> All Motor
Old 07-27-2006, 11:16 PM   #1
Sassafrass
Sassafrass's Avatar
Send a message via ICQ to Sassafrass
Default MY fresh build continues to be a pain** LSV**
Just wondering if I could get some opions on something.
I just had a LSV put together, block was bored/honed for new 12:1 weisco piston set, new valve seals, new everything basically.
First time it went back together it was buring crazy oil, filled my ehasut ports, header, exhaust.
The problem was never clearly identified. We thought it was rings, replaced those, didnt help.
rechecked valve seals, looked good.
even checked cylinder bore/hone, also within spec.
only other idea was an injector issue spraying too much so it wouldnt allow the rings to seat proper.
So a whole new block was bored/honed again, new rings blah blah and this time we put stock b16 injectors in for my rc 440's. and on the street tunned made it very conservative for an easy break in.
It is still burning oil, smoke does come out the exhuast still. If I let it sit for a few hrs on startup a basketball (bit smaller) sized poof of smoke comes out, then it smokes pretty constant for like 5 mins after some driving it clears up, not completely tho.
Also now I have found its smelling like egg's (sulphur)
Plus are clean now tho, were just thinking that it still needs to burn out the residue oil from before. This true? how can I confirm this, or what? I have been following break in instructions form bambam's thread as close as I can.
Basically need to know if it will burn away after driving or how do I know the rings are seating again?
*oil levels are good, and no leaks*
PasswordJDM - JLBMotorsports - AJ Racing - Espec_rep - BodyKits NW -
NoLimitMotorSports - Alchemist - MrHeeltoe - FOX Products - Rage Racing -
MazworxRaceSupply
Sassafrass is offline Report Post   Reply With Quote
Old 07-27-2006, 11:26 PM   #2
Combustion Contraption
Combustion Contraption's Avatar
Send a message via AIM to Combustion Contraption
leakdown test.
wet vs dry compression test.
Burning oil isnt a mystery. There are only a few ways it can happen.
EARL LASKEY, YOU WILL BE MISSED
CCCylinderheads.com
Buy the 85x89 Project Hatchback!
Combustion Contraption is offline Report Post   Reply With Quote
Old 07-28-2006, 11:29 AM   #3
strict 9 ef
strict 9 ef's Avatar
Default Re: MY fresh build continues to be a pain** LSV** (Sassafrass)
who built this motor for u ?
do u have a cat ?
strict 9 ef is offline Report Post   Reply With Quote
Old 07-28-2006, 03:00 PM   #4
Sassafrass
Sassafrass's Avatar
Default Re: MY fresh build continues to be a pain** LSV** (strict 9 ef)
brand new high flow cat
Anyone know why my exhaust smells like sulphur???? what causes this?
MazworxRaceSupply
Old 07-28-2006, 03:50 PM   #5
shrums-EG6
shrums-EG6's Avatar
Send a message via AIM to shrums-EG6
rotten eggs means your cat is working. trust me i know after going straight pipe for a while and then getting a cat.
shrums-EG6 is offline Report Post   Reply With Quote
Old 07-28-2006, 04:37 PM   #6
Mr.RHTuner
Mr.RHTuner's Avatar
Sassafrass, who built your engine?
Mr.RHTuner is offline Report Post   Reply With Quote
Old 07-28-2006, 05:21 PM   #7
Brick Top
Brick Top's Avatar
how did u clock the rings? how did u break it in?
Modified by brick top at 9:51 PM 7/28/2006
MR EJ7 / LS Vtec
190whp / 123wtq
13.4@101 Blundell Tuned
Brick Top is offline Report Post   Reply With Quote
Old 07-28-2006, 06:19 PM   #8
Sassafrass
Sassafrass's Avatar
Default Re: MY fresh build continues to be a pain** LSV** (Mr.R******)
Mississauaga Engines did the machine work and valve seals.
Scott, a buddy up in Milton did the assembly
MazworxRaceSupply
Old 07-29-2006, 05:07 PM   #9
Mr.RHTuner
Mr.RHTuner's Avatar
ah I know scott, got my dizzy and alternator from him
Old 07-30-2006, 11:01 AM   #10
strict 9 ef
Mississauaga Engines THAT IS UR PROBLEM RIGHT THERE no joke they are horrible.
CAESAR has a lot of horror stories.
i bet it is ur valve seals
try putting another head on the block
Old 07-30-2006, 04:27 PM   #11
Sassafrass
Sassafrass's Avatar
Yea, trust me I know that now.
Why would u suggest a entire new head? I think I'll just try to get the valve seals replaced and see where that lands me
MazworxRaceSupply
Old 07-31-2006, 07:30 AM   #12
strict 9 ef
well a friend of mine had a head done by sauga engines and the valve seals were so badly put in that the head was total garbage.
the clearences were so off that even i a new valve seal were to go in it would not seal at all.
i don't think anyone makes oversized valve seals.
i think u should go to GORD BUSH PERFORMANCE 905 677 8657 in sauga
besides tuning it will be the best money u ever spent on the motor.
it wil get done once and it will be done properly that is for sure.
Old 07-31-2006, 12:35 PM   #13
Chillinit
Chillinit's Avatar
Ain't that the Truth! Gord is a rude boy! Save yourself a lot of time and headache.
Don’t believe the HYPE! - Educate yourself
Builder - Gord Bush Performance @ 416-259-9700
Alignment Specialist in the GTA - http://www.levelauto.com/
Chillinit is offline Report Post   Reply With Quote
Old 07-31-2006, 01:52 PM   #14
strict 9 ef
Default Re: MY fresh build continues to be a pain** LSV** (Chillinit)
the guy is a canadian version of port flow , alaniz and import builders he is really that good
Old 08-16-2006, 12:51 AM   #15
AllMotorMark
AllMotorMark's Avatar
sounds familliar ....same problem same result all the way down to the GORD BUSH
GORD is he is the man
11.4 118mph comp4/street all motor
for Dyno tuning in the southern ontario area send an email or pm....
http://www.1320drag.com
AllMotorMark is offline Report Post   Reply With Quote
Bookmarks
