> All Motor
Old 07-02-2006, 12:47 PM   #26
sheepey
2000 Acura Integra
My Garage
sheepey's Avatar
Send a message via AIM to sheepey
Default Re: (bambam)
Originally Posted by bambam
That is directly from ARP's instructions man.
cool cool. Thank you sir
sheepey is offline Report Post   Reply With Quote
Old 07-02-2006, 01:09 PM   #27
vivid 02
vivid 02's Avatar
Send a message via AIM to vivid 02
Default Re: (sheepey)
Very nice write up
1998 INTEGRA TYPE R 2.1L ALL MOTOR JERRY BUILT
238 WHP @Do-It-Dyno thru exhaust;12.494 @ 110.12 mph BOTI Street Stock
2007 Ridgeline RTLTow;2004 BMW 330i Daily. Best prices go to Tommy Gun @ camp1320
vivid 02 is offline Report Post   Reply With Quote
Old 07-02-2006, 06:32 PM   #28
schpootypie
schpootypie's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (bambam)
Awesome write-up. But I have one question, what ecu do you recommend using on a LS/Vtec setup? Also, I'm planning on doing a LS/VTEC build this winter, would it be OK to PM you any questions I have?
Check out the hatch!!!!!!!!!!!!!!!!!!!!!!!
http://www.cardomain.com/ride/2160665
schpootypie is offline Report Post   Reply With Quote
Old 07-02-2006, 06:48 PM   #29
bambam
bambam's Avatar
Send a message via AIM to bambam
Default Re: How to build a "reliable" lsvtec/b20vtec (schpootypie)
You can PM with ANY questions you may have.
As for the ecu. Honestly, it doesn't matter since you should be chipping it and tuning it anyway. A chipped P28 will work fine, as long as you get it tuned.
There isn't any one ecu that is going to work correctly for this setup. It's not a stock honda motor and honda never made an ECU to go with it, obviously. There is not a "best" stock ecu for this kind of setup.
-Vouches are in my Bio.
http://images.honda-tech.com/set1/smile/emthup.gif All-Motor Forum
'03 ABP RSX Type-S
NAVY. Out to sea until Early September. Sorry fellas.
bambam is offline Report Post   Reply With Quote
Old 07-02-2006, 06:59 PM   #30
EK Josh
1997 Acura Integra
EK Josh's Avatar
Somewhat of a random question considering the amount of info in this thread, but when you installed the valve cover did you use any sealant? Or did you simply clean the surface areas, put the gasket on the valve cover and then torque everything down?
||'97 Integra GS-R||
EK Josh is offline Report Post   Reply With Quote
Old 07-02-2006, 07:25 PM   #31
bambam
bambam's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (GGhatchie)
If you look closely at the valve cover gasket, there are little square shaped "pads" in some areas. Apply a SMALL dab of RTV there. That'll do it.
'03 ABP RSX Type-S
Old 07-02-2006, 07:33 PM   #32
Stins~b20VTEC
Stins~b20VTEC's Avatar
good info bro...wish i would have seen this before i posted about most of the shit you already put out...
the hatchback brigade...
jus cuz you pour syrup on shit...it doesn't make it pancakes...
Stins~b20VTEC is offline Report Post   Reply With Quote
Old 07-02-2006, 08:44 PM   #33
EK Josh
1997 Acura Integra
EK Josh's Avatar
Thank you. Awesome thread. I have it bookmarked now
||'97 Integra GS-R||
Old 07-02-2006, 08:53 PM   #34
itgsr98
itgsr98's Avatar
Now that the head is installed, we may install the oil line and timing belt. Follow the instructions included with your lsvtec oil line kit, as every kit is different. But, what ever you do, don't forget to teflon tape all fittings! The kit I am using is from full-race.com and is a proven kit. It replaces the factory oil pressure sending unit with a "T" in which the unit and oil line are screwed into. It's simple, and that's why I like it. I like the Golden Eagles oil sandwich adapter, but they include the wrong head gasket in there kits, which is why I will never use one.
[/i]
question? what's wrong with the golden eagle head gasket fitment. i just finished an ls/vtec build using there vtec kit and didnt notice any issues. plz explain. thanks.
"Don't pretend to be someth'n your not, just be who you are. That's what's really cool".
itgsr98 is offline Report Post   Reply With Quote
Old 07-02-2006, 09:06 PM   #35
bambam
bambam's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (itgsr98)
Alot of people have had problems with the vtec head gasket. You are supposed to use the gasket that matches the block with this setup to prevent leaks.
You may or may not experience leaks. If you don't, cool. If you do, buy the gasket that matches the block.
Modified by bambam at 10:01 PM 2/29/2008
'03 ABP RSX Type-S
Old 07-02-2006, 09:19 PM   #36
red808teg
red808teg's Avatar
fabulous, the has been none greater than this thanks alot you cleared up some very unanswered questions I had
red808teg is offline Report Post   Reply With Quote
Old 07-02-2006, 09:54 PM   #37
EK Josh
1997 Acura Integra
EK Josh's Avatar
I plan on building a b20vtec and when I've looked online at the GE lsvtec conversion kit it always gives you a choice of what size headgasket you would like to purchase. Usually it's between 81-86mm.
For reference - http://robearracing.com/pd_gol...n.cfm
||'97 Integra GS-R||
Old 07-02-2006, 10:00 PM   #38
Cesar_CPR
Cesar_CPR's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (SiR Inspired ED7)
nice build
Cesar_CPR is offline Report Post   Reply With Quote
Old 07-02-2006, 10:36 PM   #39
bambam
bambam's Avatar
what's your question?
'03 ABP RSX Type-S
Old 07-02-2006, 10:48 PM   #40
EK Josh
1997 Acura Integra
EK Josh's Avatar
You were saying that the GE kit provides the wrong headgasket, but that link shows you being able to select the gasket you need. I guess I was just pointing out the fact that maybe that's a new thing and I wasn't sure if you were aware of it.
||'97 Integra GS-R||
Old 07-02-2006, 11:33 PM   #41
bambam
bambam's Avatar
no...I was saying that the "vtec" headgasket is the wrong headgasket. It doesn't matter which one's you can select...they're vtec headgaskets.
'03 ABP RSX Type-S
Old 07-03-2006, 12:37 AM   #42
EK Josh
1997 Acura Integra
EK Josh's Avatar
Thank you for the clarification. I guess it doesn't matter if I choose the correct bore because the gasket is wrong either way. You saved me another headache
||'97 Integra GS-R||
Old 07-03-2006, 09:43 PM   #43
she_go
she_go's Avatar
Send a message via AIM to she_go
nice write up with detailed pics
don't be ignorant...ask questions
she_go is offline Report Post   Reply With Quote
Old 07-03-2006, 10:33 PM   #44
DC2 Mang
DC2 Mang's Avatar
Default Re: (kaoss_11)
very nice write up
the solution to the all too common lsvtec questions
96 Toyota Tacoma 4x4
DC2 Mang is offline Report Post   Reply With Quote
Old 07-04-2006, 12:24 AM   #45
No_Fear
No_Fear's Avatar
good article
Face your fears, Live your dreams. http://www.nof3ar.cjb.net
EK9 Powerd by TRIAL
No_Fear is offline Report Post   Reply With Quote
Old 07-04-2006, 05:06 PM   #46
iheartmyej8
iheartmyej8's Avatar
can you use b16 oil and water pump?
00 ebp em1 daily
96 hatch project auto-x ***my build***
iheartmyej8 is offline Report Post   Reply With Quote
Old 07-04-2006, 06:07 PM   #47
bambam
bambam's Avatar
Default Re: (iheartmyda)
Yes, B16 water pumps are the same as the ITR/GSR pumps, as well as the CTR pumps. All dohc vtec bseries water pumps are 22T. As for the oil pump, it depends on what year the pump is from.
You want an oil pump from a 94+ GSR or 96+ LS/ITR/CTR/B16. If its a PRE-96 B16 oil pump, it will work, but won't pump at the higher rate.
I also went back and edited that part, so that there won't be any futher confusion.
'03 ABP RSX Type-S
Old 07-04-2006, 08:24 PM   #48
iheartmyej8
sweet. just a question i have been meaning to ask someone with some knowledge. i got a b16a2 oil and water pump. thanks for the clarification.
my ls.v is up for sale.....
http://www.honda-tech.com/zerothread?id=1679696
00 ebp em1 daily
Old 07-04-2006, 10:25 PM   #49
98vtec
98vtec's Avatar
great thread, should go in the FAQ
98vtec is offline Report Post   Reply With Quote
Old 07-05-2006, 11:59 PM   #50
oldskool teggy
oldskool teggy's Avatar
Send a message via AIM to oldskool teggy
Default Re: (98vtec)
do you think that the stock rods with arp rod bolts and acl bearings will take 9500 rpm needed on skunk stg 2 and bc stg 4? or is 9k the limit you take yours to?
265's, ban-vecs, exc mesh, super fins, mkIIs, equips, betas, deltas, ewings, emotions, gales... JDM before there was even a name for it! Oldskool is the best school....
http://g2ic.com/forums/image.php?u=8...ine=1227323780
oldskool teggy is offline Report Post   Reply With Quote
Bookmarks
b16a, b20, build, built, gasket, head, honda, ls, lsvtec, make, motors, reliable, remove, rivits, vtec
