> Honda Accord (1990 - 2002)
Old 09-21-2006, 07:41 AM   #1
TheMuffinMan
He knows where you live!
TheMuffinMan's Avatar
Default Wheel Spacers
Curious to know if anyone is using wheel spacers on their CD5 accord? I would like to space them outwards and make them a bit more flush with the fender than what they are (I was thinking the 15mm ones from Eibach). BUT i've heard stories where shit breaks because people used just a spacer and no longer lugs etc. Anyone have experience on it?
2004 NFR S2000
Originally Posted by slomofo
I think TheMuffinMan is Chuck Norris. Seriously, you can't find the TheMuffinMan,TheMuffinMan finds you.
TheMuffinMan is offline Report Post   Reply With Quote
Old 09-21-2006, 11:02 AM   #2
tchen415
tchen415's Avatar
Default Re: Wheel Spacers (TheMuffinMan)
I tried it on my cd before. I didnt notice much difference. The wheel did come out more but it wasnt what i was hoping for. Plus it didnt really fit that good. It was kinda loose. But maybe thats just me. Wheel 18" wheels, spacers and a fender roll. that would look hot
tchen415 is offline Report Post   Reply With Quote
Old 09-21-2006, 12:12 PM   #3
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
15mm is quite a bit. I assume you are referring to the Eiback Pro-Spacer?
I used 5mm wide spacers on my Accord with longer studs and didn't have any problems.
The only thing I didn't really like was there were no hub centric rings on my spacers making sure the spacer and rim were running concentric to the hub. Thats partly why I stopped running spacers. I didn't have a problem, just didn't like not having the rim concentric.
The Eibach spacers say they come with longer studs and hub centric rings so I would think they would do just fine as long as you have the room to fit them under there.
TouringAccord is offline Report Post   Reply With Quote
Old 09-21-2006, 01:49 PM   #4
wachter
wachter's Avatar
Send a message via AIM to wachter
Default Re: Wheel Spacers (t0EkNEE415)
No kiddin'. That would be suuuuuhweeet.
wachter is offline Report Post   Reply With Quote
Old 09-21-2006, 03:38 PM   #5
jdmcd7_cali-luv
jdmcd7_cali-luv's Avatar
Send a message via AIM to jdmcd7_cali-luv
I'm using spacers on the fronts right now,
its the only way i could get the ITR's to fit.
Cali-luv - NastIE Garage
My H22 Turbo Accord Build : http://www.honda-tech.com/showthread.php?t=2396753
jdmcd7_cali-luv is offline Report Post   Reply With Quote
Old 09-21-2006, 03:41 PM   #6
TheMuffinMan
Well what I have is the 94/95 EX wheels and my car's basically slammed, there's very little camber in the back and it's easily 1 - 1.5 inches inward from the fender and was thinking the 15mm wouldn't be too bad ~3/4 inch or what not
2004 NFR S2000
Old 09-21-2006, 08:36 PM   #7
iam7head
iam7head's Avatar
Default Re: Wheel Spacers (jdmcd7_cali-luv)
same here, i used to use a casted cheap 5mm for the front.
anything over 5 mm and you are running into risk.
make sure you have extended studs
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders)
Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury)
iam7head is offline Report Post   Reply With Quote
Old 09-21-2006, 10:15 PM   #8
jdmcd7_cali-luv
Default Re: Wheel Spacers (iam7head)
Yeah, I plan on using bigger ones and putting some in the bcak,
once i get the extended studs
Old 09-22-2006, 02:00 AM   #9
eagleclawracing
eagleclawracing's Avatar
Send a message via AIM to eagleclawracing
Im using spacers its workes out just fine i use the stillin kit where it bolts on to your stock then uses its own as your new lugs. if that makes any sence
94 honda accord lx
18 oz racing rims, h&R Drop spirngs with agx 8 way adjustable struts
re xxx 18 with viper 1200ds
acura TL balck leather seats momo everything
WIDE BODY!! M3 tail light conversionEvo 3 front bumper black widow side and a custum rear bumper. evo cf hood WIDE BODY!!!!!
Intake muffler pullys spark plugs and 50 shot wet kit
eagleclawracing is offline Report Post   Reply With Quote
Old 09-22-2006, 05:26 AM   #10
teamlegacy
Send a message via AIM to teamlegacy
Default Re: Wheel Spacers (eagleclawracing)
H&R spacers - Options Auto
I just got a pair for the front of my CB. Nice quality, only 5mm. They came with longer studs, but I went with ARP extended either way. I have yet to put the wheels on, so after that I'll try and let you know if there are problems.
'93 Accord LX Sedan - New Project
'92 Accord DX Sedan - Project CRUSHED
'07 Trailblazer SS - 400hp - FOR SALE
teamlegacy is offline Report Post   Reply With Quote
Old 09-22-2006, 07:00 AM   #11
khunt0012
Meat Robot Invisible
khunt0012's Avatar
Default Re: Wheel Spacers (teamlegacy)
15MM seems kind of big. I used a 1/8th spacer on my car to clean my Prelude VTEC brake setup. I just got some new rims 16X7's and they sit really flush so I just ditched the spacers as they clear the calipers with ease compared to my ITR rims.
If you want to go 15MM I'd suggest going with some extended lugs.
94 Honda Accord - H22
khunt0012 is offline Report Post   Reply With Quote
Old 09-22-2006, 07:31 AM   #12
TheMuffinMan
I'll try to take a picture of my car sometime this weekend and show you all, there really is a pretty large gap between the tire and the fender, I was thinking I might even be able to push like 20mm's ok but didn't want to risk any rubbing or damage to the lugs. My front wheels are about even with the fender but I've got some negative camber atm so I was probably just going to go and try the spacers in the back.
2004 NFR S2000
Old 08-29-2009, 06:15 AM   #13
xjohngox
xjohngox's Avatar
Send a message via AIM to xjohngox
I have some friends who placed spacers.. then for the longer studs, they got some oem studs of the 1st gen CR-Vs. a bit longer than the ones in the accords, but just right if you're planning 5-10mm spacers.
xjohngox is offline Report Post   Reply With Quote
Old 08-29-2009, 08:41 AM   #14
TouringAccord
H-T Order of Merit
thank you for the contribution but I just want to make sure you realize this thread is 3 years old
Old 08-29-2009, 10:59 AM   #15
P_Adams
P_Adams's Avatar
True, the hub centering rings / provisions are very inportant.
Years and years ago, I favored Cragar Classic rims for my ride (at the time). Beautiful finish, industry standard, but they had an oversized center hole to allow a more universal fit.
It took everything I could to make them run true, even to the point of having the tyre tread shaved.
Make every effort to make provisions for wheel centering.
P
WOW, I didn't realize it had been resurrected.
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare)
One more "What's the Top Speed..." thread and I think I'll flame someone
P_Adams is offline Report Post   Reply With Quote
Bookmarks
06, 2005, 5mm, 96, accord, acura, cal, concentric, hondatech, hub, spacer, spacers, tl, wheel, wheels
