| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Dealer Listings | Garage | Vendor Directory |
#1 | |||||
#2 |
What kind of noise is it?
#3 |
Sanji
Might be your CV's knocking from dropping the hub too quickly. It might also be that the springs aren't sitting on the perch correctly, and are making a cracking noise.
#4 |
well when my friend turns the wheel. it sounds like a popping noise. when i look at it the spring it is popping back and forth like it isnt tight enough but it is. sorry very hard to describe. any more info would be helpful gonna try to fix it today
#5 |
Chances are you assembled the front strut incorrectly at the top. Take them back off and make sure. Usually just lowering springs don't cause noises unless you assemble them wrong.
#6 | |
Purpose-built Slow Car 562 Represent http://www.myspace.com/melvinlovesburningtires RIP Ming Shin AKA 1llmatic |
#7 |
sounds like your upper mounts arent on there right. and make sure the balls inside the bearing race didnt fall out...the very first time i lowered my car i backed my car out just to see a whole bunch of grease covered balls in my driveway. live and learn..
'02 SSM EM2 D17A1.5 turbo (daily) 240 fwhp, 209 ft/lb tq @ 9.3 psi '91 toyota supra 7MGTE targa turbo (track) wouldn't you like to know ASE Certified Master Technician and Advanced Engine Performance Specialist (A1-A8, L1) |
#8 |
ther's an arrow on the upper rubber mount where ur springs goes it has to face outward i had the same problem wit mine so just take the springs back out and position the top mount right and it should fix the problem..............
#9 |
I just put stock springs back on my 01 Civic. I am having a similar problem it sounds like. When I turn the wheel, I am hearing a popping noise from both sides. I will take a better look at it tomorrow.
#10 |
DUD your installation was not correct..
http://www.7thgencivic.com/for...86545 Do this and you should have no problem....
2001 EX Coupe Rally Red 5 Speed.. 2008 CR-V EX-L 4WD Black on Black A wiseman fears and departs from evil but a fool rages and is self-confident. Proverb 14 |
#11 |
make sure they were installed right, I had the same exact noise, and it turned out that my springs were installed upside down ftl
THE FORTUNATE FEW ARE COMMING!! |
#12 |
Thanks Devani
Fixed my problem, good as new! |
#13 |
happy motoring..
#14 |
good to hear
#15 |
what did you end up doing?
#16 |
i have the same popping noise problem with my 2001 civic on the driver side, could it be the spring?
#17 |
Sounds like your top mount bearings.
2001 civic ex DD 1995 civic dx project http://images.honda-tech.com/set1/smile/emsmile.gif |
#18 |
Asleep in the Back
I had a whole world of problems with this too... I'd say Sean DM might be right on this one.
~ CW DC5 Integra Type R ~ |
#19 |
whoohoo finally!
#20 |
yeah mines made the same noise until i found out my top strut bearing needs replacing
I love the smell of burnt Rice |
#21 |
um... this thread is like 5 months old...
Canon Kiss Digital X w/ BG-E3, 18-55mm f/3.5-5.6 USM, 75-300mm f/4-5.6 III, 50mm f/1.8 GA-P35-DS3L | Q6600 @3.0 | A-DATA 4GB DDR2 | OCZ Gamer XStream 700W | eVGA 9800GX2 | D-TEK FuZion v2 | D-TEK GPU2 | D5-Vario |
#22 |
^oops haha im hella late
#23 |
I have a 03 ex and had the same problem.I replaced the bearing perches and still it did.then I procrastinated and then just realized three day's ago that it was gone.
I'm thinking they settled. |
#24 |
hmm, seems like a lot of people had problems with spring installation on their em2.
(including myself) but we fixed it the same hour haha |
#25 |
i replaced my bearing in mine but i also have that popping noise still.
| Bookmarks |
