#26 | ||||||
Sanji
#27 |
will rsx konis fit on a o4-o5 with (55mm fronts)?,,thanks
#28 | |
Sanji
#29 |
when i did my 5lug conversion, i used dc5 control arms along with it. Will that help me fit dc5 spec coilovers?
|2004 K20r Civic| Vouches: Spids5|Danio|JDM_FRONTIN|Civic Si Chic|Donut.|ToyotaLover|jgirard |
#30 |
civic and rsx LCA's are the same.
#31 |
what was the final word on dc5 ---> ep3 suspension compatability? is it just the tie rod ends and your good to go?
Nothing can beat the music of hundreds of voices screaming in unison! -kefka |
#32 | |
#33 |
whoo wait a minute. Just the tierod ends? What bout aftermarket tierod ends for a DC5? Would they work on em2 rods? Hard to find em2 rodends
One of these days Alice. POW, straight to the moon |
#34 | |
#35 | |
#36 | |
Sanji
#37 |
dude , i run an rsx subframe , and rsx suspension , but civic lower control arms. ive had both im my hands. again i say , i run civic LCA's , and everything else rsx. so i assure you , they are the same.
#38 | |
Sanji
EDIT: Here ya' go, bud. ![]() Modified by toyomatt84 at 7:55 AM 3/27/2008 |
#39 |
I just installed TEIN N1 on my 04 civic. They are DC5 spec, they fit beautifully! FYI, for 04-05 civics, all you have to make sure is that you use the tie rods from a DC5, accordingly. For civics 01-03, you will have the crash bolt issue. Hope this helps...
#40 |
does ep3= 55mm strut and 16mm holes?.. if so im guessing getting an ep3 setup for my 02 lx is out of the question
#41 | |
i am using rsx-s everything, suspension, control arms, tie rods, etc
-Freddy myspace.com/fventura03 (add me if you know me) |
#42 |
sorry matt , i thought you were talking the front buddy , my bad. you know you can probably use rsx rear LCA's , but you would have to use it all. chassis out.
#43 |
2004 Honda Civic |
So this is a general consensus based on Boilermarker1 and I encountering the same problem.
If anybody does Koni/GC's and actually order's a GC application for the Civic, the rear springs they send are too small to seat properly. You have to order RSX-S 6" rear springs. I don't know why GC just doesn't do this since I'm sure they've had several problems with this in the past. I e-mailed Mark at Ground Control and he stated that yoparts was not an authorized distributor so I'd have to take it up with Tom directly. So now I'm at a standstill. |
#44 |
If thats the case then i might as well get the buddy club coilovers over the tein ss. Thanks for all the info!
04 Fiji Blue EM2 Type S Wheel|Rota GT3's|Aero sides/CF mugen front|Stripped Interior| Comin soon Kswap|Recaro's|Rollcage|Race headers| |
#45 |
2004 Honda Civic |
You can get away with the standard springs...there's just not much travel. Just get GC's made for the RSX.
#46 |
okay so i know that 01-02 have 14mm bolts and 03-05 have 16mm bolts.. what would be needed to fit this in an 02 lx? and will it fit at all cause of the strut body sizing? 01-02=50mm 03-05=55mm
#47 | |
i can vouch for that... haha. i've tried everything to get my rear springs to seat right.. pretty much impossible.
99 CR NB Miata 02 RR EM2- sold 98 MR EJ8- totaled |
#48 |
Hate to add more questions but if some one with a k-swap could awnser this... During a k-swap even if i were to use ep3 axles and hubs would i need to change out any suspension parts? im running tein basics atm.
R.I.P. Christopher Fox, 4Golf for all eternity. |
#49 | |
Sanji
#50 |
Where do you all get the tie rod ends from? The only ones i found were T1R tie rod ends for 200 dollars..
| Bookmarks |
| Tags |
| 0105, civic, coilovers, dspec, em2, end, fit, honda, pitch, rod, rsx, suspension, thread, tie, tokico |
