from any one "the ctr lsd was dropped due to its weight and the fact they burn up" " on another note the ctr lsd eats 8% more hp up due to its much heaver weight which is why the ctr's #s were lower than expected.
I can go on but its late.
95 E36 M3
88 CRX ( GRM car)
70 Boss 302
00 Type R " Track car"
Rene M is offline Report Post   Reply With Quote
Old 10-10-2006, 10:36 PM   #18
S-=N=-A-=K=-E
S-=N=-A-=K=-E's Avatar
Send a message via AIM to S-=N=-A-=K=-E
JDM
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
1989 Honda Prelude SI
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
S-=N=-A-=K=-E is offline Report Post   Reply With Quote
Bookmarks
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or iPad advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
