Honda and Acura Appearance/Cosmetic Forums
> Group Threads
Old 11-03-2009, 11:31 AM   #24801
phunhaus
phunhaus's Avatar
Default Re: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
If you do it right you don't need new pins or plugs.
Sprint Hart CPR's for sale!
Silver RNR's for sale with RE01R tires!
phunhaus is offline Report Post   Reply With Quote
Old 11-03-2009, 11:32 AM   #24802
Moosecakes
Moosecakes's Avatar
Send a message via Yahoo to Moosecakes
^^ as long as you're careful you can save the pins, I just used a tiny flat head eyeglass screwdriver when I did my injector harness *nightmare...*, although a depin tool would make it a 100000x easier I think. I know there is a place in town that sells pins here, you could probably find one near you on google.
~I'm tougher than letha, I'm smootha than suede. Always neva broke, cuz I'm usually paid~
DNC #2
Moosecakes is offline Report Post   Reply With Quote
Old 11-03-2009, 12:10 PM   #24803
AdReNaLiN
AdReNaLiN's Avatar
Send a message via ICQ to AdReNaLiN Send a message via AIM to AdReNaLiN Send a message via MSN to AdReNaLiN
Originally Posted by 732xghost View Post
awesome to see a tuck/shave in a 4G prelude.
Thanks mate.
http://www.interaktiv.com.au - For all your Website Design needs.
AdReNaLiN is offline Report Post   Reply With Quote
Old 11-03-2009, 12:52 PM   #24804
dragneon
dragneon's Avatar
i used thin flexable picks to de-pin my harness
Steve Butabi: Oh my God, Doug. This is the most amazing place I've ever been.
Richard Grieco: Guys, guys. This is the coat room. The club's in here.
dragneon is offline Report Post   Reply With Quote
Old 11-03-2009, 01:11 PM   #24805
Paul1985
Paul1985's Avatar
That's right.
I use a precision screwdriver set or a sewing needle.
Always note down where each pin came from.
Post pics of the plugs you want to depin and im sure we can explain how it's done.
It's easier than you think.
My EG Build thread: Bay shave, paint, K24a etc.
http://www.honda-tech.com/zerothread?id=1717537
Paul1985 is offline Report Post   Reply With Quote
Old 11-03-2009, 01:23 PM   #24806
Adam West
Adam West's Avatar
My bay. Seam sealer removed. Still need to remove hood, hinges, and weld on new rad support, also need to sand it back down again before it get painted.
Adam West is offline Report Post   Reply With Quote
Old 11-03-2009, 03:27 PM   #24807
1337EJ1
1337EJ1's Avatar
Hi all !!
There some pics of my engine bay.
In work:
Not full complete but fine i think.
PS Sorry for my bad english, i'm french.
My French Board For Civic Coupe:
http://www.ejsquad.fr
1337EJ1 is offline Report Post   Reply With Quote
Old 11-03-2009, 04:58 PM   #24808
dragneon
dragneon's Avatar
mais alors!! bonjour copain. je suis francais aussi, mais j'abite en estas unis, en californie
Old 11-03-2009, 10:59 PM   #24809
SOHC®
SOHC®'s Avatar
Originally Posted by Paul1985 View Post
That's right.
Shot bro.. im really missioning to do it.
Wes.
98 EK hatch on boost
SOHC® is offline Report Post   Reply With Quote
Old 11-03-2009, 11:09 PM   #24810
Paul1985
Paul1985's Avatar
Wes.
It's harder mocking it up and working out your heatshrink/braid combo's.
You gotta feed the larger gear on first and you will have most plugs depinned to be able to fit it over everything. Getting it in a clean and organised fashion is quiet trickey and takes alotta patience IMO. Hard to explain, those who have done it will know what I mean.
It is a real pain to slide the braid over the wires with the pins still intact aswell.
If you had all new pins/wires it would be much easier and cleaner. Not completely necessary though, just would make life easier, and the easier it is, the cleaner it will come out.
My opinions.
Old 11-03-2009, 11:13 PM   #24811
Paul1985
Paul1985's Avatar
Oh by the way, all this talk about shielded wires and avoiding cutting them. Guess what I went and did. LOL.
I cut the thick BLK knock sensor wire near the ECU plug when shortening some wires there. All i did to fix the issue was join the power back together then taped that up, then soldered the shield back together and taped it all up.
Should be fine.
Old 11-03-2009, 11:19 PM   #24812
SOHC®
SOHC®'s Avatar
My opinions.
I would do that but the south african civics were made in south africa and the wiring is different to the US one's!
I can find a wiring diagram for my harness, even honda dont have as they were owned by Mercedes benz in SA in the 90's and when they went seperate alot was lost according to them!!!
So basically i just wanna resleeve my harness.
there is not much to do as im running a stand alone management so its just the basics for the dash board display and starter and so on.
appreciate your help
Wes
Old 11-04-2009, 03:29 AM   #24813
pheurton-skeurto
pheurton-skeurto's Avatar
My opinions.
this is a great explanation Paul. i appreciate it. Sometimes we just need a little guidance.
As for the knock sensor, do you even need it if you've gone OBD1? i have a 5th gen ('97-OBD2) prelude that's getting a 4th gen H22A1 (OBD1) motor. i was under the assumption that i could get rid of the knock sensor...am i way wrong?
97 Prelude
99 Civic Si
http://www.slowmotionmotorsports.com
pheurton-skeurto is offline Report Post   Reply With Quote
Old 11-04-2009, 04:51 AM   #24814
Andrew Marquis
Andrew Marquis's Avatar
Nah I don't know of anyone that still runs the Knock on OBD1's. I know I don't anyway... You should be A-ok homie.
1991 CRX SI GSR Powerplant. Wire tucked.
2007 Civic SI All stock.
Certified A & P Mechanic
Andrew Marquis is offline Report Post   Reply With Quote
Old 11-04-2009, 09:25 AM   #24815
jdmpnoy89
jdmpnoy89's Avatar
1991 honda civic std. (ef squad #71) - simplicity is key
bar'd as of 8/01/08
http://www.cardomain.com/ride/2478432
vouches in bio.
http://images.honda-tech.com/set1/smile/emthup.gif
jdmpnoy89 is offline Report Post   Reply With Quote
Old 11-04-2009, 09:29 AM   #24816
HatchVX
1992 Honda Civic
My Garage
HatchVX's Avatar
Send a message via AIM to HatchVX
I like the way you did the tube for the coolant reservoir
CHEAP EG PARTS
My EG build up
HatchVX is online now Report Post   Reply With Quote
Old 11-04-2009, 03:41 PM   #24817
Mr. Em1
Mr. Em1's Avatar
Send a message via AIM to Mr. Em1
Originally Posted by jdmpnoy89 View Post
very nice and clean. I'm a big fan of oem+ the more oem and clean the better!
Team Xenocron
F*CK All you Haters.
DON'T BUY FROM ROBEAR RACING. THEY WILL ROB YOU!!
Mr. Em1 is online now Report Post   Reply With Quote
Old 11-04-2009, 05:19 PM   #24818
Paul1985
Paul1985's Avatar
I have a K24A2 in my EG which is OBDII. Whether needed or not i dont know.
I just kept everything exactly as it was. Every pin went back into its original position.
The only thing I removed was the EVAP/Purge plug as i am not using it.
Old 11-04-2009, 08:06 PM   #24819
Ej8_KiD
Ej8_KiD's Avatar
Send a message via MSN to Ej8_KiD
my not finished bay
Ej8 Squad - Member #592
Ej8_KiD is offline Report Post   Reply With Quote
Old 11-04-2009, 09:30 PM   #24820
sirEGhatch
sirEGhatch's Avatar
Send a message via AIM to sirEGhatch
very very nice ef up there^^^
95 civic ex sedan h2b
08 graffiti cbr600rr
sirEGhatch is offline Report Post   Reply With Quote
Old 11-05-2009, 12:59 AM   #24821
jmaze
jmaze's Avatar
after fresh rebuild
84 city turbo- RIP
94 vx 260k strong
jmaze is offline Report Post   Reply With Quote
Old 11-05-2009, 07:24 AM   #24822
Michael_[UR]
Michael_[UR]'s Avatar
wow, the last few bays are really nice
nice tucked OEM style
not so super shaved^^
just my taste of bays
I my Honda
My Hatchback Build . . . flickr
Michael_[UR] is offline Report Post   Reply With Quote
Old 11-05-2009, 08:25 AM   #24823
Ej8_KiD
Ej8_KiD's Avatar
Originally Posted by jmaze View Post
after fresh rebuild
nice eg huh , any full car pics?
Old 11-05-2009, 11:50 AM   #24824
Hayce
Hayce's Avatar
^what? Looks left hook to me...
With the shielding, on my EK/B I extended by the ecu, the shielding doesn't go all the way to it.
EK sedan from NZ
Hayce is offline Report Post   Reply With Quote
Old 11-05-2009, 11:53 AM   #24825
HOTSAUCE01
HOTSAUCE01's Avatar
I dont see any RHD's on this page.. Nice work to the 3 bays above. The crx looks very well planned out and put together.
The single set-up looks mint.. Like it just came from honda that way.
-Is the header painted, jetcoated?
WTB: crx b series w/cable trans mounts. PM ME
HOTSAUCE01 is online now Report Post   Reply With Quote
Bookmarks
bay, bays, customized, engine, flywheel, h22, honda, hondatech, magazine, pics, refacing, shave, shaved, tucking, wiring
