#1 | |||||
1991 Red Honda Civic Si LSVTEC 1990 Black Honda CRX Si parts car 1990 Red Honda CRX HF project / http://www.honda-tech.com/zero...54811 |
#2 |
i give you props!!! damn you put the engine together in your room!! but it looks CLEAN!
#3 |
1997 Honda Civic |
awesome documentation of everything
MissShift vouches: GUILOTINE, blackstar |
#4 |
Yeah. It took me a while to get all the parts, but eventually I got them. I didnt really want to cheap out on anything. I see too many people use old crap like reusing head studs or useing oem rod bolts and them stretching and craping out the motor. I tried to use every precaution in building it.
#5 |
HT White Ops
Good work!! Looks like alot of fun! Go get it dynoed and lets see some #'s!
#6 |
The Boot
wow...this thread will help out the vets and noobs alike.
Sleeper ED9 ![]() #004 EFSFTMFW! |
#7 |
thats mad tyte yo!
Totally diggin' the rising sun action!
91 Civic Si |
#8 | |
454 t56 6 speed 1971 chevy custom 10 |
#9 |
nice project.
Good people: Synapse Motorsports,JDogg,b18c1_powered _si,CHEETAH, 86si,NA_is_best, Astig, McNews Automotive, geardog, 4g hatch, Innovative Motorworks |
#10 |
Moderator
Looks good!!! I like the valve cover and the original idea there.
Hondworks Need a write up on how to fix your CRX cracked climate control, PM me |
#11 | |
#12 |
nice job...
Yup, I'm FernEF http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif THE OFFCIAL BUMPER DISTRBUTOR BYB Back Yard Bumpers 98-01 dc integra front and rear bumpers FS s2k front bumpers,EG,DA,EK.CB7,evoulotion,srt4 PM ME 4 DETAILS! |
#13 |
I'm really diggin the valve cover.
GJ on the build!!!
1991 CRX SI GSR Powerplant. Wire tucked. 2007 Civic SI All stock. Certified A & P Mechanic |
#14 |
Now when you put the oil pump back on, did you use the oem gasket or just gasket maker? IF you only use gasker maker, what over parts could i use it on without the oem gasket?
#15 | |
#16 |
nice write up
GJ and i like the paint work
88 Crx Dx- Sold 89 Crx Hf- Rip (parts car) 90 Crx Si- Current 91 Crx Si- Current Myspace |
#17 |
Nice build up man
On doing your own obd-0 to obd-1 conversion. I would of went with the conversion harness, but ill say it again For doing the conversion yourself
::::97 civic coupe daily:::: ::Need a new project:: |
#18 |
i actually do have the harness. Its just that my car was already wired up for vtec and rywire said that it had to be back at stock wireing. So i had to rewire everything back to stock. I will try and take pictures of the harness and the ecu on and everything.
#19 |
thats some nice stuff man
1991 EF-8 sold to an asshole. http://images.honda-tech.com/set1/smile/emsad.gif 1991 EF-8 SiR (my baby) 1996 Integra LS 2002 eclipse RS beater (sold) http://images.honda-tech.com/set1/smile/emthdown.gif |
#20 |
good job man!!!
#21 | |
#22 |
nice build.
the valve cover is cool.
[1985 CRX Si -Sold] [1989 CRX DX -Junked] [1990 CRX DX (b16a) -Wrecked] [1990 CRX DX -Parted] [1991 CRX Si -Parted] [1988 CRX HF -Sold] 2004 s2000 Berlina MOB #040 |
#23 |
Looks great!
I know how big of a pain in the ass the obd1 swap is!
Boostwerks Time Attack CRX coming soon! www.Boostwerks.com Thanks to: Special Projects Motorsports, Servion Tuning, Cortek Inc, (Your name here!)
#24 |
its not horrible. the the conversion harnesses it makes it a lot easier than it could be. And the wireing to the vtec was pretty hacked up before so it made it easier than if it was done a lot nicer. I just need the obd1 dizzy and its done.
#25 |
Still dont have a dizzy for the obd0-obd1 swap but here are some more pictures of how it went together.
This is the rywire conversion harness hooked up. I ended up only using 4 of the 12 or so wires provided. So I cut them down so they werent in the way. But i didnt cut them enough that wouldnt enable me to resolder on the wires for use. But after I cut them down I put some shrink tube over them so they couldnt ground out or anything. ![]() This is after I put the loose wires inside wire loom. It makes it look a lot nicer. Before they were just wrapped in electrical tape. Which was REALLY fun pealing off and getting black sticky crap all over my hands. ![]() ![]() This is all the extra wireing I got out of my car after the change over. Trust me, I didnt put that much back in it. Looks a lot cleaner now with out all the butt connectors, electrical tape, and crappy wireing job. ![]() Today I just put on my hot moroso oil pan. So I decided I would try and get in the habit of doing more step by step instructions with pictures. But first I must show you how much my oil pan was leaking after just one day sitting. ![]() The tools I used: 1) New oil pan gasket 2) 3/8 and 1/4 wratchet 3) 3/8 and 1/4 extention 4) 3/8 and 1/4 10 mm and 12mm 5) 1/4 knuckle 6) Gasket maker 7) Flat head screw driver 8) Obviously a new oil pan This doesnt show you all the crap I used, but most of it. ![]() ![]() ![]() So first I drained the oil. Dont think we need pictures of that. Then I started unbolting the oil pan (I wanted to get it out of the way before I got too tired to constantly hold my arms up). But there is one bolt that wasnt accesable because the header was in the way. So I used my 1/4 wratchet, extension, and 10mm to get it. I didnt take them all off. I left one on on each side. ![]() I then unbolted the header. Some studs came out with the nuts but whatever. ![]() I then dropped the oil pan out. ![]() After that its just the reverse. I believe the tq specs for the oil pan is 10 ft lbs. Or it was about 108 inch lbs. Here it is installed and looking so hot. ![]()
| Bookmarks |
| Tags |
| 1991, civic, connector, crx, ef, extended, obd0, pictures, pistons, si, skunk2, stud, transmission, wheels, white, yellow |
