#1726 | |||||
2000 Honda CivicJoin Date: Aug 2009
#1727 |
i built my b20 crv block with b16b head . thx to the guide , i used it when my mechanic have issues with part compatibility and torqueing figures
anyway , i am comtemplating to change my current crower stage2 cams to either brian crower 3 sk2 pro3 buddy club 4 or 5 running on c.r 14 and 84.5mm pistons i am leaning more to brian due to cost. but would like to hear 1st hand experience from your guys. p.s they are all great cams! rock on, bambam and the rest of the members !
#1728 |
great!
Jason thekartshop at hotmail dot com |
#1729 |
very helpful to me! thanks!
#1730 |
I dont exactly feel like looking through all 70 pages. But has anyone ran ls block,ls rods and crank,ctr pistons,gsr head shaved .0010 and aftermarket cams safely without any tapping of the quench pads?
My exact setup will consist of ls block with ctr pistons and arp rod bolts. simple bottom end. Gsr head with BLOX HSL cams shaved 10 thousandths with supporting bolt ons and valve train. |
#1731 |
1997 Acura Integra |
ctr pistons are shit, dont use them.
use p30's.
[Formly Known as Integratype-R] www.9400rpms.com InnovativeMotorWorks |DFE Enterprises |Rocket MotorSports|cccylinderheads.com eCtune PRO,NeptuneRTP, & CromePRO Tuner / Supporter - Rocket MotorSports Dealer |
#1732 |
What makes them shit? They are identical to p30 other than the dome and height.
#1733 | |
They aren't in anyway identical to p30's. P30's are used as a good solution to people wanna bump the compression up, and have a good flame and piston weight CTR pistons are called slugs for a reason. They are the heaviest piston for b series.. and the dome is entirely too fat and big, it spreads the flame too thin and doesn't allow for the correct combustion process.. other pistons come to a point, you'll notice on ctr's at the top of the dome is almost flat for 3/8ths of a inch which spreads the flame too thin.. ctrs are ****en garbage. They belong in nothing but a b16.
#1734 | |
H-T Basic Sponsor
Robert (909) 592 - 4311 ext.102 Robert@goldeneaglemfg.com www.goldeneaglemfg.com XBL/mastermind1ra Last edited by Golden Eagle; 09-22-2009 at 09:03 AM. |
#1735 | |
so there's no reason why the combustion process is effected by the ctr piston correct? it doesn't spread the flame too thin? and far apart? my bad bro.. because it works for you, doesn't mean its correct.. i'm not bashing and I dont have bad info. take your "it works for me so its right attitude" somewhere else. I'll clear up some other misinformed information too.. CTR pistons no matter what you have, with a gsr head, you run into p2v clearence issuse with being able to only run a limited gap of 2-3 degrees retarded or advanced w/o having problems. There's been many cases where the ctr pistons "tap" the chambers of a gsr head.. even with a 3layer HG.. p30's provide a good compression relation they are trying to get with ctrs and allow for good clearences.. You can say you ran ctr pistons all you want.. it doesn't mean its right. btw i've never called a piston a slug.. except the ctr's because they are so big and heavy.. not to mention.. on a longer stroke these pistons put more pressure on parts. btw nice Headgasket, made my b20vtec life easier.
[Formly Known as Integratype-R] www.9400rpms.com InnovativeMotorWorks |DFE Enterprises |Rocket MotorSports|cccylinderheads.com eCtune PRO,NeptuneRTP, & CromePRO Tuner / Supporter - Rocket MotorSports Dealer Last edited by ALL M0T0R; 09-22-2009 at 09:16 AM. |
#1736 | |
H-T Basic Sponsor
Robert (909) 592 - 4311 ext.102 Robert@goldeneaglemfg.com www.goldeneaglemfg.com XBL/mastermind1ra Last edited by Golden Eagle; 09-22-2009 at 10:33 AM. |
#1737 | |
#1738 |
H-T Basic Sponsor
i do
Robert (909) 592 - 4311 ext.102 Robert@goldeneaglemfg.com www.goldeneaglemfg.com XBL/mastermind1ra |
#1739 |
Back on topic.
Even if I were to have a 3 layer gasket, there would not be enough clearance to run higher and longer lift duration cams? |
#1740 |
the fact that u hav to create an end all/ultimate thread on how to build a "RELIABLE" LS VTEC should be an indication that it is forsaken.
Optimized VTECs Are Better Than Sex! THE 10,000 RPM JUGGERNAUT STRIKES AGAIN!!!! Creator Of The "DREAM B" |
#1741 |
pretty much step for step how to build lol
#1742 |
dude, thanks for this very comprehensive instructions. i have been looking such an article and i found it here. i will try this on my dad's and will follow instructions. anyone who has followed instructions?
#1743 |
For my Ls Vtec i'm about to drop,
I have a LS block with some P30 pistons (11.6cr), and I want to run a high compression gasket (+.4cr) with BUDDY CLUB 4 camshafts. Should I run the high comp gasket, or go with the one from the Golden Eagle LSvtec kit ? Will there be a higher chance of valve / piston contact with the HIGH COMP gasket? Thanks for your help B |
#1744 | ||
Taking material away from the gasket obviously causes the head and block surfaces to be that much closer together. The spec4's don't have an extremely large lift (12.3mm int, 11.8mm exh), so I would guess, and mind you it's only a guess, that you should be ok with V/P clearance. What is the actual thickness of the gasket? And of course to be sure, you can always time your motor before installing it, and rotate everything with vtec engaged to make sure you don't hit....
#1745 |
#1746 |
question. what hp numbers did u get outa that build??
95 ex coupe wreaked http://images.honda-tech.com/set1/smile/emsad.gif 95 eg hatch w/B16 built http://images.honda-tech.com/set1/smile/emsmile.gif |
#1747 |
great info...thanks
#1748 |
anybody know where to get a 96-98 manual crv transmission
#1749 |
how much whp did it make
| Bookmarks |
| Tags |
| b16a, b20, build, built, gasket, head, honda, ls, lsvtec, make, motors, reliable, remove, rivits, vtec |
