Honda and Acura Appearance/Cosmetic Forums
> Group Threads
Old 11-05-2009, 01:23 PM   #24826
Jdmsoles
Jdmsoles's Avatar
Send a message via AIM to Jdmsoles
Default Re: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Originally Posted by Andrew Marquis View Post
Nah I don't know of anyone that still runs the Knock on OBD1's. I know I don't anyway... You should be A-ok homie.
What is your logic on this, because i do not see why you would want to remove a knock sensor when it tells you if motor is knocking/pinging due to heat, octane etc.... i have a obd1 gsr and i still run a knock sensor, because it was recommended for that motor due to compression ratio. Just because you do not care about knocking doesnt mean you should be telling people not to run a knock sensor. ...
Originally Posted by x still jaded x View Post
Fibercation....how are you going to quote YOURSELF in your sig? Thats like referring to yourself in the 3rd person.
Hit me up for any of your part needs asr, fal, hks, gc koni, etc, almost anything...
Jdmsoles is offline Report Post   Reply With Quote
Old 11-05-2009, 01:53 PM   #24827
jmaze
jmaze's Avatar
i had my header flat back ceramic coated while my motor was being rebuilt. i also did not go too crazy on the engine bay. just "cleaned " it up a bit. i have been daily driving my car for almost 16 years so i shaved and tucked for my own taste and needs. here is another.
84 city turbo- RIP
94 vx 260k strong
jmaze is offline Report Post   Reply With Quote
Old 11-05-2009, 02:03 PM   #24828
7rrivera7
7rrivera7's Avatar
I want to see more of that SOHC
EFI Logic - BSerious, B2ned
7rrivera7 is offline Report Post   Reply With Quote
Old 11-05-2009, 04:43 PM   #24829
Arthas
Arthas's Avatar
Send a message via AIM to Arthas
This page is seriously FULL of win.
Originally Posted by crazy View Post
Spoon SW388- To the average person they look like steelies. To the JDM fanboy, they're the 5 lug incarnation of Jesus. Of course, Rotas which look exactly the same are ugly and disgusting.
Arthas is offline Report Post   Reply With Quote
Old 11-05-2009, 10:49 PM   #24830
Paul1985
Paul1985's Avatar
It's only just started. lol.
My EG Build thread: Bay shave, paint, K24a etc.
http://www.honda-tech.com/zerothread?id=1717537
Paul1985 is offline Report Post   Reply With Quote
Old 11-06-2009, 12:51 AM   #24831
Hayce
Hayce's Avatar
Different view's dude, I see 30 posts on this page.
EK sedan from NZ
Hayce is offline Report Post   Reply With Quote
Old 11-06-2009, 01:23 AM   #24832
Paul1985
Paul1985's Avatar
Didn't know you could do that. I see about 6/7 posts on page this page.
You have any updates Hayce?
Old 11-06-2009, 03:36 AM   #24833
pheurton-skeurto
pheurton-skeurto's Avatar
he responded to my original question. its not a big deal. honda engines weren't designed to be boosted, but many of us go that route regardless. we're in a forum where nearly every member has modified some aspect of their car so suggesting someone remove a knock sensor isnt necessarily incorrect or inappropriate. alternatively, anyone with a modified engine on here should have other items in place to detect/prevent knock. ie--additional sensors, wideband o2, a system that's properly tuned, etc...
97 Prelude
99 Civic Si
http://www.slowmotionmotorsports.com
pheurton-skeurto is offline Report Post   Reply With Quote
Old 11-06-2009, 06:40 AM   #24834
Andrew Marquis
Andrew Marquis's Avatar
If the tune is right, you won't need to worry about it. Your stock GSR with a stock tune will not detonate on 93 Octane. Probably won't even det on mid-grade. Just don't be silly and run cheap low grade crap.
In my case (and most cases) I'm running the OBD-1 motor in my EF, so I had to run a conversion harness (Boomslang) so I can have VTEC and the 4-wire O2 sensor. I left the knock out. Haven't had any problems. My tuner doesn't use them anyway, so it works out fine. They can disable it in the tuning program (Mine was tuned on CROME)
1991 CRX SI GSR Powerplant. Wire tucked.
2007 Civic SI All stock.
Certified A & P Mechanic
Andrew Marquis is online now Report Post   Reply With Quote
Old 11-06-2009, 08:30 AM   #24835
pheurton-skeurto
that was my point exactly. when you consider the simplicity of the knock sensor, you begin to understand what it is detecting and how there can be inherant problems with the sensor in general. i know others have had problems with the KS and eliminated it for just that reason.
97 Prelude
99 Civic Si
Old 11-06-2009, 08:39 AM   #24836
JdmOdz
JdmOdz's Avatar
Send a message via AIM to JdmOdz
bumpppp tttt
>>>The Offiial JdmOdz Build Thread<<<
BENEN|SPOON SPORTS|SKUNK2|wēk´sôs INDUSTRIES|TEIN||BUDDY CLUB|CHASEBAY|SOL FRESH|MFS|GEAR-X|FALKEN|JUN|D2|FYAH SQUAD|CERTIFIED DANCER CREW#005
JdmOdz is offline Report Post   Reply With Quote
Old 11-06-2009, 12:35 PM   #24837
Andrew Marquis
Back on topic... Heres my bay right now. Stock GSR w/ SiR Cable trans. Should have another turbo D back in it soon.
Old 11-06-2009, 12:47 PM   #24838
Hayce
Hayce's Avatar
Not in the bay no. Got front brakes (wilwood superlite) suspension pieces (s2 pro c, spherical rta/toe etc) all in it. Heading to the dyno on the Tuesday the 10th, can't wait!!
EK sedan from NZ
Old 11-06-2009, 06:07 PM   #24839
Jdmsoles
Jdmsoles's Avatar
sure, i get what you guys are saying, but what i am saying that removing a ks shouldnt be taken as lightly as removing air bypass valve when redoing a harness, i mean its one wire. leave it.
Old 11-07-2009, 01:20 AM   #24840
4DRmafia
4DRmafia's Avatar
Thinking about tucking my Miata bay. Never seen one done yet. Has alot of space to work with as well. Humm...
4DRmafia is offline Report Post   Reply With Quote
Old 11-07-2009, 04:03 AM   #24841
Mr. Em1
Mr. Em1's Avatar
Send a message via AIM to Mr. Em1
what are your plans for it as far as tucking? full tuckin? removal of accessories? im curious to see what would come of it, i love those little cars.
Team Xenocron
F*CK All you Haters.
DON'T BUY FROM ROBEAR RACING. THEY WILL ROB YOU!!
Mr. Em1 is offline Report Post   Reply With Quote
Old 11-07-2009, 07:13 AM   #24842
pheurton-skeurto
which is one wire less...plus another sensor removed that could throw an unnecessary CEL.
we'll agree to disagree. it's probably not even worth discussing.
MORE BAYS!
97 Prelude
99 Civic Si
Old 11-08-2009, 11:36 PM   #24843
Mr. Em1
Mr. Em1's Avatar
i wanna see a bluetooth harness lol
Team Xenocron
Old 11-09-2009, 12:01 AM   #24844
97hontegra
97hontegra's Avatar
Can somebody please tell me how many pin outs i need in a Milspec firewall plug for a JDM 96-spec ITR engine loom. I need to know before i can order one. Thank you.
97hontegra is offline Report Post   Reply With Quote
Old 11-09-2009, 12:58 AM   #24845
Arthas
Arthas's Avatar
Originally Posted by jmaze View Post
after fresh rebuild
Thats a definite winner there!! I love your super clean semi tuck!
Did you use high temp paint for your header? My DC one is starting to look like shit and I wouldnt mind it being black.
Old 11-09-2009, 03:27 AM   #24846
pheurton-skeurto
97 Prelude
99 Civic Si
Old 11-11-2009, 12:00 PM   #24847
Captain JDM
Captain JDM's Avatar
Location: Tucking wires like crrraaazzy up and down the east coast!!
Send a message via AIM to Captain JDM
single cam engine bay looks really good. i like how even most of the plastics look nice and new.lol
Nb*Kbitches Team Fresh *Ninja Built*JDMSPEEDWORX
EK SQUAD
K20 & K24 parts, good stuff!!
Captain JDM is offline Report Post   Reply With Quote
Old 11-11-2009, 12:02 PM   #24848
Adam™
Adam™'s Avatar
Send a message via AIM to Adam™
Tuck my bay ben
FBP DC4 - Daily Dumped | Dumpedstars #13 | DC Squad #33 | RFA | MySpace
WTB: oem itr lip
Adam™ is offline Report Post   Reply With Quote
Old 11-11-2009, 12:04 PM   #24849
Captain JDM
when you want to man! im down for it. lol
woh is the chick in your avatar...damn
EK SQUAD
Old 11-11-2009, 12:06 PM   #24850
Adam™
Adam™'s Avatar
We might could start on it this weekend, ive already got some of it done
And I have not idea who she is lol
WTB: oem itr lip
Bookmarks
bay, bays, customized, engine, flywheel, h22, honda, hondatech, magazine, pics, refacing, shave, shaved, tucking, wiring
