> Honda CRX / EF Civic
Old 09-12-2006, 04:50 PM   #1
QuickStyle
QuickStyle's Avatar
Default Engine Knock under load / acceleration, VIDEO INSIDE!
88' honda crx si with ZC engine. out of know where my engine starts to make this knocking noise... it only does it under load and higher rpm's. i have pretty much ruled out rod knock because it does not do it at all times, sounds to me like the valve is hitting the piston. the car runs perfectly fine, no hesitation and pulls hard (for a 1.6L Sohc). watch this video and tell me what you guys think.
Click Here for Video
QuickStyle is offline Report Post   Reply With Quote
Old 09-12-2006, 05:06 PM   #2
rbjeepthing
rbjeepthing's Avatar
Default Re: Engine Knock under load / acceleration, VIDEO INSIDE! (QuickStyle)
your vid is too short to tell
rbjeepthing is offline Report Post   Reply With Quote
Old 09-12-2006, 05:13 PM   #3
QuickStyle
QuickStyle's Avatar
Default Re: Engine Knock under load / acceleration, VIDEO INSIDE! (rbjeepthing)
its 25 seconds long.... maybe it didnt load fully, it only played for like 0.5 seconds the first time i tried to watch it. but it worked after that.
Old 09-12-2006, 05:19 PM   #4
iphatcrxi
iphatcrxi's Avatar
Send a message via AIM to iphatcrxi
you got a cam in that thing? mine sounds the same way, like a diesel or something lol but it doesnt have that kocking noise
91 CRX Si D15b OBD1
Those that matter don't mind...and those that mind don't matter.
Vouches: http://feedback.ebay.com/ws/eB...380si
FS: D15b cam
iphatcrxi is offline Report Post   Reply With Quote
Old 09-12-2006, 05:37 PM   #5
QuickStyle
QuickStyle's Avatar
its just the stock cam that came with the zc engine. the noise you are hearing is the injectors ticking, thats normal. glad to hear you dont have the knocking though
Old 09-12-2006, 05:47 PM   #6
janz3n
janz3n's Avatar
Default Re: (QuickStyle)
holy hell.. what the hell is that noise.. doesnt sound good at all.
EFSS #24
i love honda
janz3n is offline Report Post   Reply With Quote
Old 09-12-2006, 06:03 PM   #7
ludesrv
ludesrv's Avatar
Take it easy man. No need to worry. If it 'pulls hard' it's something small, but that's hella loud you need to figure it out.
I'd try:
Valve adjustement
Compression test (will tell you of a piston ring failure, piston slap and bent valves, or help you in figuring it out)
Timing belt check for tightness
Waterpump bearing
Tensioner
Re-Torque the top end, something might be loose
If all those where done right and nothing needs changing, I'd pull the head. Check the valves and what not. After that, I'd yank the engine and disassemble it.
1990 LS Honda Civic Hatch (RIP) 14.57@92MPH w/ 2.0 60'
1991 SOHC Honda Civic Wagon (For Sale = 2100$)
1996 SOHC Honda Civic DX
ludesrv is offline Report Post   Reply With Quote
Old 09-12-2006, 06:18 PM   #8
QuickStyle
QuickStyle's Avatar
Default Re: (ludesrv)
oh yea i forgot to mention that the timing belt and water pump has under 10k miles on it, and the belt is tight. and you can tell its coming somewhere from the head/block not any accesories. i just checked it the other day when it was making the knocking noise. i adjusted the valves to specs when i changed the timing belt, and i also rechecked them when i started hearing the noise, all are within spec. i backed the valves off a bit to see how it ran and same thing, knocking noise, adjusted them tighter than spec and same thing, knocking noise. so i adjusted them back to spec. i did a compression check, book calls for 128psi per cylinder with no more than 28psi variation. read out to be 210-210-215-215. im asuming it is higher than the book calls for because the zc engine has more compression than stock... correct me if im wrong on that. i should probably do a "leak down" test, that would be more accurate, but i dont have the equipment at the time.
Modified by QuickStyle at 7:06 PM 9/12/2006
Old 09-12-2006, 06:30 PM   #9
crx_88_si
crx_88_si's Avatar
in the earlier part of the video it sounds like rod bearing noise...
check oil level...
Vouche: Jay-C
My Car: http://www.cardomain.com/id/crx88si
crx_88_si is offline Report Post   Reply With Quote
Old 09-12-2006, 07:02 PM   #10
QuickStyle
QuickStyle's Avatar
Default Re: (crx_88_si)
i also forgot to add that i changed the engine oil like a week ago after i started hearing the noise (didn't help the noise go away, and there were no metal shavings in the old oil), i put in chevron supreme 10w30, and a new filter. plus im like 99% sure its not a rod bearing, i had it up on a hoist and listened right by the oil pan, and you cant hear it as well as you can from up top. only have running time sitting in my yard, no miles since the oil change, and level is fine. i also change the spark plugs at the same time gapped at .045 i went with ac delco, i had ngk but i was changing those too often, so im trying something new.
i also misinformed about the compression test, i checked my records (yea i keep records of this kind of shit) and the test showed 210-210-215-215 in numberical order 1-4. now that i think of it, thats kinda of really high compared to specs.
Modified by QuickStyle at 7:29 PM 9/12/2006
Old 09-12-2006, 07:05 PM   #11
civiconfire
civiconfire's Avatar
change the oil...make sure there is no metal shavings in it...if there is...well...rebuild it or get another engine.
and yes it sounds like rod knock
my job is fun...> http://srcracing.com/
civiconfire is offline Report Post   Reply With Quote
Old 09-12-2006, 07:17 PM   #12
PINKS
I want a CRX tattoed on my butt
PINKS's Avatar
Default Re: Engine Knock under load / acceleration, VIDEO INSIDE! (civiconfire)
that 100% sounds like my motor on the week I spun a rod bearing, mine also ran for almost a week like that before it gave out
PINKS is offline Report Post   Reply With Quote
Old 09-12-2006, 07:17 PM   #13
aXhatch
aXhatch's Avatar
Send a message via AIM to aXhatch
Are those lines infront of the header AC lines?
Just wondering cuz today at the dealership we ahd a CRV come in with ALMOST the same noise, but it only happened in reverse.
turned out that it was an AC line hitting the ?pump? i believe. Its just an idea but check to make sure its not that.
we had the CRV up on a hoist for an hour or better, and it sounded internal (rod) or like a pulley hitting. it was harder to ehar underneath than above, Im just saying try it.
aXhatch is offline Report Post   Reply With Quote
Old 09-12-2006, 07:24 PM   #14
1990si
1990si's Avatar
Default Re: (aXhatch)
knocking under load = detonation. check timing
Vouches-
ecotec24, 1_Slo_Zc, Surewin, widebody96, paopao, dustin_crxsi, pdiggitydogg, boostedDA, Akiraboy,benihana881, stdefhatch, HxCforever, Nisif, and more.
90 ef
d16z6 Swap
hmt kit 9lbs
206whp
1990si is offline Report Post   Reply With Quote
Old 09-12-2006, 07:35 PM   #15
QuickStyle
QuickStyle's Avatar
Default Re: (1990si)
True. there are a few things that lead away from thinking that...
even when i hold the throttle steady, say around 2k-3k the knocking is there, plus it sounds like its only coming from one of the cylinders more than likely the 1 and 2 cylinders, is it possible for only one cylinder to detonate? you can kind of see the timing light sitting on the car at the end of the video, i did check timing 14*. i tried putting it at 8* and 20* no difference between the two, the knock is still there, timing set back to 14*.
Old 09-12-2006, 07:44 PM   #16
efHondefender
efHondefender's Avatar
Send a message via AIM to efHondefender
I'm putting my guess in as main bearing failure. sometimes spun main bearings won't knock unless under load. But I think piston slap from ovalized cyllinder walls is another good guess. Something like that usually doesn't happen over night though.
Driven by the spirit of Soichiro
efHondefender is offline Report Post   Reply With Quote
Old 09-12-2006, 07:45 PM   #17
1990si
1990si's Avatar
you are most likely a couple teeth off on your timing belt. My car had the same symptoms, fixed the belt and ran like a bat out of hell
Vouches-
90 ef
d16z6 Swap
hmt kit 9lbs
206whp
Old 09-12-2006, 08:13 PM   #18
QuickStyle
QuickStyle's Avatar
that couldnt be possible, this is a problem that started out quiet and got louder. if the teeth were off on the timing belt it would have had this problem when i first installed it, i got about 8,000 miles since i put the new belt on then all of a sudden in a matter of 40 miles this problem developes. only way i seeing this as the belt being off a couple of teeth would be if the belt slipped then tightened itself back up, dont think that could happen and if it did, it probably wouldnt be a pretty sight, and it probably wouldnt run/perform as well as it does(besides the knock). i was hoping to not have to pull the head off to check this, but it looks like i will have to, if the head checks out ok, then it would have to be something in the bottom end right?
Old 09-13-2006, 03:33 AM   #19
SETI20
SETI20's Avatar
Send a message via ICQ to SETI20 Send a message via AIM to SETI20
Sounds awfully like rod knock. Mine sounded the same when the crank bearings were going out.
FS: EDM CRX ZC H4 glass power headlights
I ship EDM parts direct from Europe. Message me with your requests.
Flickr
SETI20 is offline Report Post   Reply With Quote
Old 09-13-2006, 04:54 AM   #20
salman
Blown Big end bearing,
Change them as fast as u can, else u ahve to get a new crank, '
salman is offline Report Post   Reply With Quote
Old 09-13-2006, 05:50 AM   #21
daidilus
daidilus's Avatar
Send a message via ICQ to daidilus Send a message via AIM to daidilus
does it make the sound when the clutch is depressed my throwout bearing is going out, it sounds just like that when the clutch is let out
daidilus is offline Report Post   Reply With Quote
Old 09-13-2006, 06:28 AM   #22
crx_88_si
crx_88_si's Avatar
its a bearing man.. metal shavings might not appear.. pull the rod caps and check it out.
Vouche: Jay-C
Old 09-13-2006, 04:28 PM   #23
MENACE
MENACE's Avatar
Default Re: (SETI20)
Mine too, Ive heard a shitload of knocks in Hondas and they all sound like that. Dont let anyone tell you different. Last time i heard one like that The motor lasted the guy a week, He was cruising on the interstate and suddenly lost pressure, needless to say the number 2 rod poped out of the front of the car a few miles later. If it hasnt been doing it long i would try to roll new Bearings in it, there not very expensive. kinda a pain to do but better than buying a new motor.
Rip
JDM D15B HydroLocked
New setup:
Z6/B7 Mini me.
Obd-0, I,H,E VAFC-II DX trans, Z6 intake and injectors
MENACE is offline Report Post   Reply With Quote
Old 09-13-2006, 05:05 PM   #24
white90rexsi
white90rexsi's Avatar
Send a message via AIM to white90rexsi
Default Re: (MENACE)
Have you tried a mechanics stehascope and listning to diffrent areas. That sounds just like my b16 when I spun a rod bearing. How is your oil pressure? Does the light come on at all? I would drop the oil pan and pull the rod caps off and take a look at everything. Its easy enough to do and sounds like the problem.
white90rexsi is offline Report Post   Reply With Quote
Old 09-13-2006, 07:33 PM   #25
XYZ -HsM-
XYZ -HsM-'s Avatar
Send a message via AIM to XYZ -HsM-
ROD Knock
"SUCK MY EF'N DX" http://images.honda-tech.com/set1/smile/emsmilep.gif
-16,EF9 DX and JDM inspired
XYZ -HsM- is offline Report Post   Reply With Quote
Bookmarks
